X-E1 + 60mm (latest firmware)
Started Oct 5, 2015 | Discussions
Turlututu Regular Member • Posts: 268
I'd like to know your opinion on this combo. There are few reviews on internet of this specific combo and firmwares have maybe improve the user experience ? Please share your experience !
My needs : portraits and close-up. I wonder if the auto-focus will be efficient ? Do I need to use the macro-mode on X-E1 ? How does it compare with 56mm for portraits ?
Autofocus is fine for my needs in daylight / single point AF with 18-55mm, slow and sometimes never lock in dim light, and I don't use tracking often.
 Turlututu's gear list:Turlututu's gear list
Fujifilm X-E1 Samyang 8mm F2.8 UMC Fisheye Fujifilm XF 18-55mm F2.8-4 R LM OIS
Fujifilm X-E1 Fujifilm XF 60mm F2.4 R Macro
57LowRider Veteran Member • Posts: 4,240
Re: X-E1 + 60mm (latest firmware)
Don't know about this particular combo but top tip - if AF is struggling in low light, snap to MF and hit the AE-L / AF-L button. For reasons known to nobody, this often works when AF is completely banjaxed by the light level.
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +11 more
Vic Chapman Forum Pro • Posts: 10,694
Agreed with the above.
The 60mm f2.4 is an excellent portrait lens. While not able to provide quite as narrow a depth of field as the 56mm f1.2 it does have 9 bladed aperture which helps give a really creamy bokeh to out of focus areas. As a macro - well true macro is 1:1 whereas the 60mm is 1:2, so a close focusing lens really but this lens works really well with extension tubes and being small and light it is fine with the cheap "Pixco" ext tubes. For most work the close focus suffices. Switching the XE1 to macro with any lens simply biases the AF to look nearer for focus point - so yes, use it.
For me the 60mm f2.4 is a great portrait lens for close quarters portrait work especially studio but don't confine it portrait/macro - it is a fine lens for picking out detail in wider areas too - as below
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
baobob
baobob Forum Pro • Posts: 18,248
The 60mm is stellar in terms of res
To have a responsive lens since it's a macro design you always need to prefocus in order to avoid the lens going from narrow to infinity or the reciprocal With the latest firmware and XT the lens is quite fast
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
baobob
I just retriedmy 60mm right now
As long as you prefocus once to be at your working distance the AF is fast
Moreover it focuses now easily in low light especially with the biggest size of AF sensor which makes it a useful portrait lens in dim light
Focus peaking is a pleasure with max redlight for FP since the 2.4 aperture maximize the FP signal in the EVF
Strong, small light non intrusive, a gem
OP Turlututu Regular Member • Posts: 268
Thanks ! Gonna try this trick !
Thanks all ! I may give the 60mm a try sooner than later
I like how small and inexpensive it is comparatively to 56mm and I'm already used to slow autofocus with X-E1 then...
slimandy Forum Pro • Posts: 17,161
The 60 is surely the answer then.
Certainly good enough. It's not the quickest, especially on the X-E1, but you're not shooting sport. I like MF for close-up and for posed portrait anyway (even on the X-T1). I like using MF with the AF button on the rear of the camera - that gives you AF with MF as well and won't change focus when you go to click the shutter. This actually works better on the X-E1 than X-T1 because the button on the E is bigger.
Apparently this helps but I tend to forget! Maybe it's not an issue for me because for macro I will always use MF. It's no longer an issue on the X-T1 that I use anyway since the firmware upgrade.
As good in my experience, unless you want very shallow DoF. IQ is as good and focussing isn't far off either, neither lens being quick.
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Fujifilm X-E1 Fujifilm X-T1
Thanks for the answer !
Make sense
Other alternative is 56mm + legacy lens (I have a Kiron 105mm 1:1, Minolta mount, but it's huge, manual focusing and focal length is too long...). 60mm seems a smaller alternative.
Do you try it with moving people or kids ?
I'd like a similar firmware update on X-E1 but I guess it's too old and contrast-only AF makes it impossible...
I read the Fuji vs Fuji comparison between both lenses and 60mm seems nice.
baobob
The limiting factor for you will the XE1 not the 60mm as I posted earlier with XTs the 60mm is rather fast once it has acquired the working distance and continuous AF on XTs wit the 60mm works rather well so probably ok with kids just playing around
I find it (in the conditions mentionned) faster than the 18-55mm that I find very slow
I don't know about XE1 performance with the latest Fw you should try
I use the 18-135mm with rather rapid and erratic movements but it's quite a big lens, that  however fits well even on the small XT10 (smaller than XE1)
Make sense
To be fair a legacy lens might still make sense. 60 doesn't give you much working distance and the Fuji isn't 1:1. For this reason I also have a Tamron 90.
Yes, but I managed to get shots of my kids with a manual focus film camera too!
Yes, an upgrade to the X-T1 would be a noticeable improvement if the E-1 is proving tricky, or maybe an X-T10. The X-E1 is a nice camera though. Excellent IQ.
I have used both too.
James_MG Contributing Member • Posts: 772
Great combo and very fast, just picked up the 60mm a couple months back and enjoy the lens. Also recently picked up the x-T1 and while faster i was expecting a much bigger improvement.
Did you check the FW - vers 4.0  and make sure the lens FW is up to date also. The 60mm still isn't blisteringly fast but similar to the 56mm f1.2 now and is less likely to hunt.
Spike Milligan
baobob
James_MG wrote: picked up the x-T1 and while faster i was expecting a much bigger improvement.
The 60mm has a macro lens design plus an old mechanical engine so whatever is the AF system it will somehow remain slow
For fast operation with XT1 always prefocus to your working distance, then the AF is fast since focus is achieved with PDAF sensors. When CDAF sensors are involved the lens is slow to focus.
Avoid the focus from infinity to close and the reciprocal, macro lenses are very slow to perform focus from one extreme to the other. CAF is not reliable with this lens due to slow motion of the focus engine.
Thanks for the reply, not meaning to hijack thread, but if i could ask a simple question on continuous focus. I have two small boys (2 years and 12 months). They do not remain still, if I use zone with AF-C, do i also need to move the switch on the body (M/C/S) to C?
Thanks much, hoping to post a new thread on my thoughts of my x-e1 vs x-t1 plus the fabulous 60mm.
