Looking for a small pocketable m4/3 solution...
Started Oct 1, 2015 | Discussions
Yannis1976
Yannis1976 Veteran Member • Posts: 6,309
...for all these moments that would like to have a small camera with me (in my bag, car almost everywhere). I was thinking of the following:
1) used Oly EPM1
2) used Oly EPM2 (rather expensive)
3) used Panny GM1 (best but even more expensive)
4) used Sony RX 100 (even more expensive!!)
The EPM1 can be found in ebay rather cheap, but is it worth it? I will complement it at the beginning with the 20mm/1.7 and later either with the Oly 17/2.5 or the Pany 14/2.5
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Olympus PEN E-PM1 Olympus PEN E-PM2 Panasonic Lumix DMC-GM1
bssfujifan Forum Member • Posts: 88
Re: Looking for a small pocketable m4/3 solution...
Hi,
I realise the Panasonic LF1 is not a m4/3 camera, but it it will fit comfortably in the smallest of pockets, e.g. a shirt breast pocket and it does have a sensor larger than the typical compact camera, a decent 28-200 equivalent lens and, importantly for me, full APSM controls. It does have its shortcomings, but one of them is not 'the camera that was too big to take with me'. At present it can be bought new for £199. I have one and do not regret buying it as an alternative to my G6 and GX7. An added bonus is that I can have it with me without my wife knowing when she says 'I hope you're not going to be taking pictures all the time!' as we are ready to go out for the day!
 bssfujifan's gear list:bssfujifan's gear list
Panasonic Lumix DMC-FX07 Panasonic Lumix DMC-LF1 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +7 more
dwkyre Regular Member • Posts: 212
The GM1 is more compact than the E-PM1 and is most likely going to give you more pleasing image quality. Pair it with the Panasonic 14mm or the kit 12-32mm and you with have great capabilities in a tiny package. Pair it with one of the body cap lens and you will have the most pocketable m4/3 solution available.
Yeah, you can get the E-PM1 cheaper, but it depends on what you want out of it. I think you would have a hard time being unhappy with the GM1 solution.
 dwkyre's gear list:dwkyre's gear list
Panasonic Lumix DMC-GM5 Panasonic G85 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic 20mm F1.7 II +6 more
addlightness Veteran Member • Posts: 3,641
I bought a GM1 on ebay($290) as a 2nd/backup m43 body (to my EM10).  It's paired to my 3 pancake lenses - 9mmBCL, 14mmf2.5, 17mmf2.8.  IMO, not exactly pocketable (even with 9mmBCL) but in a small camera bag, it's very portable and lightweight.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
jwilliams Veteran Member • Posts: 6,400
1) used Oly EPM1
I have both the GM1 and RX100 MK1. Both very fine cameras. I prefer the GM1, but that is mostly personal preference and both are very good carry along cameras. The RX100 is more pocketable do to the lens collapsing into the body making it a good bit thinner. The GM1 (w kit lens) starts wider at 24mm equiv, but only goes to 64mm equiv, where the RX100 goes from 28-100 equiv. Image quality is a wash for most purposes. The GM1 has a larger sensor, but the RX100 has a faster lens so that mostly offsets the sensor advantage.
If you just want something pocketable the RX100 is hard to beat because it is truely pants pocketable. The GM1 needs big pockets to carry and is more bulky.
If you are interested in a camera to use with other lenses the GM1 wins hands down in my book. I wouldn't consider either of the Oly EPM cameras. The GM1 is a marvel of engineering and a joy to use. Be warned the kit lens is very good and I rarely take it off. I do sometimes carry an Oly 45/1.8 along if I need more reach and or speed. It makes a nice compliment to the kit lens. I already had the Oly but if I was buying now I would get the Panny 42.5/1.7 due to the in lens IS.
Jonathan
Yannis1976
OP Yannis1976 Veteran Member • Posts: 6,309
I think its not a bad idea to have a look at the 1/1.7 or 2/3 sensors like the LF1 or XQ1. It certainly is more affordable vs the GM1...
007peter
007peter Forum Pro • Posts: 12,933
don't forget Panny GF3/GF5/GF6/GF7 (quite amazing), even older GX1
If size is a priority, I would definitely look into buying GM1/GM5/GF7 (more expensive) or the older but really cheap GF3/GF5 and GF6
I just bought a GF6 (selfie screen, Wireless Flash control) and is very please with it.  The IQ is lightyear from GF2/GF3 that I had years ago, and the support for external wireless flash sync makes the lack of hotshoe liveable.  I also much prefer Panasonic 3:2 screen ratio that result in much bigger image than I do with Olympus EM1/2's 16:9 ratio.
Lastly, remember that Amazon is selling the Olympus E-PL6 for just $299!
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
robsta Junior Member • Posts: 41
I just bought an immaculate E-PM1 body on ebay to take on holiday. I teamed it with the Panasonic 12-32mm lens, which wasn't quite "pocketable" but wasn't too bulky either. I've got to say I was incredibly impressed- its low-light performance knocked spots off my G3, to the point that I never used the flash, even in low-lit bars at night time.
Just before I bought mine, another I was watching on ebay went for £50 including kit lens. At this kind of money I certainly wouldn't right it off as a contender.
 robsta's gear list:robsta's gear list
Casio Exilim EX-Z850 Nikon Coolpix L120 Panasonic Lumix DMC-G3 Olympus PEN E-PM1 Sigma 19mm F2.8 EX DN +5 more
peppermonkey Veteran Member • Posts: 5,204
Never owned either...but doesn't the E-PM1 have the same 12mp sensor as the first gen m43 cameras? And doesn't the G3 have the (then new) 16mp sensor that came with the GX1? If that is the case, I'm pretty sure the G3 would have better IQ than the E-PM1...at least in RAW. I know Oly had better jpeg engine then so I would guess jpeg wise the Oly would win but RAW wise, I would think the G3 would win...
Hubert
My non-digital gear: Agfa Isolette, Ricoh Ricohflex VII, Voigtlander Bessa R, Voigtlander Bessa L, Zorky 4, Fed 2, Konica Big Mini, Konica Auto S2, Pentax K1000, Yashica Electro 35 GX, Recesky
http://farm3.static.flickr.com/2034/2457111090_00eafbf8a4_m.jpg
http://www.flickr.com/photos/peppermonkey/
 peppermonkey's gear list:peppermonkey's gear list
Panasonic Lumix DMC-TZ3 Sigma DP2 Sony RX100 II Pentax K110D Panasonic Lumix DMC-GF1 +11 more
mh2000 Senior Member • Posts: 2,813
I played around with the EPM1 and thought it handled really well! I think it would pair better for a travel camera with the smaller Oly 17/2.8, but the 20 you are planning to start with is faster and better (but I prefer the FL and other stuff about the 17... but that's me).
Regarding the sensor, it's the same as in my E-P1 and I get fantastic photos from that body still.
My daughter has an EPM2 and it's definitely nice, but don't think it blows away the EPM1 for image quality and AF in the EPM1 is already very fast as it is.
I kind of like shooting modest gear.
I just missed out on a cameta camera EPM1 refurb deal a long time ago.
If it wasn't for the size, I'd almost recommend getting an E-P1 or E-P2. They go for a song and the more "flagship" designs are still an absolute joy to use. Still shooting mine anyway and still happy. The price drops on the original OM-D's are getting temping for an upgrade... but haven't jumped.
Regarding lenses, I was never thrilled with the P14/2.5. I have one somewhere, but never use it. I love my working set of Oly 17/2.8, Oly 25/1.8 and Oly 45/1.8 -- great classic set of primes!
Good luck! Really, you can't go wrong!
You're right about the sensors, but as regards to RAW I couldn't comment (I'm not into post-processing so only use JPEGS). But purely in terms of low-light performance the Oly took shots I would never have got with the G3. I don't know if the Oly's IBIS is better than the Panasonic's OIS or what, but it just totally out-classed it in low-light situations.
MOD Tom Caldwell Forum Pro • Posts: 46,360
When cost becomes the sole criterion
1) used Oly EPM1
My guess - you tend to get what you pay for .....  If cheapest is what you can afford then the EP-M1 is just what you need.  And of course no matter what you buy the lenses are the same - except for the RX100.
Tom Caldwell
Back in the day when the G3 was heavily discounted/discontinued, I looked into this and the consensus was that IQ was still very comparable (first gen 16MP sensor) -- noise might have been a little worse, but came with a little higher resolution for cropping. So people may argue, but it didn't seem like a compelling difference back then. The newer 16MP sensors are better now. Still, when I compared the new16MP sensor images to my E-P1, it didn't make a *huge* difference either... though I think the low light capability is better now.
Re: When cost becomes the sole criterion
Tom Caldwell wrote:
1) used Oly EPM1
This is usually only true when you are comparing current technology. I bought my E-P1 at a close out price of 1/3 of the E-P2 -- no way can you say the value was only 1/3rd of the E-P2! I like the size of the EPM1 and the design. Personally, I think I'd see more bang for my buck in adding nice lenses to the EPM1 than sacrificing lenses to step up in bodies. And remember, the EPM1 could completely compete with the E-P3! That means you are getting the same IQ performance as you got from what was once a $1000 camera! And as I said above, the EPM1 has fantastically fast AF as well! I think it was billed as (briefly) having the fast AF of any camera when it came out!
BigGG Contributing Member • Posts: 933
The best small (pocketable) camera that I have the RX100m1... I bought it for $400 about three years ago. About three months I told my sister about it and she bought a RX100m1 new for $349 and no tax....  Sure the mk2,3,4 have slightly better specification but you cannot beat the price/performance of the RX100/m1...  The best camera in the world is the one in your hand when you need it.
GaryG
 BigGG's gear list:BigGG's gear list
Sony SLT-A77 Sony Alpha a99 Sony a77 II Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH +43 more
mh2000 wrote:
Tom Caldwell wrote:
1) used Oly EPM1
Mark
.... well - (eyes wide open) - go for the E-P1 .... cheapest and the best .... there is no need to discuss this any further ....
Tom Caldwell
I have to agree- I paid £75 for my E-PM1 body, with a 493 shot-count and two spare batteries. How much more would I have had to spend to get a significantly better body?
On Amazon UK the E-MP1 kit is half the price of the E-PM2- is the latter twice as good?
If you are NOT going to ever change lenses...
1) used Oly EPM1
Then just get the RX100. It's tiny, has a really fast lens, and would have better high-iso compared to E-PM1. Well, at least, my RX100 MKII had much, much better high-ISO compared to my ancient GF1...which should be the same sensor as the E-PM1.
In general, the lens on the RX100 would be faster than all kit lenses on M43 and have more tele except the M43 super zooms...which aren't really kit lenses (and they are expensive).
If pocketability is of great importance..then RX100...no question asked.
If you want to have more then one lens, then RX100 is out obviously.
As someone already mentioned, I would also look into the Panasonic GF3, GF5, GF6, GF7. Albeit, only the GF6/7 have the 16mp sensor so IQ wise those two would be equal to the GX1.
Although the E-PM2 has a 16MP sensor, if I'm not mistaken, that's the same 16mp sony sensors that are in the Oly E-M5's so should be slightly better than the GX1, albeit, I doubt you would see too much difference.
So...unless you can find the E-PM1 for a song... I would look into the other models.
IQ wise, E-PM1 = GF3 = GF5
while GX1 = GF6 = GF7 = E-PM2 (roughly)
I would put the high-ISO capability of the RX100 to be somewhere comparable to the 16MP sensored cameras, albeit, if you have the right lens, all the M43 cameras can produce better images. But if only using kit lenses...
Hubert
Ahh...my memory certainly sucks...
Don't recall that at all, lol. Then again, never looked into the G3 so probably didn't notice. I do remember when the GX1 came, it was (extremely briefly) thought to be the best m43 camera (excluding the GH line?) at the time, and I'm pretty sure that was the first time M43 had 16mp sensor? Still, the major boast in sensor IQ came with the E-M5's 16mp sensor which came out...like a month or three after?
Anyhow, yeah, in general, I do agree with what you say.
Hubert
Re: If you are NOT going to ever change lenses...
This might sound like an out-dated suggestion, but I owned a Panasonic LX3 (that I should never have sold) that was the best pocket camera I've ever owned. Zoom was severely lacking, but for what it was it took an excellent photo.
