1200D / T5 HSS (High Speed Sync)
Started Sep 28, 2015 | Discussions
rjhp New Member • Posts: 2
Good day everyone,
I'm up to buying a new speedlight and I'm thinking about the Yongnuo YN 560 IV over the YN 560 III for it has wireless master mode and High Speed Sync (HSS) capability.
However, I'm wondering if the T5 / 1200D actually supports HSS flashes? I could not find reliable information using Google or the manual.
Thank you!
 rjhp's gear list:rjhp's gear list
Canon EOS 1200D Canon EF-S 18-55mm f/3.5-5.6 IS II +1 more
Canon EOS 1200D (EOS Rebel T5 / EOS Kiss X70)
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: 1200D / T5 HSS (High Speed Sync)
The built-in flash cannot do HSS, but the camera can do HSS with an ETTL compatible speedlite with that capability.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
BarnET Veteran Member • Posts: 3,581
Good day everyone,
Thank you!
HSS isn't a camera feature it's a flash feature.
That said the yn 560 doesn't have ttl. yes it can fire multiple times in quick succession for HSS capability but you have to set it up manually.
Which the average 1200d owner is never gonna do.
Yongnuo does have TTL capable flashes. these are the yn 568 EX flashes. They will only have that capability with the 1 system it's sold for. A canon version will not TTL on a Nikon body or the other way arround.
 BarnET's gear list:BarnET's gear list
Panasonic Lumix DMC-GX7 Fujifilm XF 18-55mm F2.8-4 R LM OIS
OP rjhp New Member • Posts: 2
Hello everyone and thank you for the kind replies.
From what I thought HSS compatibility was a feature that both the camera and the flash needed to support, but it seems that I was wrong on that.
Is HSS exclusive to E-TTL?
If I buy a manual flash that is advertised as supporting shutter speeds "1 / 200s ~ 1 / 20000s" can I expect to just set the flash time to 1/4000, my shutter speed accordingly to 1/4000 as well and be golden?
Does HSS only describe the ability to have your camera set flash times above 1/200 electronically via (E-)TTL?
Thanks to all of you lifesavers!
E-TTL = external TTL. So the flash will talk to the camera and adjust it's output even when it is not mounted on the camera. This is mostly exclusive to Canon speedlites.
TTL means the camera can talk to the flash by the hotshoe and use automatic metering. But not when it's firing off camera. Like the Yongnuo 568EX
You don't need TTL for HSS however adjusting the flash power frequency and flash count manually based on your scene and settings will be way over your head.
No it will sync up to the max flash sync speed of your camera. which is probably arround 1/200th of a second. Above that you will see black borders of vignetting coming in from the bottom. This is due to the physical shutter being in front of the sensor during the exposure. Look up some high speed footage of shutter in motion on youtube just click this link
https://www.youtube.com/watch?v=CmjeCchGRQo
As you can see the physical shutter rolls from top to bottom at faster shuterspeeds. That means the flash can't light the whole sensor at once. Therefore it needs to fire multiple times while the shutter moves along. lighting each part of the sensor till the exposure is complete.
Programming that manually is hard and requires some calculations. And that comes on top of the already complicated values on flash power.
It's just too much for a beginner to deal with. So yes the 560 IV i have here can do HSS. But i generally don't use it since ND's work just as well outdoors to limit shutterspeed under flash sync. And i tend to use these indoors in a studio environment. Which means i am basically at max flash sync and without ambient light impacting my images.
HSS means the flash is capable to fire at a lower output in rapid succession. See it as a machine gun.
If it has TTL the flash can do this automatically based on your faster shutterspeed. You only need to program it to that mode.
You can get HSS with a manual flash but it's not as convenient and for a beginner very confusing.
WilbaW
WilbaW Forum Pro • Posts: 11,643
BarnET wrote:
AFAIK, all Canon DSLRs support all functions of all Canon flashes, so if your flash is E-TTL compatible and does HSS, you can do it.
E for evaluative. Works the same whether the flash is built-in or external.
Check out the unofficial Rebel Talk FAQ.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
WilbaW
If we're talking about Canon bodies, effectively yes, but the camera has to collaborate with the flash for it to happen, so it's not like you can put an HSS flash on any non-Canon body and it will work.
LKFX_House
LKFX_House Regular Member • Posts: 334
So  what do you have to take into account if you have a canon entry-level camera and would like to try HSS?
 LKFX_House's gear list:LKFX_House's gear list
Canon EOS M Sony a6000 Sony a6300 Sony a6400 Sony E 18-55mm F3.5-5.6 OSS +10 more
R2D2 Forum Pro • Posts: 26,551
The body is capable.
You need to check if the flash is.
R2
