Best FF lens as a midrange on an APS-C
Started Sep 28, 2015 | Discussions
RS22 New Member • Posts: 24
I'm currently shooting with a Rebel T2i, but am hoping to upgrade to a FF in the not-so-distant future. Therefor, I'm buying only EF lenses. I'm currently looking for a good midrange zoom for my T2i, that I will keep whenever I make the upgrade. While the obvious choice for FF shooters is one of the 24-70mm lenses (f/2.8, f/2.8 II, f/4), I don't really have the budget for any of those (with the possible exception of the f/4).
Does anyone have a recommendation of a good EF lens that is roughly midrange on an APS-C? A used Canon 17-40 is within my budget (I'm looking for >$800), but I've heard mixed reviews. I've heard amazing things about the EF-S 17-55, but I'm not going to drop $700 or $800 on a lens that I'm going to soon be selling.
Thanks!
R
 RS22's gear list:RS22's gear list
Canon EOS 550D Sigma 70-200mm F2.8 EX DG OS HSM
Canon EF 17-40mm f/4.0L USM Canon EOS 550D (EOS Rebel T2i / EOS Kiss X4)
DannH Contributing Member • Posts: 642
Re: Best FF lens as a midrange on an APS-C
Thanks!
R
A bit more than you wanted to spend, but the 16-35 f4 gets outstanding reviews on FF and should also perform well on crop.
Another alternative would be to pick up a used tamron 17-50 non vc. IQ is nearly as good as the Canon EF-S 17-55 at a fraction of the price.
arty H Senior Member • Posts: 1,546
I have used the 17-40 and 24-105L on crop and then later on full frame. Both are sharp across the frame. The 17-40 becomes an ultrawide on full frame, and the 24-105L is a great general purpose lens on full frame.
A choice depends on your needs, if you want a wider view, the 17-40L is sharp. With good contrast. It is light, compact, and has great AF. The 24-105L is an excellent lens. It may not be as good for events (indoors, without flash), but it gives you a slightly wide view on crop and goes pretty long. The IS is useful. It is also larger and heavier than the 17-40L.
If you want the best optics, the 24-70F2.8 will give you that...at a price in dollars, size and weight. The 24-70F4 doesn't have the range of the 24-105L, and reviews have it weaker at 50 mm, with other defects that would turn me off. There is a slightly less expensive option on a newer 24-105 variable aperture lens. Frankly, the 23-105L is fine for outside. I use a fast prime when taking photos indoors.
Your decision depends on whether you care about cost, size weight, optics, etc. None of the L zooms is flawless, but the 24-70F2.8 comes closer than the others. I don't care for the size and weight, and cost, of that lens. In terms of cost, there are frequent white box deals on the 24-105L, so it may wind up costing you less than the 17-40. Take a look at Canon price watch dot com.
Lemming51
Lemming51 Forum Pro • Posts: 15,278
cart before the horse
Buy a full frame body FIRST. Then shop for lenses for it.
The preferred midrange focal lengths for APS-C starts at 15-17mm. You're afraid that if you buy EF-S in that range you'll have an expensive lens you can't use on a future 5D/6D. Well, if you don't already have and use a 10-20ish lens with your T2i, then a 16-35L or 17-40L is going to be just as useless to you when you go full frame.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
J A C S
J A C S Forum Pro • Posts: 20,544
Probably the 16-35/4 IS as suggested above. It is new and will not be upgraded soon, and it is excellent. The 24-105 will be a better "workaround" zoom for FF (not better optically) but it can be had in a kit for a low price. If you go for the 24-105, get a "white box" lens for around $600, if you are in the US.
BAK Forum Pro • Posts: 26,020
24 - 70 Tamron f2.8 with stabilization, around $1100 US with rebate.
xy Junior Member • Posts: 39
Re: cart before the horse
I'm not sure the degree to which this impacts the OP's situation, but I right now with the 1, 5 and 6 series all due for an upgrade there's a strong argument to be made for waiting 6+ months. My next camera will be FF and I'm seriously looking at a 24-70 for my 60D. I find myself swapping in the cheap 1.8/2.8 primes a ton (24, 40, 50, 100) when the 18-200 doesn't cut it IQ-wise (which is frequently). And perhaps to your point, I'd be pairing it frequently with the 10-22.
 xy's gear list:xy's gear list
Canon EOS R5 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon RF 35mm F1.8 IS STM Macro +5 more
Rexgig0
Rexgig0 Veteran Member • Posts: 7,399
"Best" is going to vary, for different shooters, but I feel that my 24-105/4L IS is going to remain a work-horse* lens for me, for the foreseeable future, useful on APS-C, APS-H, and full-35mm-frame. Distortion is quite reasonable from 28mm to 105mm, it is at least somewhat weather-sealed, AF is fast and accurate, it has IS, and its MFD allows very close-range shooting, which can be further improved by screwing a 500D onto the filter threads. Being able to zoom to 105mm, rather than just 70mm, is a notable advantage. (For reference, I have a Nikkor 24-70/2.8G, which I use on a D700 camera.)
I disdained mid-range zooms for quite a while, but then added my 24-105L in September 2014, and then the Nikkor 24-70/2.8G in May 2015, and now feel quite differently. I have mostly used the 24-105L on APS-C and APS-H cameras, and have only use the Nikkor 24-70/2.8G on full-35mm-frame.
My EF-S 10-22mm lens complements the 24-105L quite well at the wide end. It is the only EF-S lens I have bought new, and my only other EF-S lens, bought pre-owned, was a brief experiment that I presumed I would trade-away. This lens has notably low distortion, even compared to most wide-angle L lenses. (Until I acquired 7D Mark II cameras, late last year, I could not correct distortion in-camera, and my employer requires OOC JPEGs, with no post-processing allowed.)
A recent addition is my 16-35/2.8L II. While not as trendy and sexy as the more recent 16-35/4L IS, the constant f/2.8 maximum aperture means a 7D Mark II can AF in low light at EV -3. I cannot say my 16-35/2.8L II is a most-favored lens, and I considered selling it quite soon after buying it, but it serves a purpose, starting at wide-normal, and zooming to normal, on APS-C and APS-H cameras. I can correct its distortion in-camera, when shooting with a 7D Mark II.
*I do not claim to be a "professional" photographer, as I am not in the business of photography, and my skill-set is not broadly extensive, but I do shoot some evidentiary/forensic images, primarily in low light, for very important purposes, as part of my duties as a public servant.
I wear a badge and pistol, and make evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, and PJ. I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +54 more
