1100D not recognising Blue, Yellow colors
Started Sep 28, 2015 | Discussions
aayushjoshi Forum Member • Posts: 84
Hello
I am facing a strange issue with my 1100d dslr, wherein for some reason it is unable to process colors like Blue, Yellow. I haven't done extensive testing yet to determine the full range of failure but these 2 colors were fairly obvious. The photos come out very monochromatic because its converting these 2 colors to grey or something like that. I am able to see Red, Pink and Green i think clearly in the pics.
I have tested with 2 lenses so far with the same results, it is a 3 year old camera. I have cleared all settings from the menu but that didn't fix it.
Welcome your suggestions.
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50) Leica M Monochrom (Typ 246)
RedFox88 Forum Pro • Posts: 30,738
Re: 1100D not recognising Blue, Yellow colors
You'll need to include example photos.  Plus cameras don't see colors.
OP aayushjoshi Forum Member • Posts: 84
Sure I will attach some later in the day today. Sorry about the technicalities of it but from my perspective/layman's perspective its the camera not giving the colors that it can see in the photo.
Once in a while it is able to produce a photo which is half color and half monochromatic indicating some interim issues inside.
iancrowe Senior Member • Posts: 1,477
aayushjoshi wrote:
Hello
Have you tried a different memory card? This sort of fault an be caused by a memory card starting to go bad.
Ian
Sorry guys, reviving the old thread as i got busy with too many things.
Attached is a sample click of a bright blue ball for reference.
Having said that I will try a different sd card to confirm. thanks
plain text Senior Member • Posts: 1,805
Are you shooting Jpeg or raw? If raw, how do you process? If Jpeg, what colourpace & white balance?
 plain text's gear list:plain text's gear list
Fujifilm FinePix S100fs Sony Cyber-shot DSC-R1 Canon EOS 50D Canon EOS 550D Canon EOS 600D
Lemming51
Lemming51 Forum Pro • Posts: 15,278
and picture style, and any adjustments to Saturation or Color Tone?
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Hi, I shoot jpegs. Color space tried both srgb and adobe rgb with same result. WB Shift/KT read 0, 0/+-0.
picture style tried standard and landscape with same result. No adjustments. I actually did a reset before trying again.
Yowie Wowie Senior Member • Posts: 1,166
aayushjoshi wrote:
I shoot jpegs.
What happens if you shoot raw?
 Yowie Wowie's gear list:Yowie Wowie's gear list
Canon EOS 600D Canon EOS 70D Canon EF 50mm F1.8 II Canon EF 400mm f/5.6L USM Canon Extender EF 2x III +5 more
Case_
Case_ Junior Member • Posts: 46
Judging by the full size image, there seems to be something seriously wrong with either your camera (most likely) or your processing software. That weird vertical raster should definitely not be there.
 Case_'s gear list:Case_'s gear list
Kodak EasyShare Z1085 IS Canon EOS 350D Canon EOS 600D Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 II +3 more
