PHOTO THREAD: Samsung 16mm f2.4
Started Sep 26, 2015 | Discussions
johnsigs Regular Member • Posts: 177
Re: PHOTO THREAD: Samsung 16mm f2.4
Nice capture
 johnsigs's gear list:johnsigs's gear list
Sony a9 Sony a1 OM-1 Canon EF 100mm f/2.8 Macro USM Voigtlander 12mm F5.6 Ultra Wide Heliar +16 more
Chris62 Contributing Member • Posts: 693
This lens makes a compact camera from my NX30 so I use it mainly for occasional pictures.
 Chris62's gear list:Chris62's gear list
Panasonic Lumix DMC-LX7 Samsung NX30 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +2 more
jonathanj
OP jonathanj Contributing Member • Posts: 999
What is that first picture? It's a good picture but I have no idea what it is, a rift in the space-time continuum?
 jonathanj's gear list:jonathanj's gear list
Panasonic Lumix DMC-GX85 Sony a7R III Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH +8 more
MadCypher
MadCypher Forum Member • Posts: 89
david wr wrote:
nx300 +16mm fountains abbey
Hauntingly gorgeous picture!
 MadCypher's gear list:MadCypher's gear list
Canon EOS Rebel T4i Canon EF-S 18-135mm F3.5-5.6 IS STM
So my intention to take picture of normal thing and get a picture that nobody  knows what is it
- is succesful:)
It is a fountain in my city - I could take such picture only with this lens because longer FL requires further distance and then iwe get concret fence between caemera and object so the same effect is impossible.
From the other side shorter FL can cause a camera bath in fountain water:)
There are situations that MTF sharpness are not the most important. The right FL is the key.
But IMO 16/F2,4 is quite good if it is good copy. I am very glad from mine.
Beautiful,
Where is it? (I go sometimes for trips and It could be potential place to visit :))
83cat New Member • Posts: 15
paulnelson88 wrote:
super pretty picture, great!!
 83cat's gear list:83cat's gear list
Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS Samsung NX 16mm F2.4 Pancake Samsung NX 45mm F1.8
david wr Regular Member • Posts: 412
it's fountains abbey north yorkshire near ripon. every saturday night this month it stays open late and is floodlit
not taken with a samsung
Up.
Lamborghini well know model
ChimPanzer Regular Member • Posts: 307
16mm lens distortion
I read about this lens that it has quite a notable barrel distortion. Do you correct it with in camera correction or in the post processing?
Re: 16mm lens distortion
I use RAW only so always post processing.
Using jpg or RAW + jpg is useless - if even you use RAW you can watch embededed jpg using Irfan View and from NX it is 20 full resolution jpg.
(LX7 embedded jpg has 2 MP only)
But about corrections...it can be Lightroom  does a correction automatically? I do not know.
For sure it does with LX-7 compact camera.
The same file opened in Raw Therapy had wider angle of view and more deformations.
I did not check 16/f2,4 yet in RT. Frankly speaking I do not care - todays lens nearly all are corrected in PP - mostly in MFT system.
The reasons of using 16/2,4 are small size and angle of view of course.
Look that for presentation on Tv-set purposes where aspect ratio is 16:9 we need crop the picture if we want to have Full screen filled up from 3:2 to 16:9.
(This is als cons for me about 4/3 sensor)
This picture could not be taken i.e by 30/F2 because of the object between camera and the car (not visible from this perspective of course) or this picture could be taken but in cropped car version.
I use this lens full open in 90% cases I like the results.
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
For the 16mm lens Distortion Correction is greyed out and defaults to ON for raw. LR applies the Distortion Correction camera info automatically. Some other software may not; I do know that FastStone does not. I use that sometimes to get the full uncorrected width to work with.
Other lenses may give you the option of turning it OFF in the Menu, e.g. the 30mm. With the 30mm I usually have it set to OFF in camera.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
