Single lens for GX-8
Started Sep 17, 2015 | Discussions
skybushman
skybushman Regular Member • Posts: 160
Looking for advice for a single lens (I can only afford one) for my new GX-8?.... Right now my mind is on the 20mm F1.7, however I am wondering if the 12-35 mm F2.8 might not be a better choice seeing I'll only have one lens to start with... it' just so damn expensive!
 skybushman's gear list:skybushman's gear list
Fujifilm X-T4 Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm XF 23mm F2 R WR
dmanthree
dmanthree Forum Pro • Posts: 10,309
Re: Single lens for GX-8
If you can swing it, get the 12-35. It's the most useful lens you'll ever own.
JeanPierre Martel Veteran Member • Posts: 3,304
These are two kinds of photographs; zoom guys and prime guys.
If you're a prime guy, any prime between 15mm and 25mm would be fine. If you're looking for a bright and cheap prime, the Lumix 20mm and the upcoming Lumix 15mm could be good choices.
If you're a zoom guy, there are two possibilities.
First, an entry-level zoom. There is a lot of them. Some are better (the Lumix 14-42mm II and the Lumix 14-45mm) but none are bad. The "worst" being the M.Zuiko 12-50mm (which is actually quite a good lens, but not as sharp as the other ones).
Second, you can select a pro-grade standard zoom. Some like the Lumix 12-35mm F/2,8: I for one prefer the M.Zuiko 12-40mm F/2,8 because it's amazingly sharp wide open.
Since it's simply impossible to make a bad choice, I can agree in advance to your decision.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
jeffharris
jeffharris Forum Pro • Posts: 11,411
Yep… though some walk the line.
The 15mm f1.7 has been shipping for quite a while. The 20mm is certainly a good choice. Although, I might opt for the 25mm f1.4.
The 14-42mm II is the best of the kit-zoom bunch. As an alternative, there's the 14-140mm II which is comparable to the 14-42mm II, but is a perfect one-does-it-all zoom lens.
I second the 12-40mm.
It's got a little extra range and close-focus ability allows me to skip carrying a macro lens if I'm simplifying my kit. The OP could look for a refurb (pert nigh impossible to find) or go used.
Pretty much.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
BigGG Contributing Member • Posts: 933
To items of the PL 12-35mm  DFD support and Dual Mode IS(Stabilization in BOTH the body and the lens)
GaryG
 BigGG's gear list:BigGG's gear list
Sony SLT-A77 Sony Alpha a99 Sony a77 II Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH +43 more
Bhima78 Senior Member • Posts: 2,850
12-35 would be a bit more ideal.
You can find it and other Panny lenses for good deals on ebay or digitalRev as they are shipped from either Hong Kong or Japan and the prices are MUCH lower than US Retail.
If you cannot afford it, consider sticking with the kit lens and buying one prime like the 20mm or the new 25mm f1.7.
 Bhima78's gear list:Bhima78's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario 35-100mm F2.8 OIS +12 more
Gbone Regular Member • Posts: 127
The 12-35 is moisture resistant (same as the GX8).
The 12-35 covers several focal lengths.
The 12-35 is now $200 less (just under $800) at Amazon and BH.
Hope you enjoy the 12-35.
skybushman
OP skybushman Regular Member • Posts: 160
Well thanks folks, I guess 12-35mm F2.8 seems like the overall recommended winner - Now it's time to break the bank I guess and cough up for one!
Appreciate everyone's response - thank you!:-)
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
12-35 and a c/u supplementary
yes, a lovely lens.
Add a c/u supplementary lens, I have a Marumi 200 (+5), and a willingness to use the EX TEL function which uses half your sensor for a 1.4x effect to turn the 35 long end into 50 (100 FF equiv) occasonally, and you are all set for fun in the sun or the gloom of the gloaming with excellent results.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
TheClueless
TheClueless Senior Member • Posts: 2,140
I guess it depends on what you shoot. I recently bought the GX8 and I'm alternating between the 12-35, the 15 Summilux (probably the most used for my style of shooting) and the 42.5 Nocticron as the main lenses.
I would say the 15 pairs nicely with the GX in terms of an image aspect and also a genral handling aspect, but whether you can live with the 30mm FOV and whether it's worth it is obviously up to you.
I'm not not a fan of the 20/1.7 for its image quality vs cost / size, but I just don't like the control aspect for a prime, and the FOV is a bit narrow for my liking again as a main prime. I have it, just never use it - especially on the relatively hulking GX, where the size advantage is pretty much moot.
 TheClueless's gear list:TheClueless's gear list
Leica Q2 Leica M10 Panasonic Lumix DC-G9 Sony a7R IV Sony Cyber-shot DSC-V1 +71 more
brosenz Senior Member • Posts: 1,004
LUMIX G VARIO 14-140mm is a good all around lens
dmanthree
It's a wonderful lens, but on the GX8 you're pretty much confined to e-shutter. Not a deal breaker, but just something you need to know going in.
But that 12-35 is killer...
Thank you, I am not familiar with the e-shutter concept and how it affect the use of this lens, please could you clarify, thanks
BJN
BJN Veteran Member • Posts: 5,119
For slow and noisy AF, the 20mm 1.7 shines
If you want really slow AF with via a noisy motor, the 20mm 1.7 is a perfect choice.
The price dropped $200 on the 12-32mm 2.8 if you want to consider that lens.
A better prime is the Panasonic 42.5mm f/1.7 OIS, although it's a portrait focal length.
If you can hold off for a bit before buying a "normal", the upcoming 25mm 1.7 Lumix lens should offer fast, quiet focusing.
BJ Nicholls
SLC, UT
 BJN's gear list:BJN's gear list
Panasonic Lumix DMC-GM5
dmanthree
Shutter shock. When the mechanical shutter closes/opens/closes/opens it can create some blur with certain lenses under certain conditions. So far, the only lens where I can see the effects of shutter shock is the 14-140. At its worst if can blur a pic so its useful for only small prints or web presentation.
E-shutter uses an electronic-only shutter, so there is no open/close cycle of the mechanical shutter so there no blur. But, you're limited to a smaller range of ISO and can't use a flash. Also, the "sweep" time of the electronic shutter is about 1/25 of a second, no matter what the shutter speed is, so moving objects might blur or distort. That said, e-shutter is very useful, and if you take just a little care, it works very well. You just have to shoot within its limitations.
skyak Regular Member • Posts: 119
Depends on what you are doing with the camera...but for me the 20mm makes the most sense to start because (1) you can put the camera in your pocket (2) f1.7 is more useful all around than f2.8 (3) it is cheap.
 skyak's gear list:skyak's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS Panasonic Leica Summilux DG 25mm F1.4 Panasonic 20mm F1.7 II +5 more
Lassoni Contributing Member • Posts: 512
The GX8 kit I bought came with the 14-42mm f3.5-4.5 mega ois ii , which is excellent in sharpness and everything, even offers Dual IS for the body. If you want low light, a 2.8 zoom is probably better, but is very expensive and hard for me to personally justify for myself at least. I think 2.8 might not even be wide enough.
I'm personally more interested in the panasonic's new 42.5 f1.7 prime lens, which has 1:5 (0.2x) magnification, much better magnification than the olympus 45 1.8 or even 75 1.8 (it too has OIS, so I think if not now, it should eventually support Dual IS). A prime with wide aperture works well imo, cause the DOF you get from f1.4-f1.8 prime is plenty enough for anything, whilst 2.8 might be "too much" even (5.6, when f4 or lower could suffice.. FF equivalency)
But yeah, the kit lens is really really nice. Very very very small (stupid small) compared to anything else I've ever used, yet it probably resolves better than any other panasonic kit zoom.
 Lassoni's gear list:Lassoni's gear list
Panasonic Lumix DMC-GX8 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 100-400mm F4.0-6.3 ASPH +8 more
Isabel Cutler
Isabel Cutler Forum Pro • Posts: 19,190
Re: For slow and noisy AF, the 20mm 1.7 shines - I agree....
It was my first lens for my first Micro 43 camera (e-pl1) and I never regretted the purchase.  Extremely useful lens with beautiful image quality.  Yes...it makes noise and it's sometimes slow to focus (though much fast to focus with my Panasonic GX7), but a great starter.
I did buy the 17mm after a long while for quicker autofocus, but I just don't like it as much as the 20mm - the focal length is more pleasing for my purposes.
Isabel
 Isabel Cutler's gear list:Isabel Cutler's gear list
Sony RX10 IV Canon EOS 7D Panasonic Lumix DMC-GX7 Olympus OM-D E-M10 II Sony a7 III +2 more
larsbc Forum Pro • Posts: 18,282
I've got both but...
If I had to pick only one, it'd be the 12-35/2.8. I love my 20/1.7 lens but the 12-35 is just more useful under a wider variety of situations.
For that matter, even when I only had my kit 14-45 lens and the 20/1.7, the 14-45 saw more use due to its versatility.
So get the 12-35/2.8 first and then add to it when your budget and interest allows.
