M1 vs M2 vs M3 what is the different.
Started Sep 16, 2015 | Discussions
ms18
ms18 Veteran Member • Posts: 3,530
One of my friend looking for a first mirrorless. He is planning to go with EOS M system as it has a 22mm lens with F/2. He found that older models are cheaper than new M3. He found all 3 models bundled with EF-M 22mm f/2 lens with out kit lens. He doesn't want kit lens. He is going to be 35mm shooter for sometime.
Can you elaborate the difference between these 3 versions of the body?
 ms18's gear list:ms18's gear list
Fujifilm X-T20 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +1 more
Canon EOS M3
amd Contributing Member • Posts: 604
Re: M1 vs M2 vs M3 what is the different.
I currently own both the M as well as the M2. While I checked out my brothers M3 I cannot comment in detail on it.
M2 is a bit smaller than the M, but feels a slight little bit less sturdy. The cover for all the ports is OK on the M but very flimsy on the M2
Sensor is the same, and I have not seen any difference in IQ between M and M2. While there are feature comparisons on the web I won't try to replicate, the M2 has Wifi remote control over the M, which I find very useful in some situations. (Instant sending of pics over iPad or iPhone)
The over and over debated AF performance of the M series ist actually significantly better on the M2. While it will never be an action cam, I'm OK with the M2 where the original M left me frustrated in situations like low light or macro. I have no scientific test, but personally the M3 AF did not feel more snappy or more accurate to me.
From a form factor point of view I prefer the M and M2 over the M3. I have a FF DSLR for times when needed, and as small as possible is the gap I am filling with the M2 now. If the M3 was the same form factor as the M2, and would have shown more noticeable IQ and AF improvements, I would have gone for the M3 without a doubt.
FYI: I bought the M2 after the M3 was released, and did not regret the step. Now I'm waiting for the M4 or M5 with A6000 like AF
 amd's gear list:amd's gear list
Canon EOS 7D Fujifilm X-Pro2 Canon EOS 5D Mark IV Fujifilm X-E3 Canon EF 50mm f/1.2L USM +21 more
HaroldC3
HaroldC3 Veteran Member • Posts: 3,067
M1 vs M2: M2 adds wifi, slightly smaller body, slightly faster AF, less blackout time between images
M3 is a complete redesign of the M1/M2.  New 24MP sensor, actual grip, tilt screen, slightly improved AF, optional EVF add-on
 HaroldC3's gear list:HaroldC3's gear list
Canon EOS M6 Nikon Z7 Canon EF-M 22mm f/2 STM Canon EF-M 15-45mm F3.5-6.3 IS STM Nikon Z 14-30mm F4 +3 more
nnowak Veteran Member • Posts: 9,072
9
M uses the 18MP 650D sensor
M2 uses the 18MP 700D/100D sensor
M3 uses the 24MP 750D/760D sensor
M and M2 sensor have nearly identical noise performance, but the M2 version has more on sensor AF points spread over a larger area.
M3 sensor has about a 1/3 to 2/3 of a stop advantage (at high ISOs) in noise performance over the M/M2 sensors.  M3 sensor also adds even more AF points over an area similar to M2.
Overall, all three cameras have good sensors and all are capable of producing very high quality images.
M and M2 have very similar bodies with near identical controls and construction.  The M2 is slightly smaller, has faster AF, much faster shot to shot time, and WiFi for remote shooting and image transfer.
Compared to the other two, the M3 adds a built in flash, ability to add a clip on hot shoe EFV, tilting touchscreen, faster AF with EF-M lenses, and NFC to the WiFi.
Aside from price, there is no reason to choose an M over the M2.  The M2 is either the same, or better than the M in all regards.
Choosing between an M2 vs M3 is trickier and will depend on your friends needs.  Using the EF-M 22mm lens, the M3 will focus a little faster and produce images with a little more detail and a little less noise.  However, the M2 is noticeably smaller and significantly cheaper.
If your friend wants a pocketable, high performance package, they should get the M2.  There is nothing smaller available from any manufacturer that can match the performance levels of the M2 and EF-M 22mm f2.0.  If your friend would prefer a "mini" DSLR experience, then the M3 is a better choice with the larger sculpted body and potential to add an EVF.
One other small consideration.  The M, M2, and 100D all use the same battery (LP-E12).  Spare third party batteries are readily available for next to nothing.  The M3 uses the same battery as the 750D and 760D (LP-E17).  Currently, there are no third party options for the M3 battery and original Canon units cost 10X more than the aftermarket M2 batteries.
thedanj
thedanj Contributing Member • Posts: 505
I don't have much to add to what others have said except to say that I've owned all three, and now I shoot with the M2. I was pleased to discover that it actually focuses faster than my M3 did in most instances, and I vastly prefer its color rendering.
 thedanj's gear list:thedanj's gear list
Fujifilm X-T20 Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R
I too have owned all three, but now shoot with the M2.  If I was to make a VERY broad generalization about AF speed it would be this.  With EF-M lenses, the M3 is probably faster in more circumstances.  With adapted EF lenses, the M2 is probably faster in more circumstances.
Photato
Photato Veteran Member • Posts: 3,150
Great summary nnowak.
I would add that only the M can run Magic Lantern which gives you additional features.
Also only the M and M2 can do Video at 3X lossless magnification which is an essential for wildlife shooting.
The OP question is loaded and to properly answer it would require a Table of more than 100 items
 Photato's gear list:Photato's gear list
Panasonic LX100 Canon EOS M Canon EOS M6 Canon EOS M6 II Canon EOS R10 +22 more
I forgot about the really cool 3X video zoom, which I only just recently learned about.
Correct me if I am wrong, but isn't the 3X video zoom only available on the M via magic lantern whereas is is native on the M2?
MustyMarie
MustyMarie Regular Member • Posts: 240
a small correction:
Same # of AF points-31 (M/M2), but maybe a larger area of sensor-not stated-but not significant as we mostly use the center AF pt don't we?
The AF sensitivity is the same for M/M2 as well- EV 1-18.
The M3 has 49 AF pts, but the sensitivity is LESS, EV 2-18 !
GL to OP's friend!
Kolaaa New Member • Posts: 2
I found there to be one important feature that is included on the M1 and M2, but removed on all subsequent models. This is, the ability to recognize independent left and right input channels through a stereo 3.5 inch” cable.
If you happen to have a Tentacle Sync E timecode generator, you can quickly see what I mean. Plug TS into the M1 Or M2 and the Left channel will be the audio timecode and the right will be the mic which is on the TS. Completely independent of each other, with no cross bleeding. From the M3 forward the inputs are combined. If anyone has found a workaround or magic cable or adapter to bring back discreet Left and Right input channels, please reply with any info. Thank you for reading, happy new year!
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,480
The differences between all 3 models were already explained in depth.
The M3 is the best of the 3 in all aspects. I would like to toss in M6 (1) as it is another huge step up from M3.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
R2D2 Forum Pro • Posts: 26,528
Pssst, the OP’s friend may have made his choice already.
But I do agree with your characterizations.
R2
