Sony Announces Addition of Uncompressed 14-Bit RAW Still Image Capture for New α Cameras!
Started Sep 15, 2015 | Discussions
VladimirCZ Regular Member • Posts: 271
Hi All,
just found it on http://www.sonyalpharumors.com.
The link is here.
Great news, indeed!
Vlad.
Jose Viegas
Jose Viegas Senior Member • Posts: 1,825
Re: Sony Announces Addition of Uncompressed 14-Bit RAW Still Image Capture for New α Cameras!
Interesting...
 Jose Viegas's gear list:Jose Viegas's gear list
Fujifilm X-T3 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 35mm F2 R WR Fujifilm XF 16mm F2.8 Fujifilm XF 23mm F2 R WR +7 more
OP VladimirCZ Regular Member • Posts: 271
I'm wondering if uncompressed also means lossless.
jaybr Senior Member • Posts: 1,591
Very good news.
 jaybr's gear list:jaybr's gear list
Sony a7R II Canon EF 16-35mm F4L IS USM Sony FE 55mm F1.8 Sigma 8mm F3.5 EX DG Circular Fisheye Sony FE 70-200 F4 +4 more
Jose Viegas
10
I hope they mean lossless compression, uncompressed RAW will be huge.
kronosx2 Forum Member • Posts: 71
Shows that Sony is at least listening to people's requests...no matter how long it took
From Wikipedia:
"Lossless compression is a class of data compression algorithms that allows the original data to be perfectly reconstructed from the compressed data."
So I hope that it will be a raw in it's pure form.
Jose Viegas
VladimirCZ wrote:
From Wikipedia:
Have you ever used a ZIP file? That's lossless, you don't loose data, just save space while transporting it.
mick232 Contributing Member • Posts: 964
Losses in image quality are introduced by lossy compression. If there is no compression (that is what "uncompressed" means) then there is no loss in image quality.
 mick232's gear list:mick232's gear list
Sony Alpha a99 Sony Alpha NEX-C3 Sigma 30mm F2.8 EX DN Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* Tamron SP 24-70mm F2.8 Di VC USD +19 more
sevo_stille Regular Member • Posts: 294
Yes, but why include a link to that utterly embarrassing and usually wrong rumours site, when all they do is quote Sony's own site: https://alphauniverse.com/stories/sony-announces-addition-of-uncompressed-14-bit-raw-still-image-capture-for-new---cameras/
D Cox Forum Pro • Posts: 22,945
That is good news.
Now the next thing they need to add is micro-scanning (pixel shift).
You don't save very much in file size with lossless compression -- maybe 50% at best.
You will still be able to use lossy compression or JPG if you need smaller files. It is good to have the choice.
Jose Viegas wrote:
VladimirCZ wrote:
From Wikipedia:
Sure, they could apply LZW compression to the files and get lossless compressed files. What I wanted to say is that I'd prefer unaltered raw without any compression, but LZW would be good as well, if available.
kamituel
kamituel Senior Member • Posts: 1,125
50% isn't much?
We have 14 bits per channel, and we have three channels. For A7rII that would give:
(42000000 * 14 * 3) / (8 * 1024 * 1024) =~ 210
Each uncompressed RAW file would be around 210 Megabytes in size. Compressing that by 50% is a huge difference.
I saw it on sonyalpharumors first. If I'd seen it on alphauniverse first, I'd provide their link.
Rhawi Dantas
Rhawi Dantas Contributing Member • Posts: 646
VladimirCZ wrote:
Hi All,
The link is here.
Great news, indeed!
Vlad.
That is great news!
It is a pity that my trusty A7II won't be supported.
Could anyone explain to me what is different from the A7II to the A7rII (besides BSI and stacked sensor) that does not allow this feature to be incorporated also?
I guess they know what they are doing since now I feel compelled to buy an A7rII.
Portfolio : http://dantas.photography
Streets of Helsinki : http://streetsofhelsinki.dantas.photography
Flickr : https://secure.flickr.com/photos/rhawidantas/sets/
 Rhawi Dantas's gear list:Rhawi Dantas's gear list
Sony a7R III Sony a7 III Sony FE 35mm F2.8 Carl Zeiss Planar T* 2/50 ZM Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +6 more
kamituel
Rhawi Dantas wrote:
VladimirCZ wrote:
Hi All,
The link is here.
Great news, indeed!
Vlad.
That is great news!
The SAR title is misleading (surprise!), Sony will get the firmare update for A7rII. Other cameras are not specified, but they're mentioned. The original announcement stated:
"via firmware update to additional cameras beginning with the recently introduced α7R II full-frame mirrorless model."
Jose Viegas
Rhawi Dantas wrote:
VladimirCZ wrote:
Hi All,
The link is here.
Great news, indeed!
Vlad.
That is great news!
You don't know if it will be supported or not, what's said is they'll start by the A7RII.
tommiejeep Veteran Member • Posts: 6,561
Really doesn't matter, same words.  Thanks for posting and gives me a better feeling about Sony.  Just hoping the Firmware filters down to the first four sooner than later.
Astrophotographer 10 Forum Pro • Posts: 12,829
Yes its poor wording. It means exactly that its for new models starting with A7rii and A7sii. That means models to come after that and not earlier models like A7r, A7 or A7ii. But I suspect its their lack of good English and they mean starting with the latest models and filtering down to the earlier models later like A7r A7ii A7.
Well I hope that is what they mean!
It may not work well on A7r and A7 as they don't have the latest Bionz X processor I presume which may be required to maintain a certain reasonable speed.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony a7R II Sony a7R III Sony FE 55mm F1.8 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +1 more
