Sailor Blue wrote:
I can't comment on using a wide gamut monitor but with a normal (~sRGB) monitor if you are telling windows to change the monitor profile instead of letting the color calibration software take care of that then yes, you are probably correct.
It shouldn't matter if either Windows or the Spyder software is responsible for loading the monitor profile as long as they actually do it. From my experience it's better to use the profiling software to do that (I use the dispcalGUI Profile Loader -- apparently the Windows calibration loader has wrong scaling and quantization. I'm not sure if that's true of Win10).
I use a Datacolor Spyder3Elite, and haven't had any problems at all with color management. I make no changes to Windows and what happens is that the default Windows default color profile loads first then the Spyder software starts and changes the color calibration. The screen colors show an obvious change when this occurs and suddenly colors are what they are supposed to be.
What you are seeing is the Spyder loader telling the Windows CMS about the calibration curves. But this doesn't have to be picked up by an individual program. PS, LR, most other raw converters I've tried and well-written photo viewers know that they need to translate your photo colours through the monitor profile. To quote from the dispcalGUI site:
Even non-color-managed applications will benefit from a loaded calibration because it is stored in the graphics card—it is “global”. But the calibration alone will not yield accurate colors—only fully color-managed applications will make use of display profiles and the necessary color transforms. Regrettably there are several image viewing and editing applications that only implement half-baked color management by not using the system's display profile (or any display profile at all), but an internal and often unchangeable “default” color space like sRGB, and sending output unaltered to the display after converting to that default colorspace. If the display's actual response is close to sRGB, you might get pleasing (albeit not accurate) results, but on displays which behave differently, for example wide-color-gamut displays, even mundane colors can get a strong tendency towards neon.
Let me reiterate: FastStone Image Viewer does not respect your Spyder profile; it's probably using sRGB so your Spyder profiling is wasted. As such the application can be used for a general image management (browsing, managing, copying, transferring, etc.) and it's great for that; but in my opinion it shouldn't be used for any colour-critical work (notably image editing).
I also can't comment on how the X-Rite color calibration is applied since I haven't worked with one of them. Perhaps someone like digidog, who I think has experience with both X-Rite and Datacolor calibrations, can explain how the color calibration profile is applied with the X-Rite products.
I've got the Spyder 3 and Spyder 4 hardware but use Argyll and dispcalGUI for calibration and profiling (it gives me much better results than the Datacolor software). I encourage you to try it.
