17-40L too soft for my 5Ds. What should I get instead?
Started Sep 13, 2015 | Questions
canon35l Regular Member • Posts: 115
Hi all,
I use my 17-40L for daylight shooting mostly during hikes/trips/vacation in the city and nature, but it's really too soft for my taste. Because of that I've been taking lately my 35L instead of the 17-40, but too many times the 35 is not wide enough...
The natural candidate is the 16-35 f/4L IS, however it is quite heavy and big, so I wondered if anyone has in mind other options I should consider?
I don't mind getting a prime in the wide side of this range, since the 5Ds allows plenty of cropping.However, I would still appreciate a zoom, since I couple this lens with the 70-300L when I travel light.
Note that I am interested in AF lenses only. Thanks in advance for sharing your opinion!
 canon35l's gear list:canon35l's gear list
Canon EF 35mm F1.4L USM Canon EF 85mm F1.2L II USM Canon EF 135mm F2L USM Canon EOS 5DS Canon EF 70-300mm f/4-5.6L IS USM +1 more
Canon EF 16-35mm F4L IS USM Canon EF 17-40mm f/4.0L USM Canon EOS 5DS
mclaren777
mclaren777 Regular Member • Posts: 257
Re: 17-40L too soft for my 5Ds. What should I get instead?
The 16-35mm f/4 is the most logical choice.
It's foolishly sharp!
José B
José B Forum Pro • Posts: 20,497
canon35l wrote:
Hi all,
I agree with mclaren-----the 16-35/4 L IS is awesome! Extremely sharp and I don't think it is heavy and big. The 24-105/4 L IS used to be my fave walkabout lens but now I like the 16-35 even more for my 5DS.
cheers,
José
 José B's gear list:José B's gear list
Canon EOS R6 Mark II Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5DS Sony a6500 +16 more
Don Lacy
Don Lacy Senior Member • Posts: 2,181
canon35l wrote:
Hi all,
17-40 1.05 lb
16-35 1.35 lb
It is worth every one of those extra ounces over the 17-40, the first time I open the images from the 16-35 it's sharpness was clearly evident over my 17-40 it cured me of my Zeis infatuation.
 Don Lacy's gear list:Don Lacy's gear list
Canon EOS-1D Mark III Canon EOS 6D Canon EOS 5D Mark IV Canon EOS M100 Canon EF 50mm F1.8 II +11 more
BlueRay2 Forum Pro • Posts: 14,816
+1
and if you really want to go crazy, go for the new canon 11-24 f4.0 bad-boy
salamander1 Senior Member • Posts: 1,427
what, you're joking, right?
indeed, these guys crack me up when they consider a 16-35 f4.0IS "heavy" i guess they drink their beer through straw now because beer cans are too heavy to lift
OP canon35l Regular Member • Posts: 115
Well, maybe I have a physical disability you are not aware of? maybe heavier lens means for me less photos and more pain?
I wrote that I use zoom lenses when light weight is important for me, so the weight is an important factor in my decision.
Thanks all, seems like the 16-35 IS is the way to go.
