BSI vs CMOS in low light photography
Started Sep 10, 2015 | Discussions
erotavlas Regular Member • Posts: 219
In light of Sony's introduction of full frame BSI sensor.  Is there any real world advantage to using a BSI sensor for astro work?  Are there any disadvantages to using BSI compared with CMOS?
What about on smaller sensor like Samsung APSC sensors?
 erotavlas's gear list:erotavlas's gear list
Sony Alpha NEX-5N Sony a6000 Sony a6500 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Carl Zeiss Touit 2.8/12 +3 more
Astrozoid
Astrozoid Contributing Member • Posts: 569
Re: BSI vs CMOS in low light photography
BSI sensors usually have greater quantum efficiency, so you get a higher signal-to-noise ratio and that is a good thing.
The bad thing is that it's a Sony sensor, and they are using lossy compression on the raw files, and that is not a good thing:
http://www.dpreview.com/articles/2834066212/the-raw-and-the-cooked-pulling-apart-sony-raw-compression
The other consideration for astronomy is that sometimes you have to jump through hoops to get correct flat fielding: you need superflats to deal with fringing:
https://www.astro.uni-bonn.de/theli/gui/aboutsuperflatting.html
Jerry
Trollmannx Senior Member • Posts: 4,870
Astrozoid wrote:
The back side illuminated sensor is a CMOS sensor turned backwards. So BSI = CMOS.
The lossy compression is actually not a big deal (have to search long and hard to find visible real life compression artefacts). To me the bad news is heavy spatial filtering in bulb mode leaving the Sony user with rather unsharp images compared to unfiltered images.
Have posted examples in this forum.
Jerry
