Macro Questions concerning AF extension tubes.
Started Sep 9, 2015 | Discussions
alfredo_tomato
alfredo_tomato Veteran Member • Posts: 4,382
What advantage would I see getting the Oly 60mm 2.8 over the Sigma 60mm 2.8 with AF extension tubes? I like the results from the Sigma 30mm 2.8 with extension tubes, but it is inconvenient.
I've been using the Oly 40~150 4-5.6 and extension tubes with some success. two hand held examples:
So what way should I go?
 alfredo_tomato's gear list:alfredo_tomato's gear list
Olympus PEN E-PL1s Olympus PEN E-PM2 Olympus OM-D E-M10 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +13 more
Panasonic Lumix G Macro 30mm F2.8
Dave in Wales
Dave in Wales Contributing Member • Posts: 901
Re: Macro Questions concerning AF extension tubes.
You may find this post of mine interesting.
http://e-group.uk.net/forum/showthread.php?t=38657
alfredo_tomato
OP alfredo_tomato Veteran Member • Posts: 4,382
What is the working distance at 60mm? Would a non Macro 60 sacrifice quality?
Vlad S Veteran Member • Posts: 3,766
This page at Cambrigde in Color discusses disadvantages of the extension tubes, and has a calculator for magnification and focusing distance. For the calculator you will need the native magnification of the lens, which you can find in the technical specs on the manufacturer's web site, and in the lens database here at DPReview.
Vlad
 Vlad S's gear list:Vlad S's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +2 more
OzRay
OzRay Forum Pro • Posts: 19,428
If your happy with the quality of the Sigma, then I don't think you'll gain much with the Olympus. With macro, you're always pretty much going to have to physically move in and out for focus, so the only real advantage of the Olympus is that you'll have AF for general shooting.
Thoughts, Musings, Ideas and Images from South Gippsland
http://australianimage.com.au/wordpress/
alfredo_tomato
It seems the big disadvantage of extension tubes is having to take the lens off to shoot other than Macro.
I am not that interested in extreme closeups. I seem to be more interested in using macro for composition.
tt321
tt321 Forum Pro • Posts: 13,854
AF extension tubes also allow AF, but you are right AF is less useful in macro, unless it's the new AF bracketing feature you are using.
I'd think that AF in macro would work very well with the touch-screen focus point selection.
alfredo_tomato
Until recently, I used manual lenses with extension tubes and/or reverse rings.  One thing I liked about the reverse ring was that the adaptor worked like a lens hood. A swap between macro and standard was quick..
I do like the lower price of the Sigma 60, but the Oly appears to be an excellent portrait lens too.
alfredo_tomato
Touch focus is tough with my fat fingers.
The most fundamental disadvantage is the inferior image quality with extension tubes compare to true macro lenses.
Vlad
OzRay
Are we talking about the Sigma 60mm f2.8 for m4/3 or a Sigma macro lens? If the former, then I'd recommend the Olympus without hesitation.
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
Vlad
That depends on a lens used with macro tubes, doesn't it?
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
Why buy Sigma 60 if you have Oly 40-150?
What advantage do you expect from Sigma 60mm compared to Oly 40-150 set at 60mm with the same set of extension rings?
Vlad
I doubt it. The lens optical corrections are designed for a limited range of operating conditions. When you take a lens outside of that envelope by forcing it to focus closer than designed, I would expect all sorts of aberrations crop up. That's just my guess though, I'd love to hear from people more experienced with extension tubes.
Vlad
Certainly, it's a budget solution, and you also give up infinity focus, but some lenses are really good and still produce good macro results. Here were my tests with my Sigma 60mm + extension tubes:
http://www.dpreview.com/forums/post/56005421
Obviously not elaborate tests, but the results look good to me.  The only issue to watch out for--and it's still the case for non-macro shots, is purple fringing.  I have to fix that with the Sigma lens on E-M1 even for normal shots, depending on contrast.
JimLindner
JimLindner Senior Member • Posts: 1,308
Well to muddy the waters, you might try diopters. Here is a quick shot with a +6 diopter on my 75mm to give you and idea of magnification.
+6 diopter
Diopters are more convenient since they mount on front of the lens.
They can add aberrations or distortions since you are putting another piece of glass in front of lens.
Generally speaking diopters magnify more on telephoto lens and tubes more on wider lenses.
They are relatively inexpensive.
They can be stacked for different combinations, the above was a +5 and +1 stacked.
Regards Jim
We All Need Water!
 JimLindner's gear list:JimLindner's gear list
Panasonic Lumix DMC-G3 Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 75mm F1.8 Adobe Photoshop Lightroom 5 +1 more
alfredo_tomato
No I was referring to the Sigma 60mm 2.8 Art with extension tubes.
alfredo_tomato
OK, that is another option to explore. Thanks.
OzRay
OK. Then in that case, I would most definitely recommend the Olympus 60mm. The difference between regular and macro lenses is, other than they are designed to natively provide close focus functionality, they produce a flat image field across the sensing medium, so that there's no curvature happening if you are photographing such things as coins, stamps etc. The resolving power of the Olympus macro lens is also quite exceptional for such a low priced macro lens.
