Canon 50mm f1.4 Focus Ring
Started Sep 9, 2015 | Questions
TheElleBell New Member • Posts: 1
I was shooting a wedding the other weekend and my 50mm 1.4 took a small fall on the grass. Ever since the focus ring won't work. It's not stuck though, which seems to be the only problem I've read about from others.
The external ring moves normally however: Nothing happens with the focus internally. It's just stuck at infinity.
I brought it to my local Canon shop and they said it would be a flat rate of $124. I've had the lens for a few years now.
Would you suggest I try to disassemble the focus ring and see if it's an obvious problem? loose screw ect.
Thank you!
