What's your PC specs for your a7RII raw files?
Started Sep 8, 2015 | Discussions
JLim22 Contributing Member • Posts: 501
I'm just curious what people are using to edit their a7RII raw files.
I'm using a i5 8gb ram ssd laptop and it was running so smoothly with my previous Canon cameras, but it seems pretty slow for the a7RII files. In LR, it literally takes couple of seconds to load each image. This is probably one of the reason why some might not like the large 42mp files.
C1 seems to run faster than LR, but after playing with it for couple of weeks, I decided to stay with LR.
I'm going to try to convince my wife that I need a new laptop...  haha
Please let me know what you're using so that I can gauge what I need. Thx!
pc or mac:
processor:
ram:
hd or ssd:
raw file performance with LR:
 JLim22's gear list:JLim22's gear list
Sony a7R II Sony FE 55mm F1.8 Sony FE 28mm F2 Sony FE 35mm F1.4 Zeiss Batis 25mm F2 +2 more
Sony a7R
bravomail Regular Member • Posts: 424
Re: What's your PC specs for your a7RII raw files?
I'm going to disappoint you from the get-go - don't use laptops if you are after performance.
My suggestion - make DIY desktop PC - there are plenty of guides.
Get i7 class CPU - it has hyperthreading which is beneficial. Get non-kit cooler.
Also get decent video card - although not sure which kind is best supported for GPU acceleration. DxO doesn't seem to benefit from GPU. CaptureOne seems to get better. LR - is widely dismissed for Sony RAWs. Check newegg for cards in 150-200 range to get the idea. GF750Ti or higher with 4K support recommended.
RAM - 8GB is enough for basic RAW processing. But if you use offline Photoshop or similar software - they like RAM, the more the merrier. 16GB is recommended. 32 is overkill.
Hard disk - get regular and/or external USB 1-8TB for storage and backups and internal SSD 500GB (480) for OS and temp storage of RAWs (while you process them). Samsung Pro seems to be fastest (but not cheapest), and Crucial seems to be cheapest.
Get decent monitor - 4K 27" IPS LED recommended (Dell has one for ~500).
 bravomail's gear list:bravomail's gear list
Sony a6000 Sony E 18-200mm F3.5-6.3 OSS Sony E 35mm F1.8 OSS Sigma 60mm F2.8 DN Art
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 8,263
JLim22 wrote:
pc or mac:
pc
processor:
i7-4810mq
ram:
32GB
hd or ssd:
both
not using LR
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony a7R II Sony FE 55mm F1.8 Phase One Capture One Pro +25 more
sevo_stille Regular Member • Posts: 294
That is not really a matter of the Sony files, but of Lightroom 6/CC - which is not happy with a mere 8GB of RAM any more. I only use that bloatware for past projects, and have otherwise moved to C1.
Promit Senior Member • Posts: 2,083
I'm probably not a good example, as this PC was built for things far more difficult than simply photo editing. But here we go:
PC, Windows 8 until 10 seems stable enough. Core i7-5930k (hex-core with HT) at 3.5 GHz. 32 GB memory (half filled, will move to 64 soon). Old dual AMD HD 7970s which hopefully will change over to NV 980s soon. I use a RAID 0 array of three WD Black 4 TB drives for my photos, and an SSD RAID 0 for my video editing.
It is more than adequate I'm using Dell UltraSharp monitors, most recently the U2715H (sRGB gamut model), calibrated with the X-Rite i1.
 Promit's gear list:Promit's gear list
Sony Cyber-shot DSC-RX10 Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 16-35mm F4L IS USM Canon RF 35mm F1.8 IS STM Macro +2 more
Boosted240
Boosted240 Regular Member • Posts: 304
Custom built PC (that's been my main hobby since childhood)
Intel core i7 4770k @ 4.3ghz on water
16GB DDR3
A pair of Samsung Evo SSDs in RAID 0
Nvidia GTX 780 TI w/32" Acer 4k IPS monitor and 27" HP 1440p monitor
I keep my Lightroom catalog on the PC (SSDs) but my RAW files are stored on my Qnap 12TB NAS. As for the performance, I can't tell a difference editing images from the A7II, A7RII, or much else. Import speed is slower due to being on a NAS (only doing about 120MBps copy speed) but everything else feels just fine.
I agree with others. A desktop w/large monitor is the way to go, not a laptop.
 Boosted240's gear list:Boosted240's gear list
Sony FE 55mm F1.8 Sony a7R II Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Zeiss Batis 85mm F1.8 Adobe Photoshop CS6 +5 more
Stflbn Veteran Member • Posts: 3,729
I mainly run Capture One anymore.   Recently moved to a self built PC over a new 27" iMac.  Previous iMac was 5 years old.    The difference in a good Gaming video card over the iMac's mobile video card is staggering when exporting processed images.
Saved about $1000 below the current iMac and the PC is much faster,  though you have to be willing to deal with more fan noise than the iMac.
AMD 8350 4Ghz overclocked to 4.3Ghz
GeForce 960 G1 4GB video card -  also overclocked
16GB Ram
256GB SSD HD
3TB SATA HD
LG 27MB85R-B
Sony A7ii
Sony 55 FE 1.8 | 28 FE f2. | 70-200G FE F4 | 70-400G ~ LA-EA4
Rokinon 135 f2 | Kiron 105 Macro
Helios 40-2 | Tair 11a | Helios 44-4 | Min MC 50 1.4
http://stufflebeanphotography.com
 Stflbn's gear list:Stflbn's gear list
Sony RX100 V Sony a6500 Sony a7 III Sony FE 55mm F1.8 Sony FE 28mm F2 +9 more
JeffGo Contributing Member • Posts: 840
Homebuilt PC.
Current: 2nd Gen Core I7-875K @ 2.93GHz, Asus MB, 16GB, 256GB Samsung SSD for OS (Win10) - only running @ SATA II speed, data stored on 3 HDDs mostly SATA II, AMD R9 280, NEC PA272W 2560x1440 + Dell U2410 1920x1200. LR6 CC. I would not call this speedy on loading A7rII  or even A7r.
Planned:
6th Gen I7 (Sky Lake) probably I7-6700 (TBD), Asus or Asrock (?) MB, 32GB, 500-512GB Samsung SSD (M.2), same HDDs, video, monitors. Catalog moved to SSD - although I don't believe that's a perf issue for me.
 JeffGo's gear list:JeffGo's gear list
Panasonic Lumix DMC-TS20 Sony RX100 III Sony Alpha NEX-7 Sony a7R II Sony E 18-55mm F3.5-5.6 OSS +12 more
vett93
vett93 Veteran Member • Posts: 5,329
Mac/Xeon processor/64GB RAM/SSD+HDD/2 graphic cards
What do photo editing computer and game computer have in common? They both need to be fast to get your creative juice running.
Sony A7II | A6000 | RX-10
from 12mm to 500mm
 vett93's gear list:vett93's gear list
Sony a9 Sony a7R III Sony a6500 Apple iPhone 11 Pro
Abrak Veteran Member • Posts: 4,204
Re: Mac/Xeon processor/64GB RAM/SSD+HDD/2 graphic cards
I upgraded my computer when I got the A7rii for exactly the reason you mention. I dont really think any laptop will cut it (although I am a pretty heavy PS user.) My laptop was a Razer Blade gaming laptop with i7, 2gb video card and 1.5TB of SSDs but only 8gb of ram.
So I replaced my laptop with a desktop ...
processor i4790k
Video card Nvidia 960 2GB (I dont do video)
Ram 32GB (overkill but PS loves ram)
Hard disks
1 x 480gb pcie flash (c drive)
2 x 1TB SSDs
1 x 2TB hard drive
Total cost about the same new as my old gaming laptop was when new.
Performance increase when using this PS action listed here http://www.gavtrain.com/?p=1509
...went from 1min 20 seconds to 19 seconds....
My computer is probably now well over the top but I wanted to get something that would last as I am not very tech literate for upgrading...
Robert98 Regular Member • Posts: 189
Not felt the urge to upgrade my MacBook Pro Retina Mid 2012, 2.6Ghz i7, 16GB RAM, GT650M 1GB, 512GB SSD, running Yosemite.
Using C1Pro, seems to run at about the same speed as LR did with my old Canon 18MP images. ie occasional pauses as I load the next image, but no stuttering whilst actually working on images.
 Robert98's gear list:Robert98's gear list
Sony RX100 VII Sony a7R III Sony a7R IV Sony FE 55mm F1.8 Sony FE 70-200 F4 +3 more
vett93
processor i4790k
This processor is fine. You don't really need a Xeon processor for photo editing.
I don't think this is overkill. I ran my Mac Pro with 16GB first but it was quite slow after I used LR and other plug-ins for some time. After upgrading to 64GB, it does not slow down anymore. I think 32GB is just barely enough.
Hard disks
2 x 1TB SSDs
1 x 2TB hard drive
I am trying to keep my cost down. So I would use one PCIe flash drive as working drive. Then moving the finished images to HDs. I have only 1 catalog in LR but it runs across several drives. So it is easy to move files around.
I think your computer is fine. The weakest link in your hardware is the size of the RAM. But if you run Windows, you will need to clean it up regularly.
from 12mm to 500mm
(unknown member) Senior Member • Posts: 2,961
4-year old iMac (i7 processor), 12 GB memory, loads RAW files into C1 extremely smooth, (less than a second) even from external drive. If I anticipate heavy editing, open and save, I load the raws onto internal SSD.
SSD is probably the biggest performance boost you can get (for OS and applications).
I find that Macs need substantially more memory than PCs for most tasks. My rule of thumb is to just add 8-16 GB on the Mac side for comparable performance, and really you're just better off maxing it out right off the bat. My old MBP had to be retired as the maxed out 8 GB became insufficient for basic work tasks. My current rMBP at 16 is just adequate memory-wise, whereas my older 16 GB PCs are struggling with other things (mainly CPU) first. I don't know what it is about OSX that is consuming so much, it's not as if Windows is lightweight. I don't think it's extra stuff running on the system, but rather the system itself (so all apps across the board take a lot more memory).
It's a pity that Apple charges so much for memory upgrades, and also unfortunate that Apple doesn't have a product line between laptops (iMacs included in that category) and pro workstations with stuff I don't have much use for (FireGL, ECC memory, dual Xeon are all cool but not really that useful for my work).
Have you heard of running MacOSX on a PC? macosx86 is the project name, I think.
Sure but it's a hassle and not completely stable. My Macs are for work and that frequently includes doing things like running OSX betas. Can't rely on anything but an actual Apple machine for that sort of thing. I have a high spec rMBP and a very high spec PC and I split the work between the two as needed.
juvx
juvx Senior Member • Posts: 1,536
Used to own a Custom PC company.
Used to own my own custom PC building company a few years ago.. That being said, this is what i use right now....
I'm mainly using a 2013 15inch Macbook pro retina and it does just fine, due to its dedicated nvidia video card and fast SSD. Excellent computer. So I would recommend macbook pro retina as my number one choice for you for PHOTO editing. The screen is a PLEASURE to edit on. I often edit my photos while in bed or watching TV on the couch.
I also have a powerful Desktop gaming PC I've built myself. with an overclocked and watercooled i7 4770k, 32 GB ram, and nvidia gtx 980, and 512GB SSD. To be honest though, this is overkill for any photo editing needs. Also have a home build NAS running freeNAS with 16TB of space in RAID 6. (z2)
The number one priority is whatever you opt for, make sure it has a SSD on it. As big as possible to edit on and at least 8 GB ram.
Photo editing is not as demanding as some people in the thread make it out to be.. its video editing that needs the real Juice... So if you're also planning to edit 4k video then go for a high end system, if not just stick with a mid range system or any macbook pro retina with a dedicated video card.
Message me if you need me configure a video editing rig.
 juvx's gear list:juvx's gear list
Sony a7R II Sony a6500 Sony a9 Sony E PZ 18-105mm F4 G OSS Sony FE 35mm F1.4 +4 more
rogerjosem
MOD rogerjosem Veteran Member • Posts: 3,293
I am not sure about this, actually I see my i5 4GB RAMd MBA 13" and i5 8GB RAMd MBA 11" performing pretty much equally when handling A7 and A7r files in LR, and both just a tad less snappy than my high-spec´d rMBP 15" (it is a pleasure seeing photos on a retina screen). They all are way faster and more comfortable for me than my Surface Pro or my wife´s core i7 PC (the Macbook trackpads are magical enough to make me stop bother editing files in LR on PCs).
 rogerjosem's gear list:rogerjosem's gear list
Sony a7R III Fujifilm GFX 100S Zeiss Otus 55mm F1.4 Zeiss Otus 85mm F1.4 Sigma 105mm F1.4 DG HSM Art +10 more
texascbx Contributing Member • Posts: 650
I have a Intel 4670k running at 4.5Ghz with 16Gb of memory and a Samsung 256Gb SSD. It opens RAW files from the A7RII with Photo Ninja with no problem.
 texascbx's gear list:texascbx's gear list
Sony a7R II Sony a6300 Sony E 18-55mm F3.5-5.6 OSS Tamron SP 70-300mm F/4-5.6 Di USD Sony FE 55mm F1.8 +5 more
8 GB RAM are plenty on my iMac. When I added 4 to make it 12 GB I did not notice any difference in Photoshop. Unless you are opening dozens of addition layers onto your RAW, it really should make no difference.
The bottle neck is more likely the read/write speed to your hard drive and the internal bus.
