E-M5 Mark II vs E-M1
Started Sep 8, 2015 | Discussions
mrboh New Member • Posts: 9
I recently purchased the E-M5 Mark II + 12-40mm kit thanks to a $250 cashback offer that Olympus has had here in Australia. Individually the two are fantastic - I love the immaculate build quality of both as well as the control layout of the body. However, the lens feels a bit too heavy for the body when they are mated together. I had a quick play with an E-M1 and it feels like, with the bigger grip, it would be more of a natural fit for the lens. So I am wondering about swapping the E-M5 II body for the E-M1. The E-M1 is obviously a lot older now - is it still worth investing in?
The camera is intended for travelling and my ultimate plan is (was?) to get the 75-300mm for wildlife shooting/other longer range stuff. However, from the specs it looks like this is even heavier than the 12-40mm and might be even more unbalanced with the smaller E-M5 II body.
Olympus 12-40mm F2.8 Pro Olympus E-M1 Olympus E-M5 II Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II
Skeeterbytes Forum Pro • Posts: 23,182
Re: E-M5 Mark II vs E-M1
You sound like a candidate for the grip, which can be had without the battery pack if desired (HLD8G). Having both E-M1 and E-M5 (the original) I can verify the M1 handles larger lenses much more easily. I'm perfectly comfortable using it with the 40-150/2.8. For larger 4/3 lenses (up to 3.6 pounds) I add the grip. The E-M5 can be shot with bigger, heavier lenses so long as I support the rig with the lens to keep thing balanced, but for one-handed shooting I prefer smaller, lighter lenses.
Good luck,
Rick
Bialykot Forum Member • Posts: 70
Yes, the add-on grip is worthwhile for the EM5 II when using larger lenses.  It's still not as comfy as the EM1, but perfectly usable.  I'd personally hang on for the EM1 Mark II though if you intend moving that way.
captura Forum Pro • Posts: 27,478
Keep the lighter E-M5II and get the Pana. 12-35 lens which weighs only 305 gm. (instead of the 12-40 which weighs 382 gm.)
 captura's gear list:captura's gear list
Sony Alpha NEX-7 Canon EOS Rebel SL1 Sony a7 Olympus OM-D E-M10 Canon EF 85mm F1.8 USM +3 more
(unknown member) Veteran Member • Posts: 3,010
I use that lens on my E-PM2 a lot. My camera barely has a grip. I hold the lens with my left hand palm up cradling the lens. Just ignore the unbalance and save yourself a lot of money. You won't really notice it after a while.
OP mrboh New Member • Posts: 9
Thanks for your input. Yes, it certainly looks like the grip is an option. There appear to be a few cheaper alternatives to the official Olympus grip so I might give one of them a try. If you were buying a camera now to work with the 12-40mm etc, would you consider the E-M1 as an option or just go straight to the E-M5 II plus grip?
Adamant Contributing Member • Posts: 797
I own an E-M1 and an E-M5 II.  The ergonomics of the E-M1 cannot be topped.  It may be the most comfortable, grippable camera ever made.  Fits like a glove.
A gripped E-M5 II is no slouch and is quite comfortable, but it's no E-M1.  For pure ergonomics, go for the E-M1.
berni29 Veteran Member • Posts: 3,119
Hi
Great as the EM1 is, the EM5 mkII has the ability to shoot low speed burst with 0sec antishock. For that reason alone it is a better option. As long as you buy the grip that is.
Also further down the line, the EM5 mkII may get some of the EM10 mkII features via a firmware upgrade.
Alo the EM1 mkII will be out at some point and will probably blow all our socks off.
Berni29
EM-10, GM1 + Pana 12-32mm, 35-100mm f2.8, 20mm f1.7, Voight 17.5mm f0.95, Oly 45mm, 50mm F2 macro, (prev EM5, GH1, E30, E510, E1, E300, LX3)
 berni29's gear list:berni29's gear list
Ricoh GR II Olympus E-M1 Sony a7R II Olympus OM-D E-M10 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +13 more
Based on feature sets the E-M5II brings more to the table, with the exception of CAF response and focusing with four-thirds lenses. Since I've never handled the new model I can't compare with the E-M1, but have to say I really like the M1, which is the best digital camera I've used.
Unless you actively dislike the M5II or plan on getting even larger lenses and perhaps four-thirds lenses, I'd probably get the grip and stand pat. Luckily, both are very good cameras.
Rick
Yes the EM1 is fantastic to hold.  I recently purchased the EM5 II (plus the 12-40 pro lens) and added the grip later.
It was a split decision between the EM1 and EM5 II, but I reckon that the EM5 II should get some decent firmware updates in the next few months (e.g. focus stacking that the 10 II has now), which just swung the balance for me.
I will probably trade the 5 II in for the EM1 II when it becomes available as it (the current EM1) is soooooo good in terms of handling.
dulynoted
dulynoted Senior Member • Posts: 2,267
Same here. About to get an em5 mark II but will probably trade it for the em1 mark II next year since i expect that to have 4k capability.
happysnapper64 Veteran Member • Posts: 5,421
I have recently purchased a second hand E-M1 with battery grip + 12-40 f/2.8 & it handles superbly with & without the grip.
lee uk.
There are old pilots, & there are bold pilots, but there are no old bold pilots.
"I would never want to join a club that would have me as a member" Groucho Marx.
 happysnapper64's gear list:happysnapper64's gear list
Canon EOS 5D Mark II Canon EOS 7D Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM +6 more
abe4652 Veteran Member • Posts: 3,147
The question is though, and this is now a serious one, will they have fixed the design error with the rear knob, where it stops working?
Cane Veteran Member • Posts: 6,900
I would think needing to buy an add on grip is the biggest design flaw? But really, how important is holding a camera?
Gregm61 Forum Pro • Posts: 15,899
berni29 wrote:
Hi
As a prospective buyer not yet in the system, I most likely would not pick an E-M1 today over the E-M5II, unless I was a prior four-thirds user with a set of the Zuiko DSLR glass.
As an E-M1 owner over the past almost two years, I would not replace it with an E-M5II as I fully expect within a year or so the new high-end model with have all new features, by then most likely even updated versions, probably with more resolution and still with features the E-M5 models never had, or will have. It makes sense they'd hash out any issues with new features on the lower-end models.
It also sounds like the E-M1 is about to get yet another update in October with new features. Who knows, that may even include low speed burst with 0 anti-shock.
"There's shadows in life, baby.." Jack Horner- Boogie Nights
WNeuetc Regular Member • Posts: 378
Good luck,
Rick
I can second the HLD-8G grip recommendation.  I've been shooting an E-M1 for nearly two years now, mainly using my Oly Pro zoom lineup (12-40 F2.8, 40-150 F2.8 and 7-14 F2.8) and found the E-M1 well matched (though with the 40-150 I leave the tripod mount on as a 'hand grip').  I just picked up the E-M5 II and even though I found it reasonably well balanced with the 12-40, I can understand that others may find it cumbersome.  And certainly the 7-14, to say nothing of the 40-150 make for an awkward setup.
With the HLD-8G grip the E-M5 II is easily a match for the E-M1 in the balance and comfort department.   In fact, with the grip, the E-M5 is actually a bit more 'grab-able' than the E-M1 (in fact may be too substantial for some smaller hands).  The main downside of the grip, is the need to remove it to change batteries.  Not a big deal, but it is a bit of a pain, given the pretty limited battery life of the E-M5 (and E-M1) cameras.
Wes Neuenschwander
Seattle, WA USA
 WNeuetc's gear list:WNeuetc's gear list
Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +2 more
dulynoted
I was thinking about the jb designs em5 mark II add on grip when i get mine. Seems very well made and allows access to the battery compartment.
I'd basically decided to go with this thread's advice and stick with the E-M5 II + purchase the Fotodiox grip. But now the v4.0 firmware news has broken and I'm wondering about the E-M1 again! It looks like, come November, most of the features will be similar. Major differences appear to be:
  • E-M1 will have focus stacking (and still have the built-in grip!)
  • E-M5 II will have somewhat better IBIS, high resolution mode and a few more options for movies
Is that a reasonable summary? Has this changed anybody's opinion about getting one over the other?
E-M1 has better CAF and the ability to use four-thirds lenses, if those are meaningful capabilities.
Rick
Zephir 750 Senior Member • Posts: 2,039
Good question.
 Zephir 750's gear list:Zephir 750's gear list
Canon EOS 50D Leica M8.2 Olympus E-1 Olympus E-3 Leica M9-P +19 more
