Panasonic 14-140mm
Started Sep 1, 2015 | Questions
davidgalavan Junior Member • Posts: 32
Panasonic 14-140mm
Hi, this may not be the place to raise this matter, but I hope someone may respond or direct me to a more appropriate thread.
My question is relating to the Pan 14-140 on amazon.uk showing for sale at £389. This is fine except it also shows a newer model for £523. I have checked the tech specs for both and they seem exactly the same.
Can somebody explain the difference in price to me, if any? Both are f3.5-5.6.
I am researching this lens and very close to purchasing it. Thank you in advance.
 davidgalavan's gear list:davidgalavan's gear list
Panasonic Lumix DMC-GX8 Canon EOS 80D Panasonic 12-35mm F2.8 Sigma 150-600mm F5-6.3 | C Canon EF-S 18-135mm F3.5-5.6 IS USM +1 more
Panasonic Lumix G 14mm F2.5 II ASPH
pannumon Veteran Member • Posts: 4,130
Re: Panasonic 14-140mm
The older model should be f/4.0 - f/5.8. They may have wrong specs.
The older (f4.0 - f/5.8) has some gray color. The newer version seems to be cheaper, although considered optically better, faster (aperture-wise) and lighter. Some people may have reported some problems with the newer lens (OIS?), and I am not sure does it have "stepless" aperture control like the older version. This is useful for video.
To your question, it seems to be the same lens, but I cannot answer your question (and cannot withdraw this useless post).
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
hearingdouble Regular Member • Posts: 118
I've had a look on Amazon and the cheaper one is indeed the f3.5.  They may be releasing a re-skinned 'matte' version soon, hence the price drop.
An excellent price for the lens.  It's a great kit lens.
brentbrent Veteran Member • Posts: 5,766
Here is a link to the original and v.II lenses on B&H: http://www.bhphotovideo.com/c/search?Ntt=panasonic+14-140&N=0
v.II is considerably lighter and more expensive (at B&H), and somewhat smaller and faster at 14mm. It has the newer IOS system and takes 58mm filter instead of 62mm. I think the consensus is that v.II is considerably better for still photography, but may exhibit shutter shock at certain mechanical shutter speeds (potentially 1/60 to 1/250???). Also, some report that it can exhibit jitters in handheld video.
I like my v.II a lot for stills.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Terminal Boy Senior Member • Posts: 1,292
They re skinned the 14-140 MK2 and 14-42 MK2 to match the G7 and GX8. 45-150 got the same treatment I think.
 Terminal Boy's gear list:Terminal Boy's gear list
Panasonic Lumix DMC-GM5 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +2 more
