The Samsung BIG lens TEST - performance at 16mm
Started Sep 1, 2015 | Discussions
Matt Everglade Regular Member • Posts: 200
As introduced by ChimPanzer, here I'd like you to guess which Samsung lens belongs to which image.
I shot a "wall" with several meters distance.
16mm, F4 (F4.5 for the 12-24mm) and F11, ISO100 on a tripod with 2 sec self-release. WB corrected in Lightroom to be equal on all photos. Actually those images were shot on two different days due to (non-)availability of the lenses.
Center - Open the file at original size for 1:1 view.
Midframe - Open the file at original size for 1:1 view.
Corner - Open the file at original size for 1:1 view.
It is your turn to guess which Samsung lenses I used - left to right.
I will tell you how many answers you got right.
Matt
Visit my blog about photography and Samsung NX:
http://www.matteverglade.com
 Matt Everglade's gear list:Matt Everglade's gear list
Samsung NX1000 Samsung NX30 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 60mm F2.8 Macro ED OIS SSA +7 more
ChuckTa Senior Member • Posts: 1,492
Re: The Samsung BIG lens TEST - performance at 16mm
Just a wild guess, and the different lighting made it more difficult.
Left to right
1. 12-24
2. 16-50 S
3. 16-50 pz (this one I am more sure due to edge softness)
4. 16 f2.4
 ChuckTa's gear list:ChuckTa's gear list
Sony a7 Samsung NX500 Fujifilm X-T20 Panasonic Lumix DC-GX9 Panasonic Lumix DC-GF10 (GF90) +8 more
ChimPanzer Regular Member • Posts: 307
Hi Matt,
Thanks for testing! I can see quite some diffraction at F11 on the pictures that impacts most of the pictures, except for Lens 3. I did not expect it to happen so notably on most of the lenses. So it is quite useful to remember to avoid F11 and higher stops.
Here are my guesses:
Lens1 16mm
Lens2 16-50mm PZ
Lens3 S 16-50 2.0-2.8
Lens4 12-24mm
ChimPANZER
zipcode Regular Member • Posts: 312
1. 16-50 S
2. 12-24
3. 16-50 pz
4. 16 f2.4
OP Matt Everglade Regular Member • Posts: 200
Must have been too easy, directly a 4 out of 4, congratulations.
I am sorry, none is correct. Try again!
Well done, 2 out of 4 are correct.
OMG, remind me to buy the lottery tomorrow
It wasn't easy, luck was required. But my 12-24 tends to give darker images, that's the first. And I got 3 for the softer corner of PZ kit at f4.5. Guess the other two. But assume S lens sharper than 16mm pancake.
It is good that the S lens was among. However I a bit disappointed at is quality, especially the corner performance with lots of croma and fuzziness.
The 16mm seems a better lens than I expected. Was a useful test. Thanks Matt!
ChimPANZER
Yes, the 12-24 seems to be a really good lens. I thought the chroma aberration could not have been from the S lens.
Jefftan Veteran Member • Posts: 3,501
I am sorry why is there 8 frame for 4 lens
if it the same lens from up to down?
Top is F4, bottom at F11.
surprising is how good the 16-50 pz is compare to 16-50 S
a little more sharpening of the 16-50 pz and they would look very similar.  A great advantage of Samsung camera and also Panasonic camera (12-32mm) is the good kit lens. Fuji camera also provide good kit lens but is large and not small collapse type
Not everyone would want the extra cost and bulk of extra good lens.  Smart people would not buy Sony just for their junk kit lens
mordor_74 Contributing Member • Posts: 622
So the choice for the landscapelovers is between 12-24 and 16? Lucky ones, they are pretty affordable!
 mordor_74's gear list:mordor_74's gear list
Sony Cyber-shot DSC-HX5 Canon EOS Rebel SL1 Samsung NX1100 Samsung NX 30mm F2 Pancake Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +7 more
A full frame 12 is much wider than an 12 at APS-C. So landsape tends to be shot with FF in most of the cases.
I see your point but i dont think that everybody is willing to spent 1300€ (the cheapest FF body if i am correct: D610) for a body. Also consider that many people are starting do wide landscape "the other way" = stiching more pictures and i must say with good result andfar beyond the capacity of a 12mm + FF.
THe 12-24mm is a wonderful lens for landscape. I seldom needed a wider angle of view. I think no other system has a better wide-angle option in this price range.
Ok, the 12-24 prices are currently down as any other Samsung lens prices as well. It seems many retailers clear their stocks due to Samsung withdrawing from several markets.
NX1 is appr 1600 EUR + 350 EUR for the 12-24, + you may bet 50-250 for 200 EUR
So you end up spending 2200 EUR roughly for the gear and then you have the broadest coverage fom wide angle to tele.
This you need to compare to a Full frame price with a lens that covers 18-300 to get the same .
The important difference comes when someone wants to go even wider. On FF you can, on APS-C not really.
