Blurred images with 70-200 f4IS..
Started Aug 31, 2015 | Discussions
anil22 Regular Member • Posts: 296
I was shooting this with a Canon 70-200 f4IS on a 5DII. As you can probably tell from the EXIF, the shutter speeds were pretty fast. I must have shot close to 30-50 images, and most of them are blurred. The lens seems to work well otherwise, so I am puzzled why this happened. Any ideas?
Thanks..
Anil.
Canon EF 70-200mm F4L IS USM Canon EOS 5D Mark II
J A C S
J A C S Forum Pro • Posts: 20,544
Re: Blurred images with 70-200 f4IS..
Is that restricted to specific FLs? Turn the IS off and try with fast enough speed, handheld.
I see a clear upside-down blur. Very unlikely to be some kind of shake at that speed unless it is a defective IS. It might be decentered. But then it should be consistently soft at the same shutter FL and aperture...
happysnapper64 Veteran Member • Posts: 5,421
Are you sure the IS is in fact working? Mine makes quite a noise when the IS kicks in, which I was told by members here that it was usual. Worth checking.
lee uk.
There are old pilots, & there are bold pilots, but there are no old bold pilots.
"I would never want to join a club that would have me as a member" Groucho Marx.
 happysnapper64's gear list:happysnapper64's gear list
Canon EOS 5D Mark II Canon EOS 7D Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM +6 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Wow--that is incredibly bad! It almost looks like massive vertical motion blur. Your shutter speed is fast enough so that even if the IS isn't working and you are shooting from a rickety ladder it should look better than this. Your aperture is also O.K. I don't know your work, but I assume you are advanced enough to know how to focus and handle your camera.
I would do the newspaper on the wall test STAT. Something is seriously wrong with your camera or a lens element has been knocked out of alignment. Remove any filters and also test with and without IS on.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
