Re: The Olympus 12mm field curvature vs. soft corners.
Bassam Guy wrote:
I don't really care about what shape the front element has, all I care about is the rearmost element - the sensor and what it creates. I've used this lens a bit for a couple weeks, in Times Square, Coney Island, in woodsy areas while hunting for my lost cat, and my brother-in-law's back yard.
It does great. I did buy a hood at B&H while in NYC (as I was obviously there). Only once, with the hood off, could I coerce some chromatic abberation from a low bright sun peeking through some trees. The flare was non-existent.
This is a damn good lens and I'll post some samples when I get home.
I won this new on eBay, with my lone opening bid of $400, so I can't say it was too expensive. I find it sharp from center to edge. Curiously, the edges were only sharp when they were in focus, duuh. Sure, it distorted in Times Square when pointed up but that's what I expected.
I did read a few very positive reviews on this lens, and only a few negative ones where I didn't think the reviewer(s) knew how to test wide angle lenses: focusing on the center and expecting edges to be in focus (despite the greater distance), angling it up and expecting undistorted results, etc.
This thing has great colors and is sharp. Just shot 150 keepers of 170 pix with it at my sister's birthday party Saturday. Cropped, a little white balance, a few vibrance and tonal adjustments, and I had a slideshow to surprise her with Sunday ready in a couple hours.
What serious criticism have you seen?
I've been around a while to see the comparisons, inevitably to the Olympus 12-40 and Panasonic 7-14 which do not have such aberration at 12mm, but neither lens option offers a sharp enough frame not to care at 12mm. At print size even as large as 30" prints which I've tested you can't notice the MTF drop off. I suppose you might be able to if you were sticking your nose up against it with a loupe, but who even really is that much of a pedant?
The other complainants seem to raise the issue of price. I raised the issue of this aberration on the basis that the now highly expensive Olympus 7-14 pro lens has a worse aberration to the corner of the frame so it can't really be said that this is a bad lens in that regard based on price. In the context I think some people just want to complain.
If you wait around you can find this lens for around $500, I did, so I don't think it is priced outside affordability. There is some degree of sample variability with this lens, but as I keep saying even when buying on ebay there is the toss it back option of INAD (item not as described) so you can't really lose.
It's a damned good lens, the distortion that it does have is easily correctable as there is a slight barrel distortion with no pillow top. DXO has an auto correcting profile for this lens also to save the hassle.
It's fast enough to shoot into the twilight zone or at night with good lighting and maintain solid shutter speeds even at ISO100 and sharp past good MTF results all the way from F/2 to around F/5.6. I have no complaints what so ever with this lens.
Some people will walk past it, it's their own loss.
