GX8 lens combo help
Started Aug 29, 2015 | Discussions
Old Timer63
Old Timer63 Veteran Member • Posts: 6,018
GX8 lens combo help
I`m thinking about getting the GX8. I have a 25 1.4 Panasonic Summilux so I gather that the inbuilt IS in the body will work with that lens?
Also, I have the latest Panasonic 14-140 OIS lens, so will that work in conjunction with the body IS? or is one switched off?
I shoot 4K video as well and from what I`m hearing the in body IS is turned off during 4K?
Thanks guys
I feel so much better now that I've given up Hope
http://www.pbase.com/davechilvers/latest_images
 Old Timer63's gear list:Old Timer63's gear list
Fujifilm X-H1 Panasonic Leica Summilux DG 25mm F1.4 Fujifilm XF 14mm F2.8 R Panasonic Lumix DMC-G7 Fujifilm X-T10 +20 more
Panasonic Lumix DMC-GX8 Panasonic Lumix G 14mm F2.5 II ASPH
hearingdouble Regular Member • Posts: 118
Re: GX8 lens combo help
Thanks guys
25/1.4 doesn't have OIS so yes, the GX8's IBIS will kick in.
The 14-140/3.5 has OIS which can work in tandem with the GX8's IBIS. You'll need to update the lens firmware to enable this "Dual IS" -- but it's worth it, the stabilisation is excellent.
hfg
hfg Regular Member • Posts: 427
I believe the 14-140mm Panasonic was one of the lenses that received a firmware update to allow it to use the GX8 dual IS system.  You can download it and apply the update yourself.
 hfg's gear list:hfg's gear list
Sony RX10 IV Sony RX100 VI Panasonic Lumix DMC-GM5 Olympus PEN-F Panasonic Lumix DMC-GX85 +14 more
Thanks guys
Forgot to reply to your last question.
Yes, IBIS is not available for 4k so you will have to use OIS only. If you're prepared to drop down to 1080p, then you can still use a form of Dual IS (which Panasonic call "hybrid" IS).
Old Timer63
OP Old Timer63 Veteran Member • Posts: 6,018
Thanks lads
To be honest I shoot video on a tripod, IS off and MF with my fz 1000 and the results can be superb.
Dave
LMNCT Veteran Member • Posts: 4,908
Is there an update for the firmware of the 25 1.4?
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
schlafmuetze Regular Member • Posts: 129
Not yet. But this round of updates is about the Dual IS which 25 1.4 will not get as it lacks the OIS.
IBIS still works for this lens, of course.
 schlafmuetze's gear list:schlafmuetze's gear list
Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 +19 more
George Spencer Senior Member • Posts: 1,079
There is an update for the Panasonic/Leica DG Nocticron 42.5mm F1.2 ASPH OIS but nothing yet for the Panasonic/Leica DG Summilux 15mm F1.7 or the Panasonic/Leica Summilux DG 25mm F1.4.
 George Spencer's gear list:George Spencer's gear list
Canon EOS 50D Canon EOS 6D Canon EOS 7D Mark II Panasonic Lumix DMC-GX8 Canon EF 50mm f/1.2L USM +12 more
cameron2 Veteran Member • Posts: 4,142
If in-body IS is really important, then the Oly EM5ii is probably the camera you want (in this size package).
If you're not sure that the GX8 is the camera that you want, then I suggest waiting a month or two. The price isn't going to go up, and you'll benefit from hearing others' feedback of their experiences.
 cameron2's gear list:cameron2's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Hasselblad X1D
Old Timer63
Thanks for your reply
It would just be nice to have IS with my 25 1.4. I`m certainly not changing makes, Panasonic really has got the 4K right now.
wait a couple of months:-( I`ll tell that to my best mate that died suddenly earlier this year He was left £1million a couple of years ago and had the best two years of his life buying sports cars, boats, cameras as and when he fancied. good luck to him and I`m sure he`ll RIP
Cheers
Cheers
IMHO, the 25 mm 1.4 has such a short focal length that it doesn't need IS.
Hey, in that case, go for it! (I did .. I pre-ordered the GX8 in July.)
katy C. Senior Member • Posts: 2,209
In body IS works with the 25 F1.4 on the GX8. It's great.
I am also finding that IBIS works a treat with my Oly lenses too.
katy
 katy C.'s gear list:katy C.'s gear list
Canon EOS M50 Canon EOS M6 II Fujifilm X-T4 Panasonic Lumix DC-S5 Canon EF-S 60mm f/2.8 Macro USM +10 more
Zensu11
Zensu11 Senior Member • Posts: 1,542
They can't create a Firmware update for dual IS on the P/L 15mm or P/L 25mm because neither of these lenses have OIS built in. However the GX8 should provide IBIS for both of these lenses and dual IS for the Nocticron as it has OIS built in. I'm thinking the GX8 kit with the new 14-140mm might be the best option for me.
Keep Calm and Sip Your Coffee
