24-70/2.8 II L has a slight delay when auto-focusing, is it normal?
Started Aug 25, 2015 | Discussions
MutantLabs Regular Member • Posts: 222
On my recently acquired EF 24-70/2.8 II L, I am noticing a slight delay when it's autofocusing. Maybe like approximately 300ms of "think time" before it then moves rather quickly and very accurately into focus-lock.
This is on a 6D, center AF point, one-shot AF and it's more noticable in lower-light scenarios.
Both my 24-105/4 L IS and 70-200/4 L IS do not show that delay, they start to move into focus pretty much immediately after I press the shutter (or back button focus) button. I've expected a better AF-performance than my 24-105 because of a) the price and b) the wider aperture of the 24-70.
Is this normal for this lens?
www.flickr.com/mutantlabs
 MutantLabs's gear list:MutantLabs's gear list
Sony RX100 Canon G7 X II Canon EOS 6D Sony a6000 Canon 6D Mark II +10 more
Canon EF 24-70mm F2.8L II USM Canon EOS 6D
Abu Mahendra Veteran Member • Posts: 5,312
Re: 24-70/2.8 II L has a slight delay when auto-focusing, is it normal?
It is the camera's extra sensitivity AF module kicking in. The reason you don't experience it with f/4 lenses is that the module is only activated at f/2.8 and brighter.
>> I love the Canon EF 35/2 IS lens!<<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
OP MutantLabs Regular Member • Posts: 222
Good info, I didn't know that. Could be part of the explanation why this lens produces so much ultra sharp images.
But does the high precision vertical sensitive AF that kicks in from f/2.8 and brighter needs extra time to do it's stuff?
hotdog321
hotdog321 Forum Pro • Posts: 21,141
That's interesting. Focusing is more or less instant with my 5D III bodies. What is this AF module thingie? Genuine request for info--no snark. Sounds like it would actually be a drawback for photographers needing to work fast.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
Nickels Regular Member • Posts: 458
Kind of curious about that myself...? There always seems to be some reasoning for expensive lens issues (i.e the 85 f1.2 focuses slow because of all the glass....yet the 35L doesn't...?)
Curious about this explanation.
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Right.  The 85L focuses by extending the large, heavy front lens group(s).  The 35L has inner focusing, moving a few small internal focus elements.
Re the 6D's AF system - Besides the standard precision cross center sensor, with f/2.8 and wider max aperture lenses it activates a high precision single axis sensor.  Other bodies are similar in this, but [wild guess] perhaps the lower light level the OP speaks of induces additional processing in the 6D, which has AF sensitivity rated to -3 EV, 1 stop greater than 5D III
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
The 6D focuses in lower light than the 5DIII. The 6D extra low light sensitivity module only kicks in in really low light.
Abu Mahendra wrote:
(..)The 6D extra low light sensitivity module only kicks in in really low light.
Now I am a little confused.
There's this one extra AF module with the vertical-line-sensitive AF point that is activated (only) if an f/2.8 or brighter lens is mounted. I got that.
Then there's another module that gets activated only in low-light situations? Or is the vertical-line-sensitive AF point module only activated on f/2.8 (or brighter) lenses and only in low-light situations?
larry Contributing Member • Posts: 889
Do you have a cite for this extra module, or is this just conjecture or misunderstanding?
Low light, near -3ev, AND f/2.8 or brighter.
No cite, just info based on use, confirmed by others here. The specs, however, are clear and explicit that the 6D can and does focus in lower light than the 5DIII. It's actually quite astounding how it will focus in virtual darkness. Coupled with IS and f/2 like with the 35IS, and it's something else.
Back to my original question:
Is anybody experiencing a slight delay / think time (~1/4th-1/3th sec) before the lens moves into focus in low-light with the 24-70/2.8 II?
In a normal to dimly lit room in the evening, focus on the far corner of the room and then point at something closer and press the shutter release. Does the lens start to move into focus instantly?
Back to my original answer. Yes, i too experience it with said lens as well as with other f/2.8 or brighter lenses. I have already provided the explanation. Nothing out of order or broken. Normal behaviour.
ed rader Veteran Member • Posts: 9,068
focus is instanaeous with 5d3....
never heard of or experienced any delay of any kind.
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
Ah, ok. I missed the point that you are experiencing the delay as well. Thanks!
BlueRay2 Forum Pro • Posts: 14,816
i am not sure about that, i notice that delay in my new 100-400mmII and my big white primes (600mm f4.0/300 f2.8) lenses. i do have to press on shutter button half way to set my lens/camera get ready for shooting (to pass that clicking and focus delay). it can be a bummer because i have missed some humming bird shots because of this nasty feature. also i had to deal with moon shots with my 600mm f4II. i finally learned to go manual with focus, IS, and everything else to shoot stationary subjects for focus accuracy purpose.
str8tshooter Forum Member • Posts: 65
Yes, only in dim situations...Like its trying to aquire focus. In bright conditions the focus is instant.
I'll say. I just bought this lens,it's awesome!
That has nothing to do with an "extra, low-light-only AF module" (I'm paraphrasing what you said, not actually quoting).  That's simply the ability of the current AF module in the 6D.  Just like the sensor can go to 200,000 ISO, the AF module CMOS can use dimmer light levels.
Are you trying to say that you want the camera to *instantly* take the pic, a  billionth of a second after you first touch the shutter button?  If you own the 300 and 600, I'd expect you to have more of an understanding of how cameras have worked, since SLR's were introduced back in the 60's?...
"Nasty feature"...
