NX 50-200 Lens OIS Versions
Started Aug 24, 2015 | Questions
CagriY New Member • Posts: 10
Hi all,
Is there a big difference between OIS 1-2-3 versions for this lens? I can find an OIS I for a considerably low price. Should I grab it or should I skip it?
If I skip, I will not buy an OIS 3 because I don't want to pay that much right now. The price is double. I just wonder if there is a huge difference among versions.
Thanks in advance!
 CagriY's gear list:CagriY's gear list
Panasonic Lumix DMC-TS2 Samsung NX30 Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS
Re: NX 50-200 Lens OIS Versions
AFAIK, only difference is iFn button on versions 2 and 3 and, for some reason, version 3 has issues with NX1 and NX500 (several threads here about that). Go for cheaper one and enjoy shooting.
mordor_74 Contributing Member • Posts: 622
I have one. Before buyng it i took some info and decides to pull the trigger. Not much difference. Mine is very good until 150. Needed to be stopped after 150, but still very good once i fix yhr contrast in pp. Afaik the latest versuon work the same. Very good conpared to various sigma, tamron and Minolta lenses.
I think that what makes the Real difference is the copy variation quality.
http://samsungnxtips.blogspot.com
 mordor_74's gear list:mordor_74's gear list
Sony Cyber-shot DSC-HX5 Canon EOS Rebel SL1 Samsung NX1100 Samsung NX 30mm F2 Pancake Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +7 more
markyboy81 Veteran Member • Posts: 4,778
How can I tell if I have version 2 or 3 as it doesn't appear to be marked anywhere on the lens?
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
ttbek Veteran Member • Posts: 4,869
It should be marked on the ring around the front element, at least it will have III on there for the III version. An unmentioned (in this thread) rumored difference is that the coating was changed for the III version, differences appear to be minimal though. Copy variation may be significant for any of them though, my III is quite a good lens, and I've seen good examples of the original here as well, I've also seen some with considerable decentering. Just evaluate the lens you receive (before buying in person if there is no return policy) and see if your copy seems good to you.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Thanks for the reply. Mine isn't marked with III on the front, yet it's ifunction so I guess it's safe to assume it's the II version?
I believe so, you can also see the front of the II lens in an image here (image 4):
http://www.samsung.com/nz/consumer/cameras-and-camcorders/lenses/nx-lens/EX-T50200IB
Compare to the III lens here (image 3):
http://www.samsung.com/uk/consumer/smart-camera-camcorder/lenses/zoom-lenses/EX-T50200CSB
