16-35mm f/2.8L II possible lens blur problem
Started Aug 19, 2015 | Discussions
hiki08 Regular Member • Posts: 189
Hello there,
I've had this lens for a few years now and on a holiday last year I had accidentally dropped it on its own from my backpack. I had it inspected by Canon who only found the lenses and fittings to have come loose (glass was undamaged). They replaced some fittings and scratched casing and I started using the lens again. Recently I've taken it to another small night photography trip and noticed some uneven blur on the right side of photos. It looks significantly more blurry than the left side and wonder if this might be an issue with the fixing of the lens. The lens zooms and operates smoothly though so I'm not sure if it can mean any loose fittings. Could I get some thoughts? Lens is out of warranty.
Photos taken recently, unedited (no cropping) JPEG out of camera:
4997
5000
5009
Photos above might be a bit dark, so I attach some touched up versions of the same photos. They have been cropped slightly, but if anything, more of the right side of photos are cropped off yet there is still significantly more blur on the right of these photos.
4997 edited
5000 edited
5009 edited
and for comparison, here is a photo of the night sky BEFORE I dropped/fixed the lens in 2013:
pre-drop image in 2013
What would everyone think is the cause? Should I be taking it back to Canon for a check? Thanks!
 hiki08's gear list:hiki08's gear list
Canon EOS 5D Mark IV Canon EF 85mm F1.2L II USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM +5 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Re: 16-35mm f/2.8L II possible lens blur problem
For some reason I can't get the posted images to enlarge so I can look at them closely, but this sounds like a classic case of a lens element knocked out of alignment. The 16-35 f/2.8 is already pretty soft at f/2.8 in the corners, so a misaligned element is disastrous. You can verify this problem with the newspaper on the wall test, but I'm pretty sure it needs fixing.
Good luck!
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
OP hiki08 Regular Member • Posts: 189
Good luck!
Thanks, I've sent an email to Canon simultaneous to this thread given your reply.
Wonder if others are also having trouble enlarging the images?
brightcolours Forum Pro • Posts: 15,885
Same here, clicking on the images does not work correctly anymore. Can't scroll after that either, someone at dpreview broke something.
When you click on the gallery link you can see the image bigger. Indeed, it looks like misalignment of the elements.
Good luck!
Landscapeforfun Contributing Member • Posts: 739
Almost certainly an element out of alignment.
IMO if your primary interest is milkyway/nightscape photos I would call the lens a total loss and upgrade to something much better. The left side of your lens is sharper, but the coma is pretty terrible, and the corners are mostly mush even on the good side.
The Rokinon 14mm f/2.8 is a good cheap alternative. Fully manual, but wider, and less coma than the canon. Sharper in the corners but a little less sharp in the center.
The Nikon 14-24 f/2.8 would also be fully manual but it is significantly sharper in all parts of the frame, wider, and almost no coma.
The new Tamron 15-30 f/2.8 VC is about on par with the Nikon, except you gain VC, AF, a native canon mount, but lose 1mm (still a 1mm gain over the canon).
You also lose screw on filters with all of these lenses which may or may not be a deal breaker for you.
The final option is the canon 16-35 f/4. You lose a stop, but the corners are significantly sharper and you maintain the use of filters. Also gain IS on this one.
Just something to consider if you are going to end up with a $300 repair bill just to get the lens to subpar compared to newer lenses.
 Landscapeforfun's gear list:Landscapeforfun's gear list
Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Rokinon 14mm F2.8 IF ED MC Rokinon 24mm F1.4 Aspherical Canon EF 16-35mm F4L IS USM +1 more
Thanks so it does look like there'll need to be a trip back to Canon then. I've really liked the lens though, and I'm the kind of person who tends to stick to the original manufacturer products. Manual wouldn't be ideal either. Tamron looks good on paper. Don't think i would consider an f/4 if I do focus on the night sky since fast shutter speed is quite key and IS is useless on a tripod. I do take it on travel too, when IS may become useful (especially in churches) but I found the lens to be sharp over past use - if it went back to its good old days then I'd be happy.
Orion142 New Member • Posts: 1
Hello,
Do you fix your problem with your 16-35 lens?
I have exactly the same problem .
Bonjours,
Est-ce que tu as corriger ton problème de ta lentille 16-35 ?
J'ai exactement le même problème .
Hello,
Much apologies, was swamped with work that I had placed all my photography stuff aside and didn't come on the forum.
Basically, yes it has been solved, but pretty much by bringing it into the local Canon service centre which confirmed some of the elements were misaligned. They aligned them again but charged me for the alignment even though I had basically not used the lens since I last took it back from them from a previous service. It was 6+ months since I got it back though so they do have a point they don't know if I had just dropped it again (lol). But I knew for myself that it's been in my dry cabinet since I had gotten it back.
I still haven't really used it after they aligned it again (it's been another year?). I'll be taking it on a trip to Iceland in a couple of weeks so I could check out if they did the alignment correctly this time.
MitchAlsup Veteran Member • Posts: 5,518
While I agree with the person above who stated that one (or more) lensing elements are out of (what astronomers call) collimation;
There might not be a lot Canon can do for you.
The other thing is that I never use a lens wide open for astro images, try stopping it down to F/4 and F/5.6 or F/8 and see if the images clean up. Also note at 24mm, a 30 second exposure will have stars on the equator move 6 pixels or so unless you use a motorized mount.
Mitch
Thanks Mitch. Wonder if you may clarify the reason you say Canon might not be able to do a lot in the case of a collimation? Not sure if it was mentioned above but the lens was previously dropped on concrete once, and I was told by Canon that the lens elements misaligned after. Their first fix apparently didn't fix the problem (would this be what you speak of? i.e. that it's very difficult to completely align the lens elements out of the original factory so there will always be collimation once it happens?).
I'm not particularly seasoned at astrophotography (I just like looking at the stars and take the occasional photos of them while on holiday), but I've also only ever heard of people suggesting to use the largest aperture when taking photos of the night sky. Wonder if your suggestion of a smaller aperture is only to see if it is a lens problem or an inherent lens characteristic?
Thanks for the tip on star trail movement. I usually go for around 15 seconds, at 16mm, that should be a lot less movement? (Though again I'm not particularly well versed and don't know how much movement that will be).
I might take a few photos with a simple patterned subject over the weekend to see if there is noticeable uneven blur.
Thanks!
At F/2.8 the lateral  <x,y>  accuracy is on the order of 0.001" and the <z> number is on the order of 0.003" for every set of lens groups in the whole optical train. A good (i.e., bad) drop can distort the lens frames to the point where the lens needs to be completely taken apart and rebuilt from the lenses--not something Canon can do in a repair shop.
Higher end Telescope manufacturers build in adjustments so that we users can collimate the field perfectly. A Ritchey Chretien telescope has some very tight collimation tolerances, and some of the larger professional telescopes take a whole month to collimate down to the 0.001" level for an 8 meter optical system.
Telescopes are designed to be used ONLY at maximum aperture, and the entire optical train is optimized at wide open--sometimes to the point where is you stop down you will reintroduce spherochromatism that was nulled wide open that is no longer nulled stopped down !?!
Take a minute to look up the MTF graph of your lens at several apertures and use an aperture where the MTF graph is as high as possible for as wide as possible, and time the exposure appropriately.
16mm gives you 50% more time before blur sets in. Higher resolution pixels give you less.
Got to take these wide open to see the collimation effects.
Mitch
Thank you Mitch for your time and explanation. I'll look up MTF as you've mentioned. My knowledge on the technical side is really not that great but I'll try to understand it better.
The weekend just went by (It's Sunday night here), but I'll see if I could take something wide open during the day next week.
Cheers!
KEN KUO New Member • Posts: 1
HELLO,   Hiki08
I have exactly the same problem as your 16-35 lens!
did Canon fix your problem with it finally?
KEN KUO wrote:
HELLO,   Hiki08
Yes, Canon fixed it in the end so the blur seemed even across the board
Then the 16-35mm f/2.8L iii came out and I bit (seeing it's one of my most passionate focal lengths)
