ISO 50 - Reduced DR on original DP's
Started Aug 18, 2015 | Discussions
SRT201
SRT201 Senior Member • Posts: 2,589
I noticed that Sigma pointed out the reduced dynamic range of ISO 50 when it was introduced in the DP1s.  I gather base ISO is actually 100.  Has anybody noticed just how much DR is lost.  I originally figured ISO 50 would be the obvious choice for landscapes but if much DR is lost then ISO 100 would be the one to stick with.
Any government that has the power to correct any injustice and level any inequality also has the power to do ANYTHING it wants.
Sigma DP1s
(unknown member) Senior Member • Posts: 1,857
Re: ISO 50 - Reduced DR on original DP's
Since the DP1s is ISO-less, the DR isn't actually reduced. ISO 50 is similar to a ISO 100 +1.0 (exposure compensation) shot. So you get cleaner shadows but lose 1 stop highlight recovery.
PrebenR Veteran Member • Posts: 4,164
You have to avoid overexposure with ISO 50. Highlights get  permanently blown
Lightwriting with Sigma dp2Q for stills and Blackmagic Pocket Cinema Camera for video
SRT201
OP SRT201 Senior Member • Posts: 2,589
Interesting.  So there's no gain on the imager and it's all just a matter of underexposure and multiplication during the development stage.
In that case then the ISO 50 with -1 compensation should be identical to ISO 100's normal exposure.  Correct?  Fairly easy to test.
Are the Quattro's ISO-less as well?
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
I remember Carl Rytterfalk ISO 50 shots from the SD15, so smooth, so brilliant.  I had to try it with my SD15.  Same result.
You get a different look at ISO 50.  I still have my classic DP2, need to try ISO 50 again.
I think ISO 50 is very worth the trouble, but overexposure is definitely fatal.
Tom Schum
Celebrate mediocrity (in moderation)
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
That's correct in theory, but since SPP is correcting the "overexposure" of ISO50 internal, it might be slightly different than ISO 100.  Same with the ISO-less SD1, it's theoretically the same if you under expose ISO 100 by 2 stops or choose ISO 400. The RAW data would be the same. But SPP is interpreting the image in a way that we can't control, so the result is slightly different too.
Quattro, SD15, DP1x and DP2x are different, because they have an AFE (analog front end)
MOD Kendall Helmstetter Gelner Forum Pro • Posts: 20,587
"In theory there is no difference between theory and practice. In practice there is."
- Yogi Berra
All of the Sigma cameras are.
That said, when using SPP to actually process the raw files they do not behave as if they were ISO-less.
You should test and see what happens (especially in the shadows), but I agree with the statement that you lose about a stop of highlight recovery.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
There is gain in terms of better IQ. I'm puzzled why people obsess about DR. For the most pleasing photos, people have reduced the DR in post anyway.
Here is a photo I took years ago. In this I reduced the DR in post quite a bit to obtain something more pleasing: https://www.flickr.com/photos/prebenr/6284631384/in/album-72157627678060149/
Not saying it is a goo picture, but if one wants to have an indefinite DR then things starts to look like snapshots.
No.
No.
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
- Yogi Berra
Taking a break from my break - can't let that pass, sorry.
Some Sigma cameras are not ISO-less, i.e. they have AFEs.
your statement directly contradicts one already made by @maceoQ:
"Quattro, SD15, DP1x and DP2x are different, because they have an AFE (analog front end)"
Back to the wilderness before I get pilloried
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
- Yogi Berra
I thought the Quattros had AFE. If it is only in SPP, then it would be interesting to hack the RAW images of the Quattros to change ISO. Roland, any pointers?
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,591
Once the shadows are pushed into the mud or the highlights pushed to saturation - they are gone forever. There are plenty of scenes where shadow detail in an area are important as well as highlight detail in a different area. If the sensor's DR is not sufficient to capture both and bracketing is not feasible ( moving vegetation in a landscape, moving water, etc.) then you have to chose which is the most important and expose correspondingly.
If the sensor's DR is capable of capturing both then expose to capture the shadow detail and process to bring out the highlight detail to minimize noise in the shadow. People are often surprised how much dynamic range exist in a natural scene. A one degree digital spot meter is a nice piece of equipment to have since it will tell you.
This scene had a very high DR. I was able to capture it and then print it nicely.
While the lighting is coming over my left shoulder, the reflectivity difference is quite large over the image, even between the shaded and sun lit part of the building.
Now what about landscapes:
This is a film shot which from my records had a 14 stop difference between the wet rock in the left of the image and the sunlit water.  I had to over expose and do a water bath development (hence expanding the DR of the film) to compress the image to capture detail in both.  Had I not done that - this image would have been what Adams use to proclaim - soot and chalk and certainly not a keeper.
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
DMillier Forum Pro • Posts: 23,871
The subject can have a brightness ratio that is pretty low for dull scenes (say 1:4) or pretty high in bright scenes (say 1:20,000).  If your sensor was capable of infinite dynamic range it would capture all the detail of the original scene.  You would then make the decision during editing as to how you wanted to render the scene in your image.
If your sensor has a dynamic range that is less than the brightness range of the scene then your camera cannot record all the detail and your choice of exposure determines what you end up  losing. In this case, you do not have the same breadth of artistic renderings available to you because your file doesn't contain all the data.
Generally (assuming you edit photos rather than using the untouched OOC files), you are better off with the first situation as it gives you far more editing options.
No.
No.
"...while I am tempted to bludgeon you, I would rather have you come away with an improved understanding of how these sensors work" ---- Eric Fossum
Galleries and website: http://www.whisperingcat.co.uk/
Flickr: http://www.flickr.com/photos/davidmillier/
ISO 50 is just overexposed ISO 100. It is useful for lower contrast subjects as you get a bit more exposure in the shadows. But shooting ISO 100 with +1EV exposure comp will yield the same file.
Roland Karlsson Forum Pro • Posts: 30,033
Yes, except that they are displayed and converted (by default) differently by SPP. The JPEG, the LCD and also standard SPP conversion, will render the ISO 50 image darker than the +1 compensated image. But, the RAW data will be the same.
/Roland
Kalpanika X3F tools:
https://github.com/kalpanika/x3f
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony RX100 III Pentax K-3 Pentax K-1 +14 more
jande9
jande9 Senior Member • Posts: 1,707
ArvoJ wrote a little utility that you can use to change the iso tag in the raw file.  It can be found here.
It works well and I had some fun playing with it.
Jan
 jande9's gear list:jande9's gear list
Canon PowerShot A650 IS Sigma DP1s Sigma DP2 Merrill Panasonic FZ1000 Sony Alpha NEX-7 +4 more
- Yogi Berra
Hmm... I guess that could affect things.  I had just heard it claimed of all of them.
One thing to get had to video filming, is that here you want to get a result!t as flat and little colour as possible. Then you grade in post.
My point would be that sure you would have more options in post, but would it not also kill creativity when you took photos?
Yes, and if I remember correctl, he wrote that utility because the exposure compensation in SPP has a limited number of steps, so you cannot recover an image if the ISO is set totally wrong. But, changing the ISOP setting you can.
/Roland
SRT201
I really don't know why Sigma had to artificially make that sounds so hi-tech.  The "Analog Front End" a term very common in signal processing is a gain stage that amplifies the signal from the imager (in this case).
That is common practice. Your product do not have something that almost all other have. The day you add it you try to make it sound as something fantastic.
/Roland
