5D3 sensor? problem.
Started Aug 17, 2015 | Discussions
paure1 Regular Member • Posts: 210
Hi all, Last weekend I took a 360 deg panorama and on processing the files discovered two frames had the partial magenta coloring. Both affected frames appeared identical and were taken 3 seconds apart. I have included the preceding frame as a reference.
The sun would have been at the top of the left hand edge on the affected frame.
The 5D3 has done 35k frames and I was using a 24 105L lens - 2 yrs old and manual exposure. I have not had this problem before and fired off another 73 frames without incident. Fxif intact
Any comments. Thanks Allan
Prior to problem
Problem frame
 paure1's gear list:paure1's gear list
Canon PowerShot G12 Canon G7 X II Canon EOS-1D Mark III Canon EOS 5D Mark III Canon EOS R +10 more
Phil
Phil Veteran Member • Posts: 3,142
Re: 5D3 sensor? problem.
Prior to problem
Problem frame
Looks very odd. I would blame memory card contacts but their are typically some raster effects from row & coluum read/write errors. This is more like an RGB channel loss.
These don't happen to be incamera JPEGs?
Phil Agur
“Imagination is more important than knowledge..." -- Albert Einstein
 Phil's gear list:Phil's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EF 17-40mm f/4.0L USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm F2.8L IS II USM +4 more
J A C S
J A C S Forum Pro • Posts: 14,944
You are probably missing the green channel in RAW. Does not look good.
OP paure1 Regular Member • Posts: 210
Hi Phil and J A C S,
Thanks for your comments.
I was shooting RAW and the faulty frames could be viewed on the LCD so not a card > PC problem. I should have checked all the frames before I left the site!
There does seem to be a problem with the green channel but with the tools I have I can't get my head around it. Looks like I will have to contact Canon.
Allan
J A C S
Allan
If you post the RAWs, people having Rawdigger can view the RAW file. Not that this would fix the problem...
Hi all,
Here is a link to an affected RAW file ...
https://www.dropbox.com/s/erf18gd24cmqhuc/311A6649.CR2?dl=0
I contacted Canon (New Zealand) and the tech said 'Clear all camera settings' and see if the problem still occurs. He wasn't interested in looking at the RAW file. We shall see.
Allan
Rick Knepper
Rick Knepper Forum Pro • Posts: 17,306
What is barely visible here but quite apparent once you download and view the file in an editor is at the extreme bottom of the frame where it appears the shutter did not close/open/whatever fully.
Problem frame
Once you've done fifty, everything else is iffy.
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R Fujifilm GFX 50S Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW Pentax DA645 28-45mm F4.5 +9 more
Iliah Borg Forum Pro • Posts: 26,080
paure1 wrote:
Hi all,
Allan
The file contains damaged raw data, and more - the embedded JPEG contains same artifacts.
This happened right in the imaging path in the camera. Red and Blue channels are in fact greens (see the raw channel histograms on a cloud), channels are multiplexed in the wrong way because the synchronization of the sensor read-out was messed up. A quick fix would be to change the RGBG pattern in raw decoder.
You can see that 2 green channels, instead of being very similar, a quite different; while Red and Blue channels are quite similar, which is typical if they would be green channels.
At the very bottom of the frame the sync problem is quite evident, it contains garbage, including on the embedded JPEG (here it is, download and look at the very bottom at 100%)
