E-P5 focusing issue
Started Aug 15, 2015 | Discussions
glassoholic
glassoholic Veteran Member • Posts: 7,641
Re: Update on E-P5 focusing issue
Are you able to transcribe or post a copy of the service report?
"You are a long time dead" - credit to my wife
Make the best of your brief time in this world
Jay Siegel
OP Jay Siegel Senior Member • Posts: 1,319
Re: Service report
There are two relevant sections. The first is "Explanation of Repairs". For both services this was the same:
"AUTO FOCUS TEST, CHECK, RECALIBRATION AND REALIGNMENT FIRMWARE DOWNLOAD: CORRECTIONS AND ADJUSTMENTS; ADDRESS VALUES MEASURE AND ADJUSTED COMPLETE CLEANING (INTERNAL-EXTERNAL)"
The second relevant section is headed "Description of Parts Used" and in the first servicing this section was empty. In the second servicing the section contained:
"MT CONTACT FRAME UNIT"
So, it looks like something was replaced in the camera which has focused flawlessly upon its return from the second servicing.
Jay S.
 Jay Siegel's gear list:Jay Siegel's gear list
Olympus C-2500 L Panasonic FZ1000 Olympus PEN E-P5 Olympus Air Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +13 more
glassoholic
Re: Service report
Thank you for that.
AgoP5 Forum Member • Posts: 70
Re: quite the opposite for me
James Pilcher wrote:
Just to balance the discussion a bit:
I've been using my E-P5 (two different bodies) for 18 months. I have nothing but praise for AF performance. I use a mixture of Olympus and Panasonic lenses. I also use a mixture of camera modes and settings all the time. So, I guess I can't help you here.
Now, if you want to discuss failing E-P5 dials, I'm your man.
Same for me, never missed a shot so far.
And mine have no problem even with dials. Lucky me.
 AgoP5's gear list:AgoP5's gear list
Olympus PEN E-P5 Olympus E-M1 II Sony RX100 II Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 60mm F2.8 Macro +3 more
Zensu11
Zensu11 Senior Member • Posts: 1,542
I've been lucky too. No issues at all in 18 months.
Bobby
"Images of broken light which dance before me like a million eyes
They call me on and on across the universe"- John Lennon
Broken light gear: 2-EP5's (one IR), P 7-14mm, P/L 15mm, P/L 42.5mm, O 60mm macro
cnw2 New Member • Posts: 1
Re: E-P5 focusing issue
eclipsechaser1 wrote:
Are you all using the small focus box right? This improves the situation somewhat
What do you mean?
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
What do you mean?
I suspect all those people have faded away from the forum in the last 4 years.....
With the E-P5 you can choose to use a small single centre focus box and do the half press focus, hold and re-frame, then full press to shoot. It's the way that I've used all cameras.
As for finding the single AF box, press Left, then Info and then Up/Down (or the rear dial) changes the focus box setup, and Left/Right (or the front dial) changes the face detection setup.
Otherwise use touch screen AF (optional touch AF and shoot) and set the focus box to the smallest size. Enable touch AF then use the slider on the right side of the screen to set the box size.
The two focus schemes are separate, can have the usual default shutter button AF scheme as anything and keep the small AF box for the touch screen use.
On all cameras I have found that using the single small centre box is the most reliable way to AF. Despite that, again all cameras may do some totally unexpected and stupid AF about 1 in 1,000 shots. If it happens a lot more often than that the try other lenses and other AF schemes and maybe even getting it fixed.
Regards.... Guy
Guy Parsons
More....
I forgot to add, the E-P5 (and most other non-SLR cameras) expects to find vertical contrast edge in the focus box to achieve AF.
In reality it doesn't need to be a vertical edge, basically just a non-horizontal edge, it gets more critical as the light gets lower.
If only a horizontal edge is available in the scene then twist the camera a few degrees and then the AF will work, hold half press and realign the frame and full press to shoot.
Regards.... Guy
paul613
paul613 Senior Member • Posts: 1,894
Pen E-P5 + Pen FT prime(s)
Jay Siegel wrote:
I started my photography hobby in the late 1960's with an Olympus Pen-FT and have stuck with Olympus every since. I really appreciate the retro styling of the E-P5 and it's strong resemblance to the Pen-FT.
My everyday-carry setup is all-Olympus: E-P5, VF-3 viewfinder, two pancake primes (9mm and 17mm), and an adapted Pen FT 38/1.8 lens made in 1972, all carried in a 5x5-inch belt pouch. The 45/1.8 would have been too big.
Paul S. in Maryland
There are no solutions; only trade-offs.
 paul613's gear list:paul613's gear list
Olympus PEN E-P5 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Sigma 30mm F2.8 DN | A Rokinon 8mm F3.5 Aspherical Fisheye (HD) +10 more
Koos_F New Member • Posts: 1
When both my EM10s gave me grave shutter problems I stopped using them (obviously) and fell back on using the trusted E-PL3 and E-PL5.
But I wanted progress, so acquired two second-hand E-P5s, which are fabulous.
If they give me problems, I'll still have the oldies to fall back on during repairs.
I'll see if I can get the OM10s repaired. If it's affordable, then it's fine and I'll sell them.
If not, goodbye.
Bottom line: I'm glad I didn't sell the oldies. They're fine cameras, just quite a bit more limited.
