Oly 14-150II vs Panasonic 14-140II
Started Aug 14, 2015 | Discussions
jbancroft1957 Contributing Member • Posts: 941
Hi
As a follow up to this thread:
http://www.dpreview.com/forums/post/56310628
I've just bought the Oly (it's being discounted heavily here in the UK), as my Panasonic suffered from shutter shock until I moved to Oly E-M10 and E-M5II bodies, using the anti-shock '0' setting.
Of course the Oly lens is weather sealed but I do find the Panasonic IQ amazingly good for the type of lens it is. So, has anyone tried both and compared IQ?
I'm wondering if, despite the discount, I simply stick with what I have and return the Oly (I've not opened the box) for a refund?
John
Panasonic Lumix G 14mm F2.5 II ASPH
CrisPhoto
CrisPhoto Senior Member • Posts: 1,749
Re: Oly 14-150II vs Panasonic 14-140II
jbancroft1957 wrote:
Hi
John
As the 14-150 mark 1 and mark 2 seem to be very similar in design (only different coating and less onion ring bokeh).
I compared 14-150 I and 14-140 II recently.
The pana lens has much more vignette. Medium FL is weak (25-40mm). And sometimes it has mis-focus at infinity with my OMDs. But if it nails it, it is very sharp at the long end.
The old Oly is better at the short end up to 50mm but much weaker at the long end. Vignetting is better but not good and the bokeh is smoother.
C
OM-D + Sam7.5, O25, O60, O75
O12-40, O40-150, P 14-140
 CrisPhoto's gear list:CrisPhoto's gear list
Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +9 more
amipal
amipal Senior Member • Posts: 1,275
I can't compare, but my copy of the Panasonic 14-140 is sharp throughout the range (though a little softer at 14mm).
Paul
 amipal's gear list:amipal's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GM5 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
alcelc
alcelc Forum Pro • Posts: 19,003
Can't comment on 14-150 II.
Same as Amipal, I'm more than happy with 14-140 II. For its early range (from 14 to 45), it is as good (I might like the contrast and saturation a little bit more) as 14-45. Comparing to 45-200, 14-140 II is obviously better.
It is mounted mostly on GF3 (my wife's camera), and occasionally used on G1, GX1 and GX7 (M/E-shutter). Like most owners of this lens, it performs well. I never noted on SS or jittering in video. If my 14-45 would be broken, I'll never hesitate to buy one more for my regular use.
Albert
