Can I buy one of the EF 100mm Macro lens instead of EF 85mm f/1.8 USM?
Started Aug 13, 2015 | Polls
ms18
ms18 Veteran Member • Posts: 3,530
I use EF 50mm f/1.4 USM with APS-C to take photos of portraits and Indoor sports. Now I'm planning to replace it with a lens with a 5D (Later upgrading to either 6d or 5d mk iii). Main reason of this replacement is inadequate focus speed and the next is 50mm f/1.4 is not  good wide open but that is the depth of field I would like to have in some portraits. Next any way i want to move to full frame for indoor noise performance.
I was thinking about buying a EF 85mm f/1.8 USM. But later on i was planning on one of the Canon 100mm macro lens. Either the L version or Non L version.  The 15mm focal difference is not a problem for me. I can adopt. I like the bonus feature of Macro. But my worry is how fast is the auto focus? The very first reason for this upgrading is auto focus speed. If the autofocus is capable same as EF 85mm then I would like to go for 100mm macro. Also let me know if there is a AF difference between L and Non L in 100 macro.
 ms18's gear list:ms18's gear list
Fujifilm X-T20 Fujifilm XF 56mm F1.2 R Fujifilm XF 23mm F1.4 R Fujifilm XF 14mm F2.8 R +1 more
POLL
Buy 85mm f/1.8 USM it has better auto focus than EF 100mm macro lens when used in indoor sports.
66.7% 4  votes
Buy one of the EF 100mm Macro lens because it has equal auto focus speed of 85mm f/1.8
33.3% 2  votes
  Show results
Canon EOS 5D Canon EOS 6D
mikero
mikero Veteran Member • Posts: 3,054
Re: Can I buy one of the EF 100mm Macro lens instead of EF 85mm f/1.8 USM?
I've owned all the lenses you mention.  The first I bought was the 85mm F1.8 which is a very nice lens and I used it a lot.  I then got into macro and bought the 100mm Macro non-L.
I bought the 100mm Macro L came out, and sold my non-L macro.  I did the swap to gain IS, because it was an 'L' lens, and because I could afford it.  The IS is a useful feature.
Eventually I sold my 85mm F1.8.  Nothing wrong with it, but it was too similar to the 100mm Macro L, and whenever I looked to use that sort of focal length, I always found myself reaching for the 100mm, largely because of the IS.  The 85mm F1.8 just sat in the bag.
I've not had a problem with AF speed of the 100mm Macro L, and if the purpose is portraiture, then I don't see a problem.  Not as fast as the 85mm F1.8, but fast enough.  And the macro and IS features make it more versatile.
Mike
 mikero's gear list:mikero's gear list
Olympus E-M1 II OM-1 Olympus 45mm F1.2 Pro Olympus 8mm F1.8 Fisheye Pro Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
Jura S Senior Member • Posts: 1,980
If you consider 100mm macro, go for the 100L.
It is a just a little sharper, but IS, wheather sealing and better construction outweight relatively small price difference.
ms18
OP ms18 Veteran Member • Posts: 3,530
I want fast auto focus for indoor game badminton. EF 50mm f/1.4 USM is not fast enough
So still EF 85mm is faster?
Yes but not for the primary reason i'm switching to.. But macro is the reason I'm considering another lens.
Fog Maker Senior Member • Posts: 2,733
Get the 100mm 2.8L
It is not expensive and will last you a lifetime.
Wicked lens.
 Fog Maker's gear list:Fog Maker's gear list
Canon EOS 5D Mark III Canon EF 24-70mm f/2.8L USM Canon EF 85mm F1.2L II USM Canon EF 100mm F2.8L Macro IS USM
bigfatron Contributing Member • Posts: 777
Oddly enough I owned both and sold the 85 last week after owning it for half a dozen years. Don't get me wrong, the 85 is a wonderful lens but AF on the 100 macro is no slouch and I didn't really need both lens in such a similar focal length range.  The 100 was proving more versatile with the macro capability and I wasn't doing enough portrait stuff with the 85 to justify retaining it (the 'look' straight out of the camera on the 85 I marginally preferred).
 bigfatron's gear list:bigfatron's gear list
Canon EOS 5D Mark IV Canon EF 24-105mm f/4L IS USM Canon EF 100mm f/2.8 Macro USM Canon EF 35mm F2 IS USM Canon EF 100-400mm F4.5-5.6L IS II +3 more
mikero
I wasn't reading carefully enough.  I wasn't aware badminton was the PRIMARY application.  Sorry.
I would think the 85mm would probably be faster.  The 100mm L is no slouch though, on the 0.5m to infinity setting.  But you'd need to test it on the intended subject to be sure.
If you're considering a macro anyway, why not get the 100mm L first, and see if it's good for badminton?  If not, get something else in addition.
Mike
maboleth Contributing Member • Posts: 831
I own Canon 100m L macro IS and is a wonderful lens with great bokeh. USM is lighting fast. That being said, I'm planing to buy 85mm F1.8. Why? Because 100 can be a bit too far on the 7Dmk2, but the main reason is that you have 1 1/3 of a stop less DOF with 1.8 than 2.8.
Plus 85mm f1.8 is cheap workhorse lens.
However, if I were you, I'd get 100mm IS first, because it's more versatile, you have a mild telephoto + portrait + macro lens + IS.
 maboleth's gear list:maboleth's gear list
Canon EOS 5D Mark IV Canon EOS 90D
DannH Contributing Member • Posts: 642
I have owned the Canon 100mm f/2.8 and now own the L lens and the 85mm 1.8. The Canon 100mm and 85mm give very different looks, personally I think the 85mm is nicer for portraits. It's not as sharp, the colours aren't as vibrant but it offers a much shallower dof and just looks better for portraits imo.
The 100mm is no slouch with focusing, but the 85mm is much faster. There is no noticeable difference in focus speed or image quality between the 2 100mm lenses, with the L you are paying for IS and weather sealing. If your planning on shooting macro in natural light its well worth it otherwise the non L is still a great buy.
You say you want the dof of the 1.4 in some portraits, but the macro lenses are only f/2.8, which is a big dof difference.
100mm Macro - Brilliant macro lens, very good portrait lens.
85mm - Brilliant portrait lens, no macro ability
Rexgig0
Rexgig0 Veteran Member • Posts: 7,399
EF 100/2.8L Macro IS has quite sedate AF. 135L is faster.
My EF 100/2.8L Macro IS is one of the slowest-auto-focusing lenses I have ever used. This much more noticeable in low light, but is always a factor. I have never used any 85mm lens. My EF 135/2L auto-focuses much faster, and is my favored portrait lens, if I have enough distance to work with it.
I am not slamming the EF 100/2.8L Macro IS; it is one of my favorite lenses, and one of my most-used, being my work-horse lens at work for almost five years, paired with a good zoom lens on a second camera body. (Presently, that zoom is a 24-105L, which has much faster AF than the Macro L.)
Having said that, the EF 100mm f/2.8L Macro IS can be an indoor sports lens, if the sport moves slowly enough. I shot my nephew's swim meets for one year with this lens. Youth swimming is not the fastest-moving sport in the world, of course. Notably, however, I did my research, and bought my EF 135mm f/2L, in order to be better-prepared for the next season, though my nephew did not join the swim team again.
My understanding is that the EF 135mm f/2L does not AF as quickly as the true sports lenses, such as the various 70-200/2.8L options.
I wear a badge and pistol, and make evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, and PJ. I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +54 more
arty H Senior Member • Posts: 1,546
AF is decent on the 100 non-L macro, but very fast on the 85F1.8. I like the 85 much more for portraits on crop or full frame. The 85 is also much smaller and more compact.
rsn48 Veteran Member • Posts: 7,755
Consider Tamron 90 f2.8 VC Macro
The Tamron 90 f2.8 VC gets excellent reviews as its earlier incarnation did as well.  This lens is a true macro lens and is value and a bit cheaper than the Canon 100.
http://www.bhphotovideo.com/c/product/892882-REG/Tamron_90Mm_F_2_8_Di_Macro.html
Given the choice between excellent equipment and excellent skill, I'll go for the skill every time.
danferrin Contributing Member • Posts: 730
Unless I've forgotten my math, the depth of field of a 100mm f/2.8 lens is essentially the same as a 50mm f/1.4 lens.
My life is a circle of confusion - photography is my meditation.
 danferrin's gear list:danferrin's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS R5 Canon EOS 60D Canon EOS R7 +20 more
Buchanan Senior Member • Posts: 1,124
I think an original 5D with a 100 macro will be challenged at shooting indoor sports.  I haven't shot badminton but have to think the movements are pretty fast, particularly the swings with the racquets and birdie action.  5D is not known for fast action accurate focusing and the 85 1.8 is faster to focus than the 100 macros.  Also don't know how bad the lighting is in the indoor venues you are shooting but if it's not too good the 1.8 will of course give you more advantage than 2.8.  You can find used 85 1.8 lenses for pretty good prices and continue saving for the macro.
 Buchanan's gear list:Buchanan's gear list
Canon PowerShot S95 Canon EOS 60D Canon EOS Rebel SL1 Canon EOS 70D Canon EOS 6D +15 more
jitteringjr Veteran Member • Posts: 3,608
I own the 85/1.8, 100L and 135/2 and I am sorry to tell you but each has its use and no one can fully replace the other 2.  I would not be looking at any macro lens if your primary focus was going to be indoor action.
 jitteringjr's gear list:jitteringjr's gear list
Canon EOS 7D Sigma 30mm F1.4 EX DC HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm F4L IS USM +9 more
Kasra A
Kasra A Regular Member • Posts: 189
If you're going to use any of these lenses on an original 5D, the limiting factor would be the body not the lens. Even the 5D Mark II doesn't have a stellar AF system.
Anyways, 100mm f/2.8L is not particularly fast, even when you set the AF range to 0.5-inf. AF speed is not where it shines, it's the resolution and it's macro abilities. 85mm 1.8 is indeed faster in focusing.
 Kasra A's gear list:Kasra A's gear list
Canon EOS R6 Sony a7R II Tamron SP 24-70mm F2.8 Di VC USD Canon EF 16-35mm F2.8L II USM Canon EF 70-200mm F2.8L IS II USM +5 more
Suave Senior Member • Posts: 2,289
I own both 100L and 85/1.8.  I love 100L but 85 has much, much faster AF.  I would never consider using 100L in a situation where I need to track.
Where's my new 50, Canon?
 Suave's gear list:Suave's gear list
Canon EOS 5D Mark III Nikon D7000 Canon EOS RP Canon EF 24-105mm f/4L IS USM Canon EF 85mm F1.8 USM +7 more
grammieb14 Senior Member • Posts: 2,675
85/1.8 is a very fast focusing lens.  I used it a lot at Hornet basketball games.  The 100 macro has a limiter to keep it from hunting.  If you set the limiter to the distance you are shooting, the af speed shouldn't be a problem.  Bab
http://www.flickr.com/photos/28700476@N08/
 grammieb14's gear list:grammieb14's gear list
Canon EOS M3 Canon EOS Rebel SL2 Canon EOS 5D Mark IV Canon EOS 5DS R Canon EOS M5 +39 more
epozar
epozar Senior Member • Posts: 1,969
Consider also 100/2
Better than 85/1.8
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko 300mm F4 IS Pro +10 more
hjulenissen Senior Member • Posts: 2,442
I own the 85mm and I am using the 100L alongside it on a Canon 7D.
In my case, the 100L is used far more than the 85mm (or my 70-200 f/4IS). IS, macro and excellent performance at f/2.8 beats moderate performance at f/1.8 (and troublesome focusing to achieve it).
Of course, if you really need f/1.8 (for DOF or light), then 85mm is what you need.
-h
