Sony a7R, a7RII shutter shock
Started Aug 9, 2015 | Discussions
JimKasson
JimKasson Forum Pro • Posts: 39,120
35
The mechanical shutter on the Sony a7RII is supposed to be better damped. It also has electronic first-curtain shutter (EFCS). How do those things make moderate telephoto pictures sharper?
The protocol:
  • The cameras: the Sony a7RII and Sony a7R.
  • The lens: the Leica 180mm f/3.4 Apo-Telyt-M
  • The filter: Heliopan 77mm variable neutral density.
  • The lighting: a single Fotodiox LED-200WA-56 daylight balanced flood.
  • ISO set to 800,
  • Manual focusing wide open, then lens set to f/5.6.
  • Drive set to single
  • Camera on an RRS TVC-43 with an Arca Swiss C1 head, RRS L brackets in landscape mode.
  • Exposure protocol: ND filter to minimum attenuation,, shutter to 1/500, make an exposures, ND filter down a third of a stop, shutter down a third of a stop, make another exposures… until you get to 1/10 second.
  • Make a series with both cameras, EFCS on and off in the case of the a7RII.
  • Develop in Lightroom 5.7.1 with standard settings.
  • Crop, export as TIFFs, analyze for horizontal edge (that's the edge perpendicular to the way the shutter travels) MTF50 in Imatest.
  • Export the results to Excel and graph.
Landscape orientation makes it easier on the mechanical first curtain cases, since the tripod is stiffer in that orientation. Mounting the camera body directly to the tripod also makes it easier on those cases.
The results:
The blue line is the a7R. It does the worst even at high shutter speeds by virtue of its slightly lower-resolution sensor. The orange line is the a7RII with both curtains operated by the mechanical shutter. I still exhibits shutter shock, which is not a surprise. The grey curve is the a7RII with EFCS on. It looks pretty darned good.
Comments and questions appreciated. More focal lengths to come, if there's interest.
OBTW, even 1300 cy/ph is pretty sharp.
Jim
 JimKasson's gear list:JimKasson's gear list
Leica Q2 Monochrom Nikon Z7 Fujifilm GFX 100 Fujifilm GFX 100S Nikon Z9 +1 more
Sony a7R
Everythingis1
Everythingis1 Contributing Member • Posts: 584
Re: Sony a7R, a7RII shutter shock
The protocol:
  • ISO set to 800,
The results:
Jim
Thank you so much for your contributions to these forums.  You are a true diamond in the rough.
JimKasson
OP JimKasson Forum Pro • Posts: 39,120
Uh, that's a Leica R series lens.
Sorry,
Jim
Horshack Veteran Member • Posts: 8,740
Bracketed shooting experiments
Jim, was hoping you'd get to the shutter vibration tests soon I'm very interested in seeing what the shutter vibration is for continuous EFCS shooting mode and how the fully-electronic shutter compares, with the real-world usage case being bracketed exposures for landscapes.
For example, on the 5DSR I found that performing a bracketed exposure in continuous mode causes vibrations on the 2nd, 3rd, etc.. exposures even with the camera in LV and with Canon's EFCS turned on (test here). The reason for the vibration is that the camera doesn't insert any delays in between exposures of the bracketed sequence, which means only the first exposure benefits from the EFCS (ie, after the first exposure, the 2nd curtain closes, the 1st curtain opens, and the second exposure starts right away, thus no settle delay and effectively no EFCS benefit). The only way to work around this on the 5DSR is to use a non-continuous mode and manually trigger each exposure of the bracket, which provides enough time for the shutter to settle between exposures and thus benefit from the EFCS. The problem with this solution is that it introduces scene-motion risk between exposures, such as the clouds, sea/lake, etc..
So for the A7rII the first experiment I'd love to see is what delay if any the camera inserts between exposures during a bracketed sequence performed in EFCS continuous shooting mode. Assuming the camera doesn't insert any delay or an insufficient delay (which in my testing on the 5DSR would be any delay < ~500ms), the next experiment would be that same continuous bracketed sequence but with the fully-electronic shutter, and then compare the shake/MTF between the two sets.
My guess is that continuous shooting with the fully-electronic shutter will yield the best bracketing solution on the A7rII. The read-noise/DR penalty from using the electronic shutter/continuous shooting vs EFCS will be immaterial since the bracketed exposures will be merged in post and provide multi-EV benefit that will allow shadows to be pushed with no noise anyway.
Petroglyph
Petroglyph Veteran Member • Posts: 6,096
The protocol:
  • ISO set to 800,
The results:
Jim
I always knew there was a reason I wanted EFCS.    That, & the silent shutter, is a real benefit partially from the copper BS wiring.  Thank you for the graph.
 Petroglyph's gear list:Petroglyph's gear list
Sony a7R II Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Samyang 20mm F1.8
HikerSD New Member • Posts: 19
This is great news. Your efforts are much appreciated.
 HikerSD's gear list:HikerSD's gear list
Sony a7R II Sony a6500 Sony E 18-200mm F3.5-6.3 OSS Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 55-210mm F4.5-6.3 OSS +13 more
khaw
khaw Senior Member • Posts: 1,249
Many thanks Jim. Repeating those measurements in portrait orientation would be illuminating.
Also, I noticed the most severe shutter shock on the A7R with APO-R 280/4 or Vario-R 105-280/4.2 in portrait orientation. Any chance you could measure those lenses on A7R and A7RII? TIA.
 khaw's gear list:khaw's gear list
Leica M9 Sony a7R Sony a7R II Fujifilm GFX 50S Sony a9 +1 more
ProfHankD
ProfHankD Veteran Member • Posts: 8,730
Effects of IBIS, body design, new shutter
JimKasson wrote:
The mechanical shutter on the Sony a7RII is supposed to be better damped. It also has electronic first-curtain shutter (EFCS). How do those things make moderate telephoto pictures sharper? ...
Very cool. I suppose you could also test with silent (fully electronic) shutter -- I guess that would give a baseline for ambient vibration?
I assume all A7RII tests were with IBIS off? How about on?
When I got my A7II, I was actually expecting that I might see some shock with IBIS off that I hadn't seen with my A7 -- because the sensor in the A7II is not on a very rigid mount. I haven't, but I never explicitly tested for this either. If anything, my impression is that the A7II is a touch more stable, and I credit the body design. Have you ever tested the A7 and A7II? It would be interesting to see if the body design for the II versions is a significant part of the difference you're seeing between the A7R and A7RII or if it really is all due to the new shutter... (which the A7II doesn't share).
Which is probably why we don't notice much of this in real-world examples from the A7/A7II even with EFCS disabled.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Abrak Veteran Member • Posts: 4,208
Re: Effects of IBIS, body design, new shutter
Well I would be interested to know if there are circumstances when the silent shutter should be used (other than when you want silence). As in perhaps high speed continuous shooting or bracketing on a tripod.
stevo23 Forum Pro • Posts: 24,735
The protocol:
  • ISO set to 800,
The results:
Jim
Any thoughts about adding a line for the silent shutter? I'm surprised no one has characterized it yet.
 stevo23's gear list:stevo23's gear list
Fujifilm X-Pro2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F1.4 R +3 more
JimKasson
Yes, but also would drop a bit and add some RN. I will get around to trying it, though. From my tests of the Nikon D810 with EFCS vs trailing curtain studio strobe illumination, there's not a lot to be gained from omitting the trailing curtain acceleration.
The camera was on a tripod. I've not found that IBIS helps with the camera on a tripod, and it often hurts:
http://blog.kasson.com/?p=8391
Yes. See here:
http://blog.kasson.com/?s=a7ii+ibis
Yes.
http://blog.kasson.com/?p=9906
Jim
JimKasson
As I said to Hank, I will get around to trying it. From my tests of the Nikon D810 with EFCS vs long exposure trailing curtain synched studio strobe illumination in a darkened room (which has to be the gold standard for vibration minimization), there's not a lot to be gained from omitting the trailing curtain acceleration at this focal length.
Going to silent shutter will cost a bit of resolution and add some read noise, although probably neither will affect the slanted edge results.
Jim
ProfHankD
Agreed that there should be almost no positive effect vs. EFCS unless you're shooting a sequence rather than an individual frame, but you never know till you test, right?
Logically, it seems that IBIS might be able to partially compensate for shutter shock. How do A7II tests with EFCS on tell you it doesn't?  (I didn't see tests with EFCS off.) Also, wouldn't the effect, if any, be much more measurable on the A7RII?
I would certainly agree that, in light of your (and other) earlier tests, one would expect the better performance to be delivered by IBIS off + EFCS on vs. IBIS on + EFCS off.  So, this is probably an entirely academic question....  Then again, I'm an academic guy and I also have very serious doubts that the control algorithm for IBIS is as smart as it could be (potential research topic?).
CraigArnold Contributing Member • Posts: 697
The protocol:
  • ISO set to 800,
The results:
Wonderful thank you!
Indeed. It's always been tiresome how so much opinion polarizes immediately to insisting that it doesn't exist (despite the evidence) or alternatively makes the camera utterly worthless (despite the evidence).
Jim
I very much look forward to some handheld testing with the Zony 55 and IBIS when you get the chance. And if I might be so cheeky, perhaps even your favourite 35.
Thank you as always for your testing.
 CraigArnold's gear list:CraigArnold's gear list
Fujifilm FinePix X100 Olympus Tough TG-4 Sony a7R Sony FE 35mm F2.8 Sony FE 55mm F1.8 +2 more
JimKasson
Results with the Leica 280/4 Apo-Telyt
10
I put the Leica 280mm f/4 Apo-Telyt-R on both the a7R and a7RII, mounted the lens collar to an Arca Swiss C1 head on a set of RRS TVC-43 legs, set the whole thing on a vinyl tile over 6 inch concrete floor, and made some slanted edge photographs at various shutter speeds. With the a7RII, i used the mechanical shutter for one set of images, the electronic first-curtain shutter (EFCS) for another, and the all-electronic -- silent -- shutter for a third.
This is a harder test for the mechanical shutter than yesterday's, since using the lens collar as the tripod mounting point allows the camera to move more than mounting the camera body directly to the tripod. Unfortunately mounting a big, heavy lens like the 280/4 to the front of the camera unsupported is a recipe for damaging the lens mount.
The first series of images was made with the camera in landscape orientation. That's easier on the mechanical shutter than portrait orientation, since tripods are stiffer in the up and down direction than they are from side to side. Then I said "what the hey" and made a series in portrait orientation.
As a total aside, why can't all lens collars have crisp detents every ninety degrees like this Leica lens?
You want the good news or the bad news first? The bad news? I thought you were tough. Brace yourself.
Here it is. Although Sony said that they increased the damping of the a7RII shutter over that of the a7R (and I have no reason to disbelieve them) with a long lens like this it doesn't make much difference. That's because the bulk of the motion imparted to a tripod mounted mirrorless camera with no added delay between winding the shutter and firing the first curtain comes from the winding action, not the motion of the first curtain. That is especially true for a big lens which has a relatively low resonant frequency compared to a small one.
Okay, are you ready for the good news?
Thought so. The EFCS on the a7RII works great. In fact, it works so well that going all the way to silent shutter mode doesn't bring any significant improvement on single shots, although it almost certainly would on a series of exposures made in a short period.
Details follow.
First, I'll drag you through the protocol.
  • The lens: the Leica 280mm f/4 Apo-Telyt-R
  • ISO set to 800,
  • Manual focusing wide open, then lens set to f/6.9 (halfway between f/5.6 and f/8).
  • Self timer set to 5 seconds on the a7RII and 10 seconds on the a7R.
  • Camera on an RRS TVC-43 with an Arca Swiss C1 head, RRS L brackets on the cameras, but not used for mounting. Lens collar mounted to head with RRS generic plate.
  • Crop, export as TIFFs, analyze for horizontal edge (that’s the edge perpendicular to the way the shutter travels) for the landscape shots, and vertical edge (that’s the edge perpendicular to the way the shutter travels)for the portrait shots. Measure MTF50 in Imatest .
Landscape mode:
The blue curve is the a7R, and the red the a7RII with the mechanical shutter engaged. Looks like the a7RII mechanical shutter is a bit better than the a7R one. The grey curve is the a7RII with EFCS on, and the yellow curve is the a7Rii with silent shutter on. Not much difference between silent shutter and EFCS. Above 1/160 second, you can throw a blanket over all the curves.
Portrait mode:
Not much to choose between the a7R and a7RII mechanical shutters, or between the EFCS and the silent shutter.
Let me point out a couple of things.
It's real close, but the EFCS actually appears to be a hair better than the silent shutter. What's up with that? I suspect it's because the a7RII drops to 12 bit precision in silent shutter mode and the read noise picks up.
This lens doesn't appear to be as sharp as the 180/3.4. How come? I think the main reason is that I couldn't get far enough away from the target.
JimKasson
You are right, Hank. I ran a test:
http://www.dpreview.com/forums/post/56285929
I hear you, and I haven't done the requisite testing to make a definitive statement, but I expect that the upper frequency of effective IBIS operation is lower than the higher resonant frequencies of camera and smallish lenses.
The big reason I didn't test that combination is that EFCS works so well at controlling camera-motion blur when the camera is on a tripod that I consider the problem solved, at least for the photography that I do.
Really big lenses might make enough difference that IBIS could actually help on a tripod, especially in the wind.
I have experimented with mechanically shaking tripods with IBIS on and off:
http://blog.kasson.com/?p=11131
Yep.
Jim
Re: Results with the Leica 280/4 Apo-Telyt
Great data, thanks Jim. I'm troubled by the lower resolution of the silent-shutter. I don't think read noise can be the cause because at ISO 800 read noise should represent a fraction of total noise (read noise+shot noise) for most exposures. Just to be sure, it would be interesting to see a single shutter-speed sampled at ISO 100 between the EFCS and SS.
JimKasson
Yes, you're right. I'm not sure how sensitive the Burns SFR method is to noise, but I do remember that the last time I tried to measure the lost in resolution as exposure goes down, it was way better than I thought it would be.
I'll see what I can do. If I'm going to do only one shutter speed, I can make 16 or 32 images and compute some statistics. There's a lot of noise in the measurements, and that would help measure it and average it out.
What do you think? Portrait mode, 1/40 second?
Jim
Lightfinity Regular Member • Posts: 380
My limited experience so far has been that no industry-developed algorithm is as smart as it could be, but many are more than smart enough to meet design goals.
That said, I imagine the reason that IBIS ON + EFCS OFF could be better is in the case of high speed continuous shooting or non-remote/timer shooting.  In this case the benefit of EFCS is potentially diminished, and the downside of IBIS (on a tripod) would be less prominent since there would be actual vibration to control.
For parity, perhaps take the first exposure from a continuous set as the baseline, then see how the following exposures compare to the first?
 Lightfinity's gear list:Lightfinity's gear list
Sony a9 Sony a7R III Zeiss Batis 85mm F1.8 Sony FE 50mm F1.8 Sony FE 100mm F2.8 GM +2 more
Lightshow
Lightshow Veteran Member • Posts: 7,725
Interesting how at 1/200? That both mechanical shutters produce sharper results than the EFCS.
Thanks for adding some data to the conversation, it speaks louder than the trolls.
I don't have any AF lenses, so if I want a picture, I have to do more than squeeze a button.
http://www.flickr.com/photos/lightshow-photography/
My lenses:
http://www.fredmiranda.com/forum/viewprofile.php?Action=viewprofile&username=LightShow
You can't depend on your eyes when your imagination is out of focus.
Mark Twain
####Where's my FF NEX-7 ?????
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony a7R Leica Elmarit-M 24mm f/2.8 ASPH Leica APO-Summicron-M 90mm f/2 ASPH Voigtlander 15mm F4.5 Super Wide Heliar +20 more
