APS-C Bokeh vs M43 Bokeh?
Started Aug 8, 2015 | Questions
Dillon Frazier
Dillon Frazier Regular Member • Posts: 120
Hey, I just sold my ancient Canon T1i and horribly built 50mm 1.8 and ordered a refurbished GX7 off of evilbay. I am extremely excited about the stylish and compact form factor of M43 as well as all of the modern touches.
My only concern is bokeh though.... I have only shot APS-C and I wanted to know if the difference is very noticeable in day to day shooting. I understand about crop factors and all of that so I'm not looking for scientific explanations, just your personal opinion.
 Dillon Frazier's gear list:Dillon Frazier's gear list
Canon PowerShot A530 Panasonic Lumix DMC-GH3 Nikon D750 Nikon AF-S Nikkor 24-120mm f/3.5-5.6G ED-IF VR Nikon AF Nikkor 50mm f/1.8D +8 more
Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3) Panasonic Lumix DMC-GX7
Skeeterbytes Forum Pro • Posts: 23,182
Re: APS-C Bokeh vs M43 Bokeh?
Am not an APS-C owner but my observation is that format has a slightly easier time achieving smooth OOF transitions and pleasing OOF backgrounds. With µ4/3 a slightly faster and/or longer lens is needed and that tends to mean the more expensive zooms and primes.
The good news is the lens portfolio exists to do just that. The Nocticron, for example, looks wonderful as does the 75/1.8. Manual fans have a lot of choices with the Voigtlanders, etc. My "secret weapon" is the ZD35-100/2.0, a gigantic, amazing bucket of bokehs. And not to overlook hundreds of legacy primes that can be adapted and used with IBIS and high-res EVFs. Something for everybody.
Rick
Bussta Regular Member • Posts: 201
Hi Dillon
I don't think you have much to worry about in that regard. As long as you use fast glass at wide apertures then you will definitely see bokeh. There is a lot of scaremongering towards m/43 systems that makes people very weary about investing in the system. Olympus and Voigtlander have some fantastic lenses that will give nicely rendered out of focus areas, it very much depends on what you want to achieve. The voigtlander 25mm 0.95 & 42.5mm 0.95 have a very special glow to their out of focus areas, it's very classic, whereas the olympus lenses are more modern and sharper but you have the added bonus of autofocus with them.
APSC does give good out of focus rendering say on a 50mm 1.8 which has the effect of an 80mm, but the new lenses for the M43 systems bridge that gap in my opinion and the pros of the smaller system body and lenses far out way the cons.
Randy Veeman Contributing Member • Posts: 799
the reality is...
5
Equivalence says APS will have a slightly shallower DOF. But DoF and bokeh are not the same thing.
Also, the reality is with m43 you might find yourself often using longer focal lengths. A 50mm lens is 100mmEFL instead of 75mm with APS.
If you want shalloer DoF take a step back and use a longer focal length. Then check reviews to see which lenses have the best bokeh.
The APS vs. 43rds will matter little.
 Randy Veeman's gear list:Randy Veeman's gear list
Samsung NX1 Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
JeanPierre Martel Veteran Member • Posts: 3,304
The PanLeica 42,5mm F/1,2 is the "bokeh master" of µ4/3 lenses. It is followed by the M.Zuko 75mm F/1,8. Then, in close-up photography, by the M.Zuiko 60mm F/2,8.
All native Voigtländer lenses, although soft wide open, also have a pleasant bokeh.
M.Zuiko 75mm F/1,8
M.Zuiko 60mm Macro F/2,8
Voigtländer 25mm F/0,95
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
Martin.au
Martin.au Forum Pro • Posts: 14,339
Have a look at sample images of the oly 45mm and Panasonic 42.5mm, f1.7. Those two lenses are most similar to your canons focal length and usage role.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
s_grins
s_grins Forum Pro • Posts: 14,011
You can create bokeh of your liking during PP
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
(unknown member) Veteran Member • Posts: 9,509
Bokeh is more a property of the lens than camera.
That said, even if you just mean out of focus blur or if you do mean Bokeh, m4/3 can do very well with the right lens just as FF can have very deep DOF and little blur with a different lens.
Plenty of lenses with a GX7 will give you what you want I think.
Good luck and happy hunting finding the ones that you like.
leggeron Senior Member • Posts: 1,077
Well the difference between m43 and canon apsc is 1.25 which means that at equal equivalent focal lengths an aperture of 1.8 on the canon will equal a 1.44 aperture on m43 for the same amount of background blur. I use 1.5 apsc crop cameras where the ratio is 1.333 (so 1.8 aperture on apcs equals 1.35 on m43) and yes, i see a noticeable difference.
So the point is you need fater and longer lenses on m43 to achieve the same amount of blur so its harder. But the good news is that m43 has the neccessary lenses. After a while you'll get used to it and just enjoy your new system.
** I usually post from my phone so please excuse any typos, inappropriate punctuation and capitalization, missing words and general lack of cohesion and sense in my posts...
______
http://www.flickr.com/photos/leggeron/
Just so you know how good/bad I am at this.
 leggeron's gear list:leggeron's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GH1 Panasonic Lumix DMC-GF1 +14 more
broody Contributing Member • Posts: 674
APS-C will have shallower DoF, but M43 lenses are considerably smaller... Tradeoffs.
I find the 25mm Panaleica and 45mm zuiko easily give me all the shallow DoF I could want. Wider lenses can fall a bit short of the mark, but I can deal with it.
 broody's gear list:broody's gear list
Canon EOS 5D Mark II Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Canon EF 50mm F1.8 II Canon EF 24-105mm f/4L IS USM +5 more
tkbslc Forum Pro • Posts: 17,526
You'll be fine!
I switched from Canon to a GX7 this past winter and getting blurry backgrounds is not an issue on m4/3.
If you liked the 50mm f1.8 on Canon, you'll be head over heels for the 45mm f1.8. They are like $200 used/$300 new now, so pretty affordable. Check out the flickr pool to appease your fears about blur/bokeh: https://www.flickr.com/groups/1759398@N21/pool/
fannta_79 Junior Member • Posts: 30
Dear Dillon,
probably by this time you already have made your own experiences regarding your question.
As I just got my first MFT gear have done a very rudimentary test at a friend with an APS-C sensor cam and a MFT cam with the very same lens. Distance and aperture and center subject were the same, please disregard ISO and WB as this is about DOF.
Here are two crops of the two photos OOO, cropped and resized (FYI- the original crops have almost the same resolution) for the web, as it was handheld -from the very same distance-. The photos have been cropped two show identical content.
I am not going to disclose now which is which, for me they look pretty close what do you think?
Let me know.
LightCameraAction Contributing Member • Posts: 709
When I purchased a micro 4/3 camera, my philosophy was that a lot of professionals at the time were using f2.8 zooms. I could equal the bokeh they got (actually exceed it) using f1.8 primes.
In reality, I do not find lack of bokeh to be an issue in most cases. For casual shots of kids and family I prefer environmenal portraits that include the environment. I often need to stop down to get enough depth of field. For formal planned portraits, I can choose a location where the background is far enough away to get the desired effect. For other photos, try playing with composition techniques like lighting, scale, negative space, etc to emphasize your subject.
I will leave you with one last thought. Look at depth of field tables/calculators for micro 4/3 and you will find that the depth of field for portraits using a f1.8/2.8 lens is about the width of a human head. The depth of field for a whole body shot is about the width of a human.
RobbieBear Senior Member • Posts: 2,356
fannta_79 wrote:
Dear Dillon,
Let me know.
The thing is:  Like FF or APS-C, the bokeh achieved with micro four thirds cameras depends on the lens used.
Some MFT lenses have excellent bokeh, whereas others (even well regarded lenses) don't.
Having said that, beauty is in the eye of the beholder: many folks will only put up with buttery smooth bokeh whereas others are quite happy with noisy/swirly bokeh.
 RobbieBear's gear list:RobbieBear's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus E-M1 II Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +1 more
Dillon Frazier
OP Dillon Frazier Regular Member • Posts: 120
Wow. Hard to believe this was like 4 years ago. I guess to summarize my experience with m43, I sold my m43 gear after about a year and bought a full-frame Nikon in order to pursue more demanding types of photography. Ironically enough, I really wanted more background blur, which was a reason I left both m43 and aps-c.
M43 is still a great system however and wonderful cameras like the GH series and the g9 make it unique. I now use m43 for part of my video work and am very pleased still.
Thanks for the input!
Dillon Frazier
UppercanadianAcadian Regular Member • Posts: 467
F1.8 primes are great
I get great results from my 45mm f1.8 prime lens. I tried a 75mm f1.8 and that can be even more extreme due to the increased focal length.
I have zero desire to get the f1.2 lenses or use the very expensive and manual operated f.95 lenses the system has available.
for general portraits, the 45mm f1.8 is fantastic
 UppercanadianAcadian's gear list:UppercanadianAcadian's gear list
Olympus PEN E-P5
Kgluong Regular Member • Posts: 341
Oly 45mm f1.8 will meet all your bokeh needs. You can get the lens used under $190 in most places.
https://www.mpb.com/en-us/used-equipment/used-photo-and-video/used-lenses/used-olympus-lenses/olympus-m-zuiko-ed-45mm-f-1-8/
