Panny 100-300 and Oly 750-300 at full length.
Started Aug 8, 2015 | Discussions
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
Re: The doubters
Trevor Carpenter wrote:
I'm a bit surprised that nobody has come on and said here's a really bad shot which proves these lenses are unusable at 300mm
Now, now...why would you possibly want to have complainers provide proof? It would only expose the real source of the complaint.
I am not at all surprised, and I do appreciate this thread and the fine examples debunking such complaints.
It is easier to complain than to work at mastering the technique to produce results such as those displayed here. Okay, now I have to go back to work.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
Roger Engelken
Re: Africa: Oly 75-300 at full length.
I am headed to Africa next May, thank you very much for sharing these fine examples of the capabilities of the lens.
Brent Lossing Forum Pro • Posts: 10,566
Oly 75-300 at 300
Ribbit74 Regular Member • Posts: 428
Re: Panny 100-300 and Oly 750-300 at full length.
Nice. I thought that was an artifact in your moon image, then I realized it was a photobomb by Saturn!
 Ribbit74's gear list:Ribbit74's gear list
Olympus OM-D E-M10 II Panasonic 20mm F1.7 II Olympus 12-40mm F2.8 Pro OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +4 more
boxerman Senior Member • Posts: 1,946
daddyo wrote:
I remember seeing these images before -- it's a pleasure to see them again. I love the first shot especially -- excellent job, and a perfect example.
I also remember that you commented on the cheetah. I was so pleased, give your skills as a photographer. Awesome. Thanks.
The BoxerMan
 boxerman's gear list:boxerman's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +4 more
Fri13 wrote:
In those temperatures and distances you wouldn't really benefitten much from a sharper optics as heatwaves anyways blurs everything.
The problem is that too often people blame optics while there simply is too much air mass between camera and a subject and it is big limiter when long telephoto objectives can be used.
Just to share my experience, not to challenge. Of course, there is thermal degradation. But these are not cherry-picked examples. I have NEVER experienced serious thermal degradation on our safari trips. I don't know exactly why. My guess is on a reasonably sized target (cheetah, for example) that fills the frame reasonably, you just get rather minimal degradation, compared to, say, shooting down the railroad tracks at some nebulous target. It might be dry air, too, though our last safari was two weeks long. Must have been moist PART of the time. On other trips (New Zealand) I do certainly notice haze at a distance, but then still no distortion. I personally think the problem is easy to demonstrate, but less important in practice, at least for what I shoot. Whether showing problems is beyond the sharpness of the 75-300, I just don't know. Anyway, it's not me blaming the optics!
The BoxerMan
A friend of my who went on safari before we did said it was a life-changing experience. Truly it was for us. We were "hight" for months afterward. Of course, that depends on your interests and personality. But, I expect you will REALLY enjoy it.
The BoxerMan
Michael J Davis
Michael J Davis Veteran Member • Posts: 3,755
Not stopping (down...)
I do think you should have insisted on 'at full aperture' - most lenses are OK when stopped down a bit. (As you know!)  I only buy lenses for use at full aperture, otherwise why buy them?
I'm still v happy with my ancient 45-200 and am sitting on the fence re a 300; was waiting for the Oly 300 to see what that is like. But now I'll have to wait for the Panny 100-400! Then please can we all go through this again?!
Mike
Mike Davis
Photographing the public for over 50 years
www.flickr.com/photos/watchman
 Michael J Davis's gear list:Michael J Davis's gear list
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +6 more
Lieslayer Regular Member • Posts: 369
Re: Not stopping (down...)
Mike
Yes...
 Lieslayer's gear list:Lieslayer's gear list
Sony RX100 Sony RX1 Olympus E-M1 Sony a7R Olympus M.Zuiko Digital ED 60mm F2.8 Macro +4 more
howardfuhrman Veteran Member • Posts: 4,153
While there are some good photos posted taken at 300mm, prior to going on safari, I saw many comments that recommended that 300mm should be avoided. The following one was taken with my 100-300 at 240mm. I recollect that the camera was on a monopod. It is reasonably sharp shot - not super sharp.  If I spent more time, I may have found a better photo.
(unknown member) Senior Member • Posts: 1,001
HIF at 500m
Taken from our veranda this morning. Despite the heat waves and the smoke & haze not too bad I think. The chopper is about 500 metres away, on its way to a small lake to take in water.
Corkcampbell
Corkcampbell Forum Pro • Posts: 18,895
"it is soft at the long end especially when the light is low and my shutter speed is slow."
Wow! Someone actually said that; was it meant as a joke? It's amazing that companies have designed glass that actually gets softer as the lighting changes... the marvels of technology.
"Knowledge is good." Emil Faber
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony RX100 III Sony RX10 III Leica C-Lux +8 more
cainn24 Veteran Member • Posts: 4,892
I have no experience with the 100-300, but with the 75-300 II, at 300mm, there is really no point in stopping it down unless you specifically need more DOF.  This is because doing so yields no significant improvement in detail resolution.  I have confirmed this with some controlled and comprehensive testing of my own sample, and SLRgear reached the same conclusion with the sample that they tested as well.
Besides there are plenty of f/6.7 (wide open) samples in this thread, from that lens, that are perfectly usable.
sean000 Veteran Member • Posts: 7,727
Mike
I still have a 45-200mm as well, and on the whole I have been pretty pleased with it. Mine is very sharp up to 150mm and still pretty darn good at 200mm (especially stopped down a tad). My biggest issue with it is light falloff and the fact that it's diameter takes up more room than I'd like in my m4/3 shoulder bag.
I also have a Nikon 300mm f/4 that doesn't get much use since my Nikon gear sits on the shelf most of the time. Since I shoot 95% of my photos with an E-M5 these days, I'm thinking about selling that and replacing the 45-200mm with an Oly 40-150mm f/4-5.6 R for daily carry stuff (lighter and smaller than the 45-200mm) and the 75-300mm for wildlife. I'm also tempted to get the 40-150mm f/2.8 Pro with the teleconverter, but it would probably sit at home almost as often as my Nikon gear.
Sean
 sean000's gear list:sean000's gear list
Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus OM-D E-M5 +6 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
Not unusable but it can be a challenge...
I got some really nice results from this lens. But at the same time handholding 300mm isn't all that easy...
The E-M5 IBIS often saved the day!
300mm f/6.7 1/40s
I really prefer situations with more light. A shot like the following is easy enough...
300mm f/8 1/750s
If you didn't know yet, I like frogs (this one was in our back yard).
300mm f/8 1/350s
It gets more difficult as heat-induced turbulence increases and you have long distances:
300mm f/8 1/400s
Here it was so bad that no shot came out sharp despite plenty of light and fast shutter speed:
300mm f/8 1/640s
The bad reputation is to a large extent a consequence of heat-induced turbulence over long distances. It's not a lens problem. It's not a hand-holding problem. There is no solution for this at all.
Enjoying the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
bradevans
bradevans Senior Member • Posts: 1,029
Re: Not unusable but it can be a challenge...
300mm f/6.7 1/40s
300mm f/8 1/750s
300mm f/8 1/350s
300mm f/8 1/400s
300mm f/8 1/640s
this
 bradevans's gear list:bradevans's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-G9 +14 more
Michael J Davis
Re: The doubters
Lieslayer wrote:
No doubt...
Excellent!!
Mike
Mike Davis
local novice Regular Member • Posts: 472
It works just fine for people/action shots as well (when i don't mess up).
 local novice's gear list:local novice's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +3 more
khoss Veteran Member • Posts: 4,946
I find they both shine wide open at the full focal length:
75-300:
100-300:
Would I like longer and faster - sure - who wouldn't - but the effective field of view and the small size and low weight allow me shots that I just couldn't get with a bigger rig.
Kurt
 khoss's gear list:khoss's gear list
Olympus Tough TG-3 Panasonic LX100 Sony RX100 V Canon EOS 50D Olympus PEN E-PL1 +4 more
gary0319
gary0319 Forum Pro • Posts: 10,540
75-300:
100-300:
Kurt
I find that I'm able to shoot the P100-300 at full length with my E-M5II, but needed to pull it back to 286 with my GX7 to retain the sharpness. Were both of your pics done with the M5II?
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
