Panny 100-300 and Oly 750-300 at full length.
Started Aug 8, 2015 | Discussions
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
Lots of posts recently have suggested that these lenses are unusable at the long end.  I would agree that 300mm may not be their sweet spot but here is a big difference between a slight drop off in IQ and unusable.  I thought I might persuade you all to post some 300 mm shots that defy the unusable tag.
Of course be prepared that someone my post a critique that says it's unusable
Here's one from me.
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Chi Pham
Chi Pham Senior Member • Posts: 1,163
Re: Panny 100-300 and Oly 750-300 at full length.
Trevor Carpenter wrote Lots of posts recently have suggested that these lenses are unusable at the long end. I would agree that 300mm may not be their sweet spot but here is a big difference between a slight drop off in IQ and unusable. I thought I might persuade you all to post some 300 mm shots that defy the unusable tag.
Here's one from me.
That's very sharp at 300mm!
Lens variation may account for some that are not happy.
Here's mine but a different lens.  Not as good but still usable.
Tamron @300mm
Tokina 300mm
Best
The higher consciousness is colorless, odorless, and without form. Therefore, it's prudent to not judge others based upon their physical qualities.
 Chi Pham's gear list:Chi Pham's gear list
Olympus E-3 Olympus E-500 Panasonic Lumix DMC-GX7 Sigma 70-200mm F2.8 EX DG Macro HSM II Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 +8 more
Robiro Veteran Member • Posts: 6,813
Pannie at 300mm
Pannie 100-300mm at 300mm attached to ancient GH2. Developed from RAW, cropped a bit and downsampled to FHD.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 Olympus 40-150mm F2.8 Pro Sigma 30mm F1.4 for Micro Four Thirds Olympus 100-400mm F5.0-6.3 IS
aodi
aodi Senior Member • Posts: 1,678
Olympus OMD E-M5 II and Olympus 75-300, 300 mm, both JPEG OOC, some crop.
Anatoli
www.transformingphoto.com
daddyo Forum Pro • Posts: 12,670
Trevor...
17
I personally believe that most people who make negative claims about these two lenses simply don't know how to use them properly. There are too many factors that can effect the sharpness of an image captured at a 600mm equivalent FOV -- not the least of which is refusing to use a tripod.
My Oly 75-300mm is sharp, wide open at 300mm -- I have way too many images to prove that. If I get an image that is not very sharp, the problem lies with my technique or the photographic limitations at the time of capture -- low light/shutter speed, subject movement, etc.
Here are just a few sharp images I've gotten with my lens at full zoom:
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Olympus 12-40mm F2.8 Pro
gary0319
gary0319 Forum Pro • Posts: 10,540
Re: I Agree with Trevor
It took me a while to learn the vagaries of my Panny 100-300. For instance...when I shot it with my GX7 I needed to back it off to 286 to minimize a reduced IQ, also 7.1 was the sweet spot and I needed to keep the speed up above 1/600.
Now I use it on my Olympus E-M5 II and it's sharp right out to 300mm, 6.3 works fine and I can shoot it a little slower.
Here's some of my first results with the P100-300 on the M5II.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
peppermonkey Veteran Member • Posts: 5,204
I understand the shutter shock variable...
but why would the lens be bad with the GX7 at 300mm compared to the E-M5 MKII assuming shutter speed was fast enough?
Hubert
My non-digital gear: Agfa Isolette, Ricoh Ricohflex VII, Voigtlander Bessa R, Voigtlander Bessa L, Zorky 4, Fed 2, Konica Big Mini, Konica Auto S2, Pentax K1000, Yashica Electro 35 GX, Recesky
http://farm3.static.flickr.com/2034/2457111090_00eafbf8a4_m.jpg
http://www.flickr.com/photos/peppermonkey/
 peppermonkey's gear list:peppermonkey's gear list
Panasonic Lumix DMC-TZ3 Sigma DP2 Sony RX100 II Pentax K110D Panasonic Lumix DMC-GF1 +11 more
Bobby J Veteran Member • Posts: 5,191
This was made through a double pane window.  It's about a 10%.  The Blue Bird is plenty sharp.
BJM
 Bobby J's gear list:Bobby J's gear list
Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH Olympus 12-100mm F4.0 Olympus E-M1 Olympus E-M1 II +9 more
Martin.au
Martin.au Forum Pro • Posts: 14,339
Ahaha. Game on. Lots more in my gallery.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
kamiyama
kamiyama Forum Member • Posts: 87
Very nice, Martin.
I've found the Panny 100-300 as sharp as my old Oly 50-200. Here are a couple of shots with the Panny at 300mm. All hand held.
Male Costa's Hummingbird
AT6 Texans at a Fly-In on Orcas Island
Rufous Hummingbird Powering Up
Rufous Hummingbird at Delphinium
 kamiyama's gear list:kamiyama's gear list
Olympus OM-D E-M5 Olympus E-M1 III Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +22 more
gary0319
Re: I understand the shutter shock variable...
I can't say for sure, but subjectively, I think the focusing algorithm of the E-M5II just resolves the information from the lens faster and more accurately. I'm sure those who know more about this will no doubt prove me wrong, but I know the E-M5II gives me sharp images,end to end with both my Panasonic 45-150 and my P100-300, both using the lens OIS.; something I could not get with my GX7.
Dave Lively Senior Member • Posts: 1,938
With my 100-300 I stop down to f7.1 or f8 whenever possible at 300mm. Even stopped down and on a solid tripod the lens is a little soft but is far from unusable. If I am taking a picture that is going to be downsized to 1200 pixels or less and can fill the frame it is usable even wide open.
All of these were exported from Lightroom with output sharpening set to high but no other sharpening applied.
This is a friend's dog. It was shot handheld at a lower shutter speed and higher ISO than I would have liked and wide open. But downsized like this it looks OK to me.
A heavy crop of a mockingbird in my backyard. Stopped down a little and mounted to a solid tripod. A little soft but exactly what I would expect for a $500 lens. I am also showing the uncropped photo to show how heavily it was cropped.
Henry Richardson Forum Pro • Posts: 21,959
Lots of people don't have a clue how to shoot telephoto
9
Some people say they don't like these lenses and, like all lenses, even the most expensive ones, there can be sample variation. In some cases shutter shock may enter the picture too. Now that that boilerplate caveat is out of the way... People often say the same things about the Olympus 14-150mm. I have noticed that some of the people who say things about it not being sharp at the long end use words like "it is soft at the long end especially when the light is low and my shutter speed is slow." Duh. Some people mistake blur caused by camera or subject movement with an unsharp lens and don't even know the difference.
Henry Richardson
http://www.bakubo.com
Chi Pham
If you recall, DXO results from the GX7 is worse than other m43.  This they mentioned is due to the Stack Sensor AKA AA filter glass.
Corkcampbell
Corkcampbell Forum Pro • Posts: 18,895
Why would you use lens OIS on the E-M5II instead of the camera's IBIS?
Why would you use lens OIS on the E-M5II instead of the camera's IBIS? Everything I've read suggests using the camera stabilization system, and turning OIS off (on lens or via menu). So, when I bought a 75-300 recently it worked very well. I have a 100-300 but only tried it on the new Oly briefly and I wasn't impressed. However, I didn't spend much time with it. The 75-300 was purchased because I found I needed the longer length for an event while I was traveling and the Pany lens had been left at home due to its size and weight. I have used a 45-175 with camera IBIS set as priority and it worked well.
Just curious.
"Knowledge is good." Emil Faber
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony RX100 III Sony RX10 III Leica C-Lux +8 more
Lieslayer Regular Member • Posts: 369
Re: Panny 100-300.
 Lieslayer's gear list:Lieslayer's gear list
Sony RX100 Sony RX1 Olympus E-M1 Sony a7R Olympus M.Zuiko Digital ED 60mm F2.8 Macro +4 more
gary0319
Re: Why would you use lens OIS on the E-M5II instead of the camera's IBIS?
Just curious.
I've tried it both ways with the P100-300 on my E-M5 II and prefer the OIS. I found no appreciable difference in image quality, one way or the other, but I seem to get a more stable image in the EVF by using the Panny OIS.
gary0319
Re: Chipmunks made me smile (nt)
No text.
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
Re: Trevor...
So much for the negative claims...a picture is worth a thousand words, and you have more than one picture.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
Roger Engelken
Re: Panny 100-300.
Did you forget to pay the peacock a sitting fee?
He does not seem amused.
