Ever wonder why Nikon doesn't have f/1.2 AF lenses and Canon does?
Started Aug 6, 2015 | Discussions
Kadidal
Kadidal Regular Member • Posts: 203
This very nice piece by Nasim explains why -- interesting stuff here on the differences between the Canon and Nikon lens mounts (even for those of us who could never afford to spend on a f/1.2 even if Nikon made one!):
https://photographylife.com/nikon-f-vs-canon-ef
 Kadidal's gear list:Kadidal's gear list
Nikon D750 Nikon D500 Tamron SP 24-70mm F2.8 Di VC USD Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.4D +6 more
Mach Schnell Senior Member • Posts: 2,959
What about the Nikkor Noct 58mm f/1.2?
 Mach Schnell's gear list:Mach Schnell's gear list
Nikon Z7 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon 85mm F1.8G Sigma 150mm F2.8 EX DG Macro HSM +13 more
lickity split
lickity split Veteran Member • Posts: 6,037
Re: What about the Nikkor Noct 58mm f/1.2?
It's not AF
 lickity split's gear list:lickity split's gear list
Nikon D850 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Micro-Nikkor 200mm f/4D ED-IF Nikon AF-S Nikkor 300mm f/2.8G ED VR II Nikon AF-S Teleconverter TC-14E III +11 more
lickity split
Re: Ever wonder why Nikon doesn't have f/1.2 AF lenses and Canon does?
No but I wondered why Nikon has nothing like the MP-E 65
Kadidal
OP Kadidal Regular Member • Posts: 203
That 65mm manual-focus is the coolest of macros -- near the top of a lot of "Why Canon?" lens lists.
brightcolours Forum Pro • Posts: 15,883
No contacts, and a too small back element (heavy mechanical vignetting, causing cats eyes and swirly bokeh).
You forgot the 55mm f1.2 and 50mm f1.2 by the way.
thelenspainter Senior Member • Posts: 1,906
Canon f/1.2 lenses have mechanical vignetting too, but in their case it's the mirror box that causes it. To me it looks even worse than Nikon because you get these square cut-off looking bokeh balls at the edges of the frame.
 thelenspainter's gear list:thelenspainter's gear list
Leica TL2 Nikon Z7 Leica Summilux-TL 35mm F1.4 ASPH Leica TL 18mm F2.8 Nikon Z 24-70mm F4 +4 more
Yes, but quite a bit less.
That is not true for the 1.2 lenses
That only goes for the 50mm f1.0?
Rexgig0
Rexgig0 Veteran Member • Posts: 6,927
MP-E 65mm can be adapted to Nikon.
There was a thread regarding this here on DPR, within the past five years. Keep in mind that the MP-E 65mm, even on Canon cameras, cannot focus to infinity, and is normally used on a focusing rail. This is not really for chasing bugs around the garden.
I wear a badge and pistol, and make evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, and PJ. I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +56 more
lickity split
Re: MP-E 65mm can be adapted to Nikon.
I did a pretty thorough search on this awhile back and came up with nada. Plenty of reasons why it cant work.
http://photo.net/nikon-camera-forum/00ROPw
BGD300V1
BGD300V1 Senior Member • Posts: 2,383
As a Nikon shooter I never really looked in to this lens but found the range interesting.  I didn't realize that its maximum focus distance was about 4 inches.
Given that, and the price, using a 60mm Micro-Nikkor for up to 1:1 and putting it on a bellows is an excellent solution.
 BGD300V1's gear list:BGD300V1's gear list
Nikon Coolpix P7100 Nikon 1 V2 Nikon D500 Nikon 1 J5 Nikon D6 +16 more
Rexgig0
I now wish I had bookmarked that thread, as this is, at least, the second time this has been discussed here. I had little interest at the time, however, as I then used only Canon cameras for macro, and had no interest in in a lab-type copy-stand set-up. If I remember correctly, the adapter was custom-made, and may, or may not, have involved a bellows. It was not something I would haul into the field for shooting insects, reptiles, and amphibians.
More than one Nikon shooter, including a local (Houston, Texas) member of the now-defunct Pixtus.com forum, who wanted to use the Canon MP-E 65mm, has simply bought the lens, along with a Canon camera, to use as a dedicated macro rig. (He brought his 60D and MP-E 65mm lens, along with his Nikon + 24-120mm Nikkor, to a local meet-up.) There is much to be said for staying with just one platform for running-and-shooting, but macro shooting is, usually, relatively slow and deliberate, in comparison.
sandy b
sandy b Veteran Member • Posts: 9,411
No
Of all the things I could sit around and contemplate, that would be pretty low in the list.
 sandy b's gear list:sandy b's gear list
Nikon Coolpix A Nikon 1 J1 Nikon D750 Nikon D7500 Nikon Z50 +14 more
joejack951 Senior Member • Posts: 2,682
Until only very recently (D810), Nikon's have lacked an electronic first curtain shutter which is basically a necessity for sharp photos at the magnifications that lens provides.
 joejack951's gear list:joejack951's gear list
Nikon Coolpix P7700 Nikon Coolpix AW100 Nikon D300S Nikon D3S Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR +5 more
Matsu Senior Member • Posts: 2,365
If the throat diameter is large enough for manual focus lenses, then it is large enough for autofocus lenses, since the AF motor and gearing sits in the barrel, not the mount throat. I like Nasim's articles, but he's got it slightly wrong here. I suspect the real reason has to do with a trade off between demising returns, cost, and AF performance. E lenses will give them another degree of freedom in the design and placement of lens elements, but I'm not sure f/1.2 is really a priority for them.
 Matsu's gear list:Matsu's gear list
Panasonic Lumix DMC-GX8 Panasonic 20mm F1.7 II Nikon D800 Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED +9 more
Rexgig0
Look at the VERY thin parts on the 50mm f/1.2 AI-S.
Parts apparently have to be very, very thin at the mount, including the finger-like part that engages the metering system, and the metal end of the mount, itself, on an f/1.2 lens. Keep in mind that I am not an engineer, just judging by eye. The glass element, too, seems quite vulnerable, as it protrudes from the mount.
"E" lenses would, seemingly, be easier to engineer if built with f/1.2 maximum aperture, but again, I am not an engineer.
Re: Look at the VERY thin parts on the 50mm f/1.2 AI-S.
The f mount is almost certainly not limiting the maximum aperture of the lens.  Bigger apertures than even f/1 have gone through it, and with longer focal lengths than 58mm
See here
http://www.muellerworld.com/exhibits/fast_lens/
Now none of these are AF, and all are converted, fixed aperture designs, but the mount isn't restricting the aperture.
A big aperture doesn't necessarily have to have a directly proportional rear element depending the design.
With both AF and aperture controls being though electronic contacts, there are no physical limitations, but that doesn't make it necessarily practical to do.
jgitomer Regular Member • Posts: 201
Assuming the Canon f/1.2 lens has a maximum focusing distance of 4 inches (roughly 100mm) it can only be used to shoot inanimate objects.  That being the case there is no need for f/.2 or, for that matter f/2.8.
So, all f/1.2 gives you is bragging rights, but from a practical standpoint very little, if any, real value.
Before you respond with the fact that with an f/1.2 lens you can focus in conditions with less light bear in mind that when shooting inanimate objects you can always use a flashlight (or a head lamp if you need both hands for the camera) to illuminate the subject and get accurate focus.
Jerry
 jgitomer's gear list:jgitomer's gear list
Nikon D600 +5 more
