Canon EF 70-300 4-5.6 IS USM
Started Aug 5, 2015 | Questions
Dave Sparks Senior Member • Posts: 1,350
Re: Troll Alert !!!
Alexsfo wrote:
tatslau wrote:
Alexsfo wrote:
tatslau wrote:
This guy doesn't even own a Canon!
Wow, what a warm welcome for a new Canon FF user... No opinions welcome, only Dxomark data.
My apologies! I saw your controversial post and you haven't updated your gear list to contain the 6D at that moment, so I jumped to conclusion too quickly.
But I suggest you should choose the right gear for the right job. Using an FF cam for video is already a waste, but using a commonly know inferior lens doubles the waste.
For good videos, you need STM lenses on a crop sensor cam, best such combination would be the 70D with 55-250 STM.
It appears that FF is good enough for Hollywood productions so I am very much impressed with 6d video especially in low light. I am using Manual focus for video. My RX100 takes care of auto everything. I have my doubts that 70d with STM will provide smooth continuous AF in low light and with its poor high ISO performance, I bet videos are much noisier than 6d.
The 5D Mk II has been popular in movie work ---
http://www.imdb.com/list/ls059550382/
 Dave Sparks's gear list:Dave Sparks's gear list
Canon G7 X II Canon EOS 90D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm F4L IS USM +18 more
Alexsfo Senior Member • Posts: 2,362
Re: L vs non-L
Finally got a chance to shoot with both non-L IS and L versions of 70-300mm. I was very impressed with non-L performance on 6d. I was preparing for the worst after reading some reviews. In reality, the difference between two lenses at 50% view is not immediately perceivable. Also, non-L performs very well up to 225mm where it is still f/5! As far as IQ, the biggest difference between two lenses is that L has more contrast (not always obvious), warmer colors, better color fidelity, more details at 100% view. Bokeh is surprisingly not all that different between the two. On the mechanical side, L has manual focus override feature, non-rotating front element, weather sealed, probably faster AF (I couldn't tell the difference right away), much thicker and heavier. What I discovered is that non-L images post-process quite nicely - all I need is slight boost in contrast/vibrance and smart sharpening. I do not need full 20MP resolution for occasional telephoto. What I do want is to retain that 3d look which I love from L lenses and this non-L lens still got it to my eyes. I do not want to clog my hard drive and memories with dull, washed out, lifeless captures.
IS is incredible on non-L. I could not tell the difference between the two. Moreover, non-L'IS works so much better for me during video. I found L lens too heavy for prolonged video use so the camera shake escalates quickly. With lightweight, non-L lens, my videos are much more steady. I'd say for professional use, L is the way to go. For enthusiasts like me, I am finding that non-L is a gem especially for the price (used). Maybe a lot of negative reviews are coming from people who used this lens on a crop? It probably performs better on a modern FF like 6d. I am also curious if Canon has improved some coatings or other elements in the lens since it was first introduced? I've been testing a recent production unit.
original jpeg OOC
slight processing in PS - levels, vibrance and sharpening
non-L, 300mm f/5.6
non-L, 300mm f/8
L, 300mm f/5.6
L-crop, 300mm f/5.6
non-L crop, 300mm, f/5.6
Note: non-L lens sharpens up a little at f/8 but at f/11 it looks slightly worse in the center (probably diffraction). I would use it a f/8 if light permits, f5.6 is perfectly acceptable if needed for DoF.
 Alexsfo's gear list:Alexsfo's gear list
Canon EOS 5D Mark IV Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM Canon EF 24-70mm F4L IS USM +4 more
hrblaine Forum Member • Posts: 92
Re: L vs non-L
"For enthusiasts like me, I am finding that non-L is a gem especially for the price (used)."
When I went digital, the first zoom I bought was the 70-300 IS USM.  IMHO it was a good buy!  I still use it when I need more reach than I can get from my 70-200 F4.  I've even used with a 1.4 extender with decent results.  Of course I'm an amateur with 85 yo eyes, ymmv.
BlueRay2 Forum Pro • Posts: 14,816
Re: Canon EF 70-300 4-5.6 IS USM
Dave Sparks wrote:
Another from the same bird series at f8:
now, that is nice shot, Dave
