Samsung EX2F Raw vs RAW vs RAW+the various JPG modes
Started Aug 3, 2015 | Discussions
Pan Jurek Mr Jerry New Member • Posts: 15
I looked and looked. How can one shoot pictures in Black and White while the camera is set to one of the RAW modes? Am I missing something. It seems that when the camera is in RAW mode, it will shoot in Color, JPG an the various JPG / RAW or RAW + modes but not in Black and White. It seems that it will ONLY shoot in Black and White while in the various JPG modes. What am I doing wrong?
Peadingle
Peadingle Senior Member • Posts: 1,342
Re: Samsung EX2F Raw vs RAW vs RAW+the various JPG modes
Shooting in RAW gives you all the information recorded by the sensor for you to do with what you want, rather than the camera doing it for you, as it does with jpgs. So that means with RAW, you convert the shot to black and white, yourself, to your taste, rather than the camera doing it for you. Shooting in black and white isn't simply a matter of removing the colour.
 Peadingle's gear list:Peadingle's gear list
Samsung TL500 Canon PowerShot G1 X Panasonic Lumix DMC-G2 Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH +8 more
ttbek Veteran Member • Posts: 4,869
You're not doing anything wrong, and neither is the camera (if I understood you correctly).
Raw files do not undergo the processing to make jpegs, so they don't go through the black and white conversion. If they did, then many people would be very upset about having lost the color from their raws. The raw file is meant to represent as close to the sensor data as is reasonably possible, though sometimes a manufacturer will tweak things a little, even when it may look like the data was changed, it's usually not, rather some metadata was included that the raw processor in a program like Lightroom is reading and following (e.g. lens distortion correction info). Here is what those modes do on most cameras:
Jpeg: you get a jpeg with all the jpeg processing applied, black and white in your case.
Raw: you get a raw file that depends on your camera manufacturer (e.g. .cr2 for Canon, etc...) this has no jpeg processing done to it. A white balance is chosen by the camera for display, but it can still be charged to anything. This will not be black and white as that setting is only about jpeg processing. The only way to have a black and white raw is to use a monochrome sensor, Leica makes such a camera.
Raw+/raw + jpeg: The name can vary slightly, what this does is to save both the unprocessed raw and the processed jpeg. So you should get a color raw and a black and white jpeg in your case. If what you meant in your post is that when using this mode you don't get the black and white jpeg.... then that is pretty unusual.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
OP Pan Jurek Mr Jerry New Member • Posts: 15
Okay. Maybe I was misunderstood. What I wanted to know was why when I shoot in RAW or any of the RAW + modes, I cannot shoot in B/W. I can shoot I RAW mode in B/W with my Fuji X10 and my Pentax MX-1. With my EX2F, I can only shoot B/W when in *.JPG mode and NOT in RAW Mode. One would figure that when designing a camera with RAW mode, RAW+ mode and *.JPG and an articulating screen with a F/1.4 Schneider - Kreuznah lens the engineers would NOT omit this function.
Peadingle
I've just been looking through the menus of my EX1. I cannot find a setting for shooting B+W but in Photo Style, I can select 'Classic' which gives a B+W picture. I can choose that setting regardless of whether I am shooting RAW or not.
Skipper494 Forum Pro • Posts: 11,264
Firstly, the EX2F is one of the very few cameras that has little or no compression of RAW files, which gives a very clean image. Shoot RAW, convert to 16-bit tiff in Samsung's converter, post process in whatever suits you and change to grayscale, even in free FastStone. This shot was taken RAW with my D700, converted to 16-bit tiff in ViewNX2 and then into grayscale in FastStone.
Old barn at Montrose.
Field near Maryhill.
Peadingle
I use ADOBE DNG converter. Does the Samsung converter produce better results?
Did not open the C.D. yet as I still can return the camera if I am not satisfied with it. Right now I am using Adobe Elements 11. Will have to try FastStone. I do not covert from *.SRW to *.DNG. I just use Elements 11 to convert from *.SRW TO *.JPG.
I thought that the whole purpose of RAW files was:
1.) The file is uncompressed.
2.) The file let's you "develope" it the way you want to.
3.) You mean to tell me that there actually are RAW files that are compressed?
