"Toploader" Case For G7 - Lowepro Rezo TLZ 10
Started Aug 2, 2015 | Discussions
Terminal Boy Senior Member • Posts: 1,292
Just picked one of these up for my G7 and it's a very nice fit with enough padding to be used both as intended as also as a padded insert for a larger bag or pack.
https://www.lowepro.co.uk/brands/lowepro/rezo/rezo-tlz-10/pd255/
G7 sits in a very similar position to the camera shown in the above link with the following lenses fitted:
- 15mm f1.7 PL with lens hood fitted
- 30mm Sigma f2.8 with lens hood fitted
35-100mm Panasonic f4-5.6 with lens hood fitted in ready to shoot, not stowed position.
 Terminal Boy's gear list:Terminal Boy's gear list
Panasonic Lumix DMC-GM5 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +2 more
Panasonic Lumix DMC-G7 Panasonic Lumix G 42.5mm F1.7 Panasonic Lumix G Macro 30mm F2.8
Jacques Cornell
Jacques Cornell Forum Pro • Posts: 16,262
Re: "Toploader" Case For G7 - Lowepro Rezo TLZ 10
Is it tall enough for a mounted 35-100 f2.8 with hood reversed?
The way to make a friend is to act like one.
www.jacquescornell.photography
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-LF1 Panasonic FZ1000 Panasonic LX100 Panasonic Lumix DMC-GX8 Sony a7R III +54 more
OP Terminal Boy Senior Member • Posts: 1,292
I don't have one of those to try it, but a quick questimate based on:
1. Where the G7 sits inside the case with the 35-100 f4-5.6 hood mounted ready to shoot.
2. The 35-100 f4-5.6 hood mounted ready to shoot being 75mm from mount face to front of hood.
3. The 35-100 f2.8 being 100mm long
Says that the EVF would sit 25mm too high in the case with the 35-100 f2.8 fitted for the flap to close properly.
You'd need the extra 2.6cm depth of the TLZ 20 to fit with that lens.
brentbrent Veteran Member • Posts: 5,766
I bought one of these on eBay for $14. It works with either GX7 or G7 with 14-140 v.II mounted, with hood reversed (pretty much a perfect, snug fit in all dimensions). The 35-100 f/2.8 is almost an inch longer than the 14-140, so that's questionable, IMO. You might be able to pull the cover over the camera even if it is sticking up out of the case a bit and fasten the buckle, but I think it would be a very tight fit if it works at all.
It's a nice, compact case with the 14-140, and room for a battery or two in the small front pocket, at a great price.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
