Digital Photo Professional
Started Aug 1, 2015 | Questions
Lionel Johnson Senior Member • Posts: 1,590
I see that there is a new version of DPP available.  4.3
I am still using the 350D (XT).
What version of DPP should I be using - I find some of the updates confusing?  I get the feeling that I am updating the software for no good reason as my old camera may not be compatible with the newer versions.
Lionel
http://www.flickr.com/photos/lionel_johnson/
'It may be that your purpose in life is to serve as a warning to others.'
Canon EOS 350D (EOS Digital Rebel XT / EOS Kiss Digital N)
Oilman
Oilman Veteran Member • Posts: 3,375
You can download the latest version...
and keep the old version on your computer just in case. I use PS and LR. At $9.99/mo. they are a bargain
The picture is the score. The processing is the performance - Modified from Ansel Adams
http://www.flickr.com/geofiz
 Oilman's gear list:Oilman's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EOS 5DS R Canon EF 50mm F1.4 USM Canon EF 500mm f/4.0L IS USM +7 more
Peter63 Senior Member • Posts: 1,529
Re: Digital Photo Professional
DPP 4 does not support the 350D. You should be using DPP 3. Canon has been adding older models to the list but there is no way to know if they will add support for your camera.
 Peter63's gear list:Peter63's gear list
Canon EOS M Canon EOS Rebel SL1 Canon EOS M5 Canon EOS 77D Canon EOS M6 +30 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
3.14.xx
+1
Latest is 3.14.xx where the .xx depends on your computer OS.
examples:
  • Windows XP (32 bit) => 3.14.15 (10/14/2014)
  • Windows 7 (32 and 64 bit) => 3.14.48 (3/30/2015)
Download the updater from Canon USA
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
OP Lionel Johnson Senior Member • Posts: 1,590
Thank you.
That ties in with what  I have found.
I have both DPP 3.14.41.0 and 4.1.50.0.
I use DPP 3
I had a look at DPP 4 and it did not seem to work with my pictures.
Now I know why.  Thanks again.
Lionel
Re: 3.14.xx
Lemming51 wrote:
+1
examples:
I have just upgraded to Windows 10.
I am currently using DPP 3.14.41.0
Should I upgrade to 3.14.48?
Lionel
