IQ difference at nearly same settings?
Started Jul 30, 2015 | Questions
rolfaalders Forum Member • Posts: 51
Been to the zoo, today.
Not really great pictures, but I was able to get some really good practice
I've got a question regarding the Image Quality of 2 pictures with nearly the same settings, but with really different image quality. I'm trying to figure out why the IQ is so different. Can you explain?
100% crops (screenshot) of the unprocessed images.
The face of the black/brown monkey has a lot of noise, is washed out and also some purple glow can be seen around the blown out highlights.
Fuji X-M1 XF60mm
Settings: ISO 800, 60mm, 1/200th, F2.4
The IQ of the white monkey seems a lot better. No purple glow, but that's because there are no blown highlights, I guess.
Fuji X-M1 XF60mm
Settings: ISO 800, 60mm, 1/500th, F2.4
Reasons for the difference I can imagine:
1. Focus on the black/brown monkey is not good, resulting in less contrast (washed out)
2. Black/brown monkey is much further away from the camera, resulting in reduced quality. (the white monkey is only 2 meters away; the black/brown monkey is much bigger, but probably 15 meters away).
3. Backlight conditions at the Black/Brown monkey
Also, the 2 final images attached:
Can you explain why the quality is so much different? Is it because of the reasons I already listed, or can you give me other reasons?
Looking forward to your comments
Thanks!
 rolfaalders's gear list:rolfaalders's gear list
Fujifilm X-M1 Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +1 more
Fujifilm XF 60mm F2.4 R Macro Fujifilm X-M1
Timefreezer BE Regular Member • Posts: 128
Re: IQ difference at nearly same settings?
It's the difference between good and bad light.
In the first (black monkey) you have a lot of light between the leaves falling right into your lens. Bad backlight. The second (white monkey) has good quality light. Photography is all about light.
Lucky the best photo, the second one (I like it!) has the good light.
nixda Veteran Member • Posts: 5,515
Besides the potential reasons you listed, which may or may not affect the IQ much, keep in mind that dark regions generally have a much lower signal-to-noise ratio than bright regions due to basic principles of photon counting statistics (i.e., basic physics). Despite the fact that the absolute noise level in darker regions might very well be lower than that in bright regions, it is generally much more visible, because the signal is also much lower.
 nixda's gear list:nixda's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +1 more
Dark monkey isn't in focus
At least it looks like it. Unfortunately, the original file isn't available, so I can't tell where the camera thinks it focused on.
The Soul Hunter
The Soul Hunter Senior Member • Posts: 1,875
this.
The OP, like a lot of neo-photographers, spends to much time on camera settings and not enough time learning about light.
Does no one take art classes any more to learn this stuff?
rgleich
rgleich Contributing Member • Posts: 565
Using nearly identical settings when the subject differs like day and night is almost 100% certain to cause problems:
  • Dark Monkey on Bright, backlit background
  • Light Monkey against dark background, top-lit
BOTH are situation that can mess with the "Auto" metering functions of nearly any camera. (Situations where we need to learn to "guts it out" and switch to Manual Mode / learn how to manage such situations effectively.)
 rgleich's gear list:rgleich's gear list
Fujifilm X-T3 Fujifilm XF 23mm F1.4 R Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR +1 more
OP rolfaalders Forum Member • Posts: 51
Thanks for your repies.
I forgot to mention, but both images are captured in manual mode (I only use M, Actually I try to learn using aperture priority,  but I like M better), so it is not the auto metering that got this result. I actually think the settings of the black monkey are quite correct, since I didn't want to use a slower shutterspeed.
However "bad light" sounds right, like the answer regarding the noise ratio. The remark regarding the art classes sounds interesting! Would you recommend an art class related to photography, or related to painting?
And indeed, perhaps a better composition, would have removed the reasons of the poor quality, but that was not my question. My question was where the poor quality originated from, from a technical/physics perspective, so i can learn. Thanks.
tom1234567
tom1234567 Senior Member • Posts: 1,970
Here is an interesting video about photograph in a zoo using natural light and camera settings explained, if anyone is interested.
https://www.youtube.com/watch?v=yRSLyvsEnS4
Tom G
N.S.A. and G.C.H.Q. The only government goons that "LISTEN"?????
I'm a 30yr old trapped in a 64yr old body
 tom1234567's gear list:tom1234567's gear list
Nikon D7200 Fujifilm X-T2 Nikon Z6 Nikon 120-300mm F2.8E Nikon Z 20mm F1.8 +2 more
John Carson Veteran Member • Posts: 4,343
this.
Sounds like using a hammer to crack a nut to me. It is fundamentally a technical issue of camera dynamic range limitations and learning to try to work around them.
john carson
 John Carson's gear list:John Carson's gear list
Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
I would say it is mainly the backlighting. Metering the exposure on the background means that the face is underexposed.
john carson
The Soul Hunter
this.
Yes, learning about light.
FFS, a one semester art course at the local community college will set a person up for life.
Acrill
Acrill Veteran Member • Posts: 3,166
In situations like the dark monkey, make sure your focus box is as small as possible and right on the eyes.
 Acrill's gear list:Acrill's gear list
Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS
forpetessake
forpetessake Veteran Member • Posts: 5,172
Apart from many factors contributing to the images, the few of them are the most important.
It does look like the first picture is misfocused enough to lose small details.
The lens also shows some veiling reducing the contrast and thus effecting sharpening. You can look at the unsharpened pictures from all x-trans Fuji cameras -- they are very soft. So a good lens contrast at lower spacial frequencies is usually more important than a lens resolution.
Finally noise and the effect of noise reduction. Those depend on the amount of light received by sensor, not the ISO. The monkey on the first image received a lot less light than the one on the second image. So it's more noisy and more softened by the adaptive noise reduction.
slimandy Forum Pro • Posts: 17,161
In the first shot most of the light is coming from the BG. In the second the best light is coming from your subject.
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Fujifilm X-E1 Fujifilm X-T1
I'm not sure I'm familiar with the term veiling. What is the cause of this?  A front element being not clean?
Vic Chapman Forum Pro • Posts: 10,694
Fuji X-M1 XF60mm
Fuji X-M1 XF60mm
Thanks!
IMO it is all of the above, Difficult light, mis-focus but mostly the wrong settings. Ideally you would post actual the images here complete with full exif rather than a screen capture so that we can see all your settings and comment accordingly.
You say you used manual exposure - manual exposure is Manual aperture, manual shutter, ISO etc. If you use any of these on auto, such as aperture priority then that is still auto exposure and it will not change the amount of light coming into the camera. If you want to use AP or SP - both are fine BTW, then also use the + - ev dial to manually adjust the exposure for specific lighting conditions. It may help you to use AP and exposure bracketing for 3 - 5 shots then decide which looks best so that next time you can set your own exposure either manually or using the ev dial.
I'm assuming the XM1 will allow you to do this via dials or menu.
The other advice to learn either by schooling or from books/magazines is also good.
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
this.
That is fine if you have the time. Personally, there is no way in the world I could fit it into my schedule and there are lots of things ahead of it in the queue even if I had the time.
The OP's issues could be dealt with in a few paragraphs. This is a broader issue than photography. Signing up for one semester courses every time you need a few paragraphs of explanation to solve a problem will give you a very busy schedule.
john carson
forpetessake
veiling glare
Veiling glare is stray light in lenses and optical systems caused by reflections between lens elements and the inside barrel of the lens. It predicts the severity of lens flare— image fogging (loss of shadow detail and color) as well as "ghost" images that can occur in the presence of bright light sources in or near the field of view.
All lenses even in perfect condition show this effect to some degree. The dust on glass surfaces, chemical changes in the glass (most frequently happens to the old APO lenses), dirty or poor quality filters, etc. can significantly increase the VG.
