G7 + Sigma 30mm f2.8 Sample Photos
Started Jul 30, 2015 | Photos
Terminal Boy Senior Member • Posts: 1,292
Finally got to take my new G7 for a walk with my daily carry Sigma 30mm f2.8.
All photos are OOC JPGs taken using the "Standard" setting. All shots at f2.8 with exposure adjusted to stay at or near ISO 200.
Mechanical shutter used for all photos.
Uninspiring subjects and composition are down to me, not the camera...
 Terminal Boy's gear list:Terminal Boy's gear list
Panasonic Lumix DMC-GM5 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +2 more
Comment & critique:
Panasonic Lumix DMC-G7 Panasonic Lumix G Macro 30mm F2.8
broody Contributing Member • Posts: 674
Re: G7 + Sigma 30mm f2.8 Sample Photos
Nice samples.
I've had best results with Panasonic JPEGs from using the curves menu to create an S curve with shadows/highlights. Also upping contrast to taste. Have you tried this?
 broody's gear list:broody's gear list
Canon EOS 5D Mark II Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Canon EF 50mm F1.8 II Canon EF 24-105mm f/4L IS USM +5 more
Spectre38
Spectre38 Regular Member • Posts: 466
I think you have a good start.
You do a good job of leading the eye down different paths in the photo.
I would also try using the rule of thirds, adjusting the alignment slightly.
And use some different perspectives than you usually see - squat down, hold camera over head, or tilt it.
A good way to get use to this is to alter the perspective/dimensions in a photo editor to alter the perspective. (in Silkypics if you got that with your camera - the icons along the bottom).
Also try raising the contrast and saturation - the easiest way is in the camera, which will affect the jpegs. If you shoot raw, it won't affect the raw image, so you would have to do that in Silkypics.
Shoot a raw image and edit the rw2 file with Silkypics or RawTherapee and just start adjusting each of the options until you find something you like, then try to emulate that while you are shooting or with the camera settings. (Silkypics is the easiest, RawTherapee is very complex)
 Spectre38's gear list:Spectre38's gear list
Olympus PEN E-PL2 Panasonic Lumix DMC-G6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Sigma 30mm F2.8 DN | A Sigma 60mm F2.8 DN Art +4 more
OP Terminal Boy Senior Member • Posts: 1,292
Thanks for the feedback and helpful tips.
While intending to put these images out there to give the forum and idea of how the 30mm Sigma and the G7 work together, a few pointers are always welcome.
Ulfric M Douglas Veteran Member • Posts: 4,828
Thanks for the info Terminal Boy, very useful stuff.
Next time I go to the camera shop I'm going to try some Jpeg/WB tweaks in the G7 to try to get 'nicer' Jpegs than my last 'standard' tests.
'Scenic' seems nearest for me, but there was still a bit of a grey/blue dullness.
Cheksa wrote:
You're evil Ulfric.
