Test quattro overexposed sky.
Started Jul 29, 2015 | Discussions
Scottelly
Scottelly Forum Pro • Posts: 18,026
Re: Test quattro overexposed sky.
Wow! That isn't supposed to be possible, from what we have been led to believe. I thought it was the shadows that were supposed to be recoverable, when shooting with a Quattro. This looks like one-shot HDR! What's the dynamic range of the new sensor again?
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
Very cool!
I was able to recover about 1 stop overexposure from a DP0Q shot.  How did you go about recovering this overexposure?
Tom Schum
Celebrate mediocrity (in moderation)
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
MOD Kendall Helmstetter Gelner Forum Pro • Posts: 20,587
I'm a bit confused, what is the difference between the three conversions?  Are they from different software?  What settings were used to recover HL?
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
rick decker
MOD rick decker Forum Pro • Posts: 19,097
Yes you need to go over what you did and how you did it.  I tried recovering some overexposed skies and did not have such luck.  I don't think the DR of the shot was that great either as it was an afternoon shot with high overcast and the sun was behind me on the house which was gray and white.
(unknown member) Senior Member • Posts: 1,857
I don't know what gate bois did, but with this particular shot it's enough to convert it with Kalpanika, are clouds are recoverable.
SPP struggles with it and you need to klick the overexposure correction (highlight pixels)
In my tests, this feature produce some color artifacts, but they are again correctable with the SPP fringing correction (don't know if it's the correct word).
But for me it's clear, that SPP needs further improvements.
digi2ap Contributing Member • Posts: 887
Tried it myself - these settings recovered all the overexposed bit and gave a flat contrast TIF to then work on:
Exposure: -1.0
Contrast: -1.5 (ex- 0.0)
Shadow: +0.5
Highlight: +0.5
Saturation: 0.0
Sharpness: 0.0
X3 Fill Light: +0.2
While I don't have a Quattro (yet) I've now tried several X3F's and have been perplexed by much of the criticism I've seen posted around forums about poor highlight recovery etc.
anthonypalmer.me
 digi2ap's gear list:digi2ap's gear list
Sigma SD15 Panasonic Lumix DMC-GH3 Sigma 10-20mm F3.5 EX DC HSM Sigma 18-35mm F1.8 DC HSM Art Sigma 50-100mm F1.8 DC HSM Art
DMillier Forum Pro • Posts: 23,871
bit of haloing around edges. Thought that was Bayer only...
"...while I am tempted to bludgeon you, I would rather have you come away with an improved understanding of how these sensors work" ---- Eric Fossum
Galleries and website: http://www.whisperingcat.co.uk/
Flickr: http://www.flickr.com/photos/davidmillier/
FDecker Senior Member • Posts: 2,344
C'mon, you know it better. Of course, one can create halos with each and every picture. I am sure, you agree that Foveon is less prone to halos than Bayer.
Exposure: -1.0
Shadow: +0.5
Highlight: +0.5
Saturation: 0.0
Sharpness: 0.0
X3 Fill Light: +0.2
with or without overexposure correction?
(i don't think you can recover the clouds without)
maceoQ wrote:
Exposure: -1.0
Shadow: +0.5
Highlight: +0.5
Saturation: 0.0
Sharpness: 0.0
X3 Fill Light: +0.2
Without.
anthonypalmer.me
digi2ap wrote:
maceoQ wrote:
Exposure: -1.0
Shadow: +0.5
Highlight: +0.5
Saturation: 0.0
Sharpness: 0.0
X3 Fill Light: +0.2
Without.
Strange. I get the result on the left with your settings. (right side is a Kalpanika conversion)
left side, SPP without highlight correction; right side Kalpanika
maceoQ wrote:
digi2ap wrote:
maceoQ wrote:
Exposure: -1.0
Shadow: +0.5
Highlight: +0.5
Saturation: 0.0
Sharpness: 0.0
X3 Fill Light: +0.2
Without.
Agreed there is something very different in these two conversions!!
The over exposure correction is making no difference so hence my conversion is without it.
anthonypalmer.me
that's being explored in lin thread...
Gate bois
OP Gate bois Senior Member • Posts: 1,700
With SPP, I put a high value of X3 fill light. I have lowered the exposure. On the correction of overexposure.
Then I made all the improvements with RawTherapee. As for the different versions, I realized with the RawTherapee.
RawTherapee offers many opportunities for improvement for the pictures.
As mentioned maceoQ, SPP still needs to be improved.
According to the two essays he posted showing the recovery of detail in the HL, Kalpanika provides better results that I obtained with SPP, using X3 fill light and activation of the correction of overexposure.
By leaving a version Kalpanika treated, it would be possible to have better results with RawTherapee.
Or working on photos probably even more overexposed.
Roland Karlsson Forum Pro • Posts: 30,033
One reason for the luck may be that he exposed at ISO 400.
If you look in the meta data you see that the CaptureISO then is 400, but the SensorISO is 200. This means that the data in the file is amplified as if it was taken at ISO 200.
So, the data in the file is one stop under exposed and therefore the highlight recovery is one stop extra.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony RX100 III Pentax K-3 Pentax K-1 +14 more
Scottelly
How is this possible?
Sorry if you've already covered this. Maybe an on-line instruction manual with some links to various places where things were discussed could be helpful. Does anyone know of such a resource? x3fTricks.com might be a good domain name for such a website. I guess the problem with such a site would be how quickly it might become obsolete, especially with new tools like Kalpanica/x3f Tools coming into existence. Certainly it would be a site that might be lucrative though, because hundreds (possibly even thousands) of people might become regular visitors. Companies like B&H Photo and Adorama might pay to advertise there, as would companies that make accessories for Sigma cameras, like those electronic viewfinders that were made for the DP Merrills.
Now I have to guess what you mean. And I guess that you are wondering how it can be possible to store an ISO 400 image as ISO 200 data. Right?
  1. We can take the Merrill first. Just like many other Sigma cameras, it does not have any AFE at all. The signal has the same amplification always. And this amplification corresponds to ISO 100. So, no matter what CaptureISO you set for Merrill, it will always be stored as SensorISO 100. Then, SPP and the OOC JPEG uses the CaptureISO and the SensorISO to scale the output with CaptureISO/SensorISO. So, if yoou set the camera at ISO 800, then SPP will scale all values in the RAW data with a factor 8. The main advantages with this method is simplicity and that you do not clip highlights when using higher ISO. On the contrary, increasing ISO, if you also expose less, makes it possible to recover more highlights.
  2. The totally opposite idea is to have SensorISO equal to CaptureISO. So, if you set the camera at ISO 800, then the RAW data in the file is scaled a factor 8, probably by changing the analogue amplification of the signal before A/D conversion. This is how SD15 does it and most cameras on the market. Except that many cameras do not amplify the whole way analogue for high ISO. For high ISO, a part of the amplification is normally digital. So, ISO 3200 might be amplified 8 analogue and 4 digital. But, the result here is that you do not need to store ant CaptureISO or SensorISO in the meta data as the RAW data is already scaled. The advantage here is that you might suck some more info out of the darkness noise.
  3. Quattro is a kind of compromise of 1 and 2. You do here amplify the signal (probably only analogue) but not the whole way. So, if you set ISO 400 (CaptureISO) then you amplify with a factor two, i.e. SensorISO 200. This is probably kind of optimal. You avoid clipping too much, still you can lure out some more out of the darkness. It is kind of clever, and Sigma needs to be clever because of their noise handicap.
