Canon 24-70 f2.8 (M1) heavy vignetting
Started Jul 29, 2015 | Discussions
Marc Plasschaert New Member • Posts: 6
Hi,
I have had my 24-70 for many years on a 40D. I switched to a FF 5Dm3 and now I realise my lens performs like below at 24mm f2.8. Some vignetting @24mm is probably normal for this lens, but this ???
Any thoughts? Same experiences?
Cheers, Marc
 Marc Plasschaert's gear list:Marc Plasschaert's gear list
Canon EOS 5D Mark III
Canon EF-S 24mm F2.8 STM Canon EOS 40D Canon EOS 5D
MutantLabs Regular Member • Posts: 222
Re: Canon 24-70 f2.8 (M1) heavy vignetting
That's a lot of vignetting! Does it change when the lens hood has been removed?
Do you have Lightroom or any other software that does automatic lens correction (including the vignetting)? If so, you can take a picture of an even white background and switch on the lens correction. It should then show a plain white image. If there's still vignetting after the correction, you lens shows more vignetting that it should.
AFAIK, even the in-camera correction (for JPGs) may do the same.
www.flickr.com/mutantlabs
 MutantLabs's gear list:MutantLabs's gear list
Sony RX100 Canon G7 X II Canon EOS 6D Sony a6000 Canon 6D Mark II +10 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Marc Plasschaert wrote:
Hi,
Cheers, Marc
This is either a wrong size off-brand lens hood or a really thick filter(s). I very much doubt the lens had anything to do with this.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
Adrian Tung
Adrian Tung Veteran Member • Posts: 4,032
Agree. Corners that turn completely black are definitely abnormal.
 Adrian Tung's gear list:Adrian Tung's gear list
Sony RX100 III Olympus Stylus Tough TG-870 Sony RX100 VI Sony ZV-1 Olympus PEN-F +23 more
gavin
gavin Veteran Member • Posts: 8,242
I never see this. Looks like hood or thick/stacked filter?
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
Sander 5D
Sander 5D New Member • Posts: 8
You can see the dark blue color in the sky, meaning at least a polariser is attached. If it is an older, thicker model, with a UV filter as well for example, it could easily show up at 24mm. Remove the filters and try again OP.
 Sander 5D's gear list:Sander 5D's gear list
Sony a7 Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 28-70mm F3.5-5.6 OSS
FredVasilescu Regular Member • Posts: 225
Did you ever drop the lens?
I dropped mine once and it got this terrible vignetting, along with other issues as well well. Like excessive play in the front barrel and bad .focusing
 FredVasilescu's gear list:FredVasilescu's gear list
Canon PowerShot G11 Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EF 50mm F1.8 II Canon EF 17-40mm f/4.0L USM +4 more
While you're worrying about the vignetting, it might be appropriate to worry about sharpness (or the lack thereof) as well. That image is very unsharp and unless you've manually focused "just somewhere" without looking into the viewfinder, I'd be very worried.
(unknown member) Veteran Member • Posts: 6,221
I'm betting it's your lens hood. Did you shoot this at 70 mm? With the hood on, try a test shot at 70 mm and another at about 40 mm or less. If it's the hood, you'll see this "vignetting" in the first shot but not the second.
I wonder if moving from a 1.6x sensor (your 40D) to a full-frame sensor made the 24-70 lens more susceptible to this problem. If so, you just need a different hood.
gavin
The hood should not vignette at any focal length? May be the wrong hood would do it
OP Marc Plasschaert New Member • Posts: 6
Thanks for all the good comments.
It was no vignetting as suggested a few times. I had a polarizing filter on a UV filter, which created the shadows at 24mm.
Cheers, Marc
