XF 90mm f/2 Sample Gallery -- What do you want to see?
Started Jul 27, 2015 | Discussions
Samuel Spencer New Member • Posts: 21
Hey Fuji!
I started working on the XF 90mm sample gallery last week, and still need to fill in a few gaps. So far, it's a peach.
What images do YOU want to see from us? I've got quite a bit around minimum focus distance, and street portraits at 2-5.6 (shooting a complete progression today). A flare example is there, and some narrow-aperture shots focused at infinity. What can we give you to help you out (although what I have so far definitely demonstrates how wonderfully sharp this thing is).
Can't wait to hear from everyone.
-Sam
57LowRider Veteran Member • Posts: 4,240
Re: XF 90mm f/2 Sample Gallery -- What do you want to see?
Everything. Go on. I've kept GAS at bay for over a year and now this lens is nibbling at my edges - the price it right too. Go on. Tip me over the cliff.
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +11 more
oscarvdvelde Senior Member • Posts: 1,421
Landscape, nightscapes (city), sports, low light/concert/stage.
Wide open and also stopped down for sunstars.
It seems one could use it for street photography of the other side of the street, which could have advantages for the less bold photographers?
 oscarvdvelde's gear list:oscarvdvelde's gear list
Fujifilm X-T3 Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm XF 16mm F1.4 R WR Samyang 50mm F1.2 +4 more
psxdadz Regular Member • Posts: 326
How about continuous focus ? Tracking
 psxdadz's gear list:psxdadz's gear list
Fujifilm X-M1 Sony a7 III Sony FE 55mm F1.8 Sony FE 70-200 F4 Sony FE 85mm F1.8
OP Samuel Spencer New Member • Posts: 21
Better than the 56, but still held back by Fuji's system itself. I'm purely speculating here, but if a full PDAF system was behind this lens, I expect it would be one of the faster focusing lenses in this 135mm range.
I initially started out with face+eye detection on, and ended up switching it off because it wasn't grabbing the right face, and wasn't gaining me anything over AF-S + recomposing, or moving my focus point to the eye and using AF-C.
Nightscapes? Will do. Sunstars, check. Low light/concert... maybe. Our lens sample guidelines restrict us to base, or occasionally 1 stop over, to get the lens at its sharpest. Concert light, even at f/2, will still be too low to get this below the handheld sharpness threshold of roughly 1/200. A tripod just means that any movements from the band (which a good one will never stay still and keep the energy UP!) will impact sharpness. I'll see if Dan is doing any shows soon so he can at least get the shot, because I do think this FL+brightness+af speed is definitely of interest to concert photographers.
You could just set the camera to 1/200 sec and let the camera pick the ISO. Then fire a burst of shots and usually there should be something very sharp among it. If you would only use the camera JPEGs or even RFC2/Silkypix one would hardly see much difference anyway, also with the noise reduction at high ISO which cannot be turned off, better try RawTherapee for critical sharpness.
Spotlights can be quite bright. I once used a Tamron 90mm at f/2.8, ISO 1600 1/100 sec on a EOS 5D.
ryan2007 Forum Pro • Posts: 12,001
Hey Fuji!
-Sam
I would like to see a portrait in Natural light and one with flash.
These are the settings I always use for JPEG that work well and will not give the plastic skin look.
Set the aperture so it makes sense, it does not have to be F 2.0. For bracketing purposes sure F2.0, 2.8, and 4.0 should be plenty for a portrait.
Manually set Dynamic Range to 100%
Manually set ISO to what makes sense, most times it is ISO 640 or less for me
Select the center autofocus point and do not use Area AF
Use Asia or Provia film simulation, Astia is better here.
Use High Performance mode
Make the focus box big but keep it centered.
Thats about it as my request
bartolyni Contributing Member • Posts: 513
meaningful shots please!
Hey Fuji!
-Sam
Not the usual beer bottles, wines glasses, greasy burgers and sign post shots that have become dpreview trademark. Just be inventive and offer the lens a chance to perform what it was designed for......Please don't take shots to compare it against Sony's counterpart.
forpetessake
forpetessake Veteran Member • Posts: 5,172
First of all, it's a portrait lens. So different types of portraits in different light are in order.
Secondly, it's a short distance sports lens. So some kind of sport action is desirable.
Those are two major uses for this lens. It's not a general purpose lens. People might shoot other random stuff with it, but they don't buy it for that purpose (some may do ... some always do).
Hey Fuji!
-Sam
PeterFXCassidy Contributing Member • Posts: 792
Hey Fuji!
-Sam
The Gettysburg address.
Program the Wifi button for time travel. It's in the manual, the part no one reads.
 PeterFXCassidy's gear list:PeterFXCassidy's gear list
Fujifilm FinePix E900 Zoom Olympus TG-810 Fujifilm FinePix S5 Pro Fujifilm X-E1 Fujifilm X-M1 +11 more
Chris Dodkin
Chris Dodkin Forum Pro • Posts: 13,956
Sam - if only you could mail me the lens, I could shoot some studio and natural light fashion and glamour sets for you - it would be a perfect test.
http://f-sunny.com
The future is just a click away...
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm X100F Fujifilm X100V Fujifilm X-T2 Fujifilm GFX 50S Fujifilm GFX 50R +50 more
deednets Forum Pro • Posts: 13,887
Hey Fuji!
-Sam
Portraits
Portraits
Portraits
Skin tones ...
Technical stuff e.g. cogwheels, nuts & bolts.
Just saying ... that would be great, thanks!
Deed
 deednets's gear list:deednets's gear list
Leica Q2 Fujifilm X-Pro3 Sony a7 IV Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Click4hope Junior Member • Posts: 44
Demonstration of the, relative for this kind of lens, close focusing ability to show what can be achieved in both portrait and general situations.  Both wide open and stopping down a bit. Having used a Canon 135L I am pleasantly surprised with the creative opportunities this feature gives us.
I agree it's a great lens.
Andy
(unknown member) Forum Pro • Posts: 47,805
Get 1-2 landscape shots at F5.6
That or shoot a tree- make the street stand out at F2.0.
Compressed landscape shots with telephoto lenses are interested.
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - George Orwell
HB1969 Senior Member • Posts: 1,724
Agree...more portraits please
I'd like to see this too.
 HB1969's gear list:HB1969's gear list
Fujifilm X-E1 Fujifilm X-Pro2 Canon EF 50mm F1.8 II Canon EF 75-300mm f/4.0-5.6 III Nikon AF Nikkor 50mm f/1.8D +12 more
Jason Haven Regular Member • Posts: 312
I want to see you send it to my address so that I can enjoy owning it.
 Jason Haven's gear list:Jason Haven's gear list
Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
