What Pana Lens is worth considering Over Olympus lens if you use OLY body?
Started Jul 26, 2015 | Discussions
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: They all are worth considering
Marty4650 wrote:
If you have an Olympus body, then you don't have to worry about whether a lens has OIS. better or worse.
If you have an early Pen body with 2 axis IBIS then switchable OIS is a better option.
If you have the later E-PM2, E-PL5, E-PL6 again with 2 axis IBIS but now able to use unswitched OIS then again the OIS is a better stabilising option.
Plus of course with OIS the live view can be stabilised without needing to half press, nice and easy framing with tele.
In my case earlier with E-PL5, the Panasonic 45-150mm using OIS was great. And earlier still with E-PL1 using the Panasonic 14-45mm with switched OIS was ideal.
Now with E-P5 anything goes and I only use IBIS.
So choose the lens that does the best job and that can be used to advantage with the particular body you own now, or might own in the future.
A lens lasts a lot longer in obsolescence terms than any of the current bodies.
Regards...... Guy
Arizona Sunset
Arizona Sunset Veteran Member • Posts: 3,797
Re: What Pana Lens is worth considering Over Olympus lens if you use OLY body?
The total cost of ownership over ten years, the difference that is, regardless of selling it at the end, is going to be pennies per day. Some lenses are worth the money - for a stop, or bokeh, or contrast - but next to FF prices, all m43 lenses are a steal. Smaller lighter and sharper for the money. So get the best that you prefer and can afford or don't. Sell the ones that you don't use, and let someone else enjoy them. There is no algorithm or spreadsheet or formula to quantify a lens like the 42.5 f1.2 or 25f1.4 - you are missing out without, or I would be. The provided spreadsheet does not help me decide what to buy - they are all evenly priced from a certain vantage point - price per picture.
 Arizona Sunset's gear list:Arizona Sunset's gear list
Canon G7 X II Sony RX1R II Sony RX100 VI Apple iPhone 7 Plus
RedDog Steve
RedDog Steve Senior Member • Posts: 1,972
It's generally accepted that lenses are a more long term investment than a body.
One would be misguided to base a lens purchase solely on which body is currently being used.
If there's even the remotest chance you'd have a Panasonic body in the future shouldn't that be taken into consideration to some small degree ?
rd
 RedDog Steve's gear list:RedDog Steve's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Panasonic Lumix G Leica DG Summilux 12mm F1.4 ASPH Panasonic 8-18mm F2.8-4 +17 more
Steve2015 Contributing Member • Posts: 516
If you have to ask, then you don't need one.
The pana lenses I'd look at if you have an oly body is...
PL 15mm 1.7 over the oly 17mm 1.8
PL 25mm 1.4 over the oly 25mm 1.8
PL 42.5mm 1.2 over the oly 45mm 1.8
They are the only panny lenses I'd personally consider....and have.
ep2Brute New Member • Posts: 21
Re: For me Robert, it is the
I do hope that you're right, because I ordered a "good as new" copy of the Panasonic 35-100 f2.8 on EBay earlier today. I hope that it's a good copy, as the price was right. I agonized over the Olympus 40-150 f.2.8 Pro last week, when two new ones were listed on EBay for $1149. While strongly tempted, I just couldn't see myself lugging that thing around while enjoying travel. I don't believe that I'll be disappointed with the Panasonic on my Olympus E-M1.
JeanPierre Martel Veteran Member • Posts: 3,304
I don't know.
The M.Zuiko 45mm F/1,8 is very good but the Lumix 42,5mm F/1,7 is better.
The M.Zuiko 12-50mm is handy (being a macro lens) but the Lumix 14-42mm is sharper.
Both are cheap and very good.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
lahsrah Contributing Member • Posts: 603
20mm F1.7
Panasonic 20mm F1.7.
My most favourite MFT lens, ever. If they release a mark III with faster focusing and same size, I'll purchase it immediately.
Pana 1.3x more expensive
This one is well worth the price. It focuses almost twice as close as Oly 45. Great for faux-macro for things like flowers.
e.g. https://www.flickr.com/photos/cameralabs/16985960386
Nathan Cowlishaw
Nathan Cowlishaw Regular Member • Posts: 297
Hands down, the two lenses I would recommend in the whole M/43 lineup are:
Olympus 75mm F1.8 & the Leica Nocticron. I've owned several lenses in Micro Four Thirds and these are BY FAR the best lenses I have owned. Trust me, they are worth the investment.
Nathan Cowlishaw
 Nathan Cowlishaw's gear list:Nathan Cowlishaw's gear list
Olympus OM-D E-M5 Olympus PEN E-PL5 Olympus PEN E-PM2 Sony a7R Olympus M.Zuiko Digital 17mm 1:2.8 Pancake +15 more
Bhima78 Senior Member • Posts: 2,850
15, 42.5 1.2, 35-100.
Those three simply because they have no equal on Oly's side of the fence. The 15mm is a fantastic lens as long as it doesn't have AF issues with your Oly body and offers an interesting field of view. The 42.5 f1.2 is the crown jewel of lenses for this system and I think the 35-100mm f2.8 is the perfect balance of performance, size and price (can be found on Amazon for $850). Oly's 40-150mm is a better performer overall than the 35-100... but it makes up for it by being MUCH bigger and heavier.
 Bhima78's gear list:Bhima78's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario 35-100mm F2.8 OIS +12 more
Maklike Tier
Maklike Tier Regular Member • Posts: 462
Trying to compare the closest Focal Length and Aperture Lenses Between Pana and Oly.
It appears that the Panasonic Lenses OIS is significantly driving the cost of each Lens purchase.
Question
1.What Pana Lens is worth considering Over Olympus lens if you use OLY body?
I found 1 focal length range is cheaper in Panasonic.
That is the Panasonic 14-42 f/3.5-5.6 (165 USD) vs Olympus 12-50 f/3.5-5.6 (500 USD)
Well, if price is the only criteria, pick the cheapest!
I sold my Pana-Leica 25mm f1.4 and bought an Oly 25mm f1.8 because technically it's sharper accross the frame, but I kinda miss how the PL25 renders and wish I'd kept it, despite it's significant size difference.
The new Oly PRO line of lenses are bigger than the Pana f2.8 equivalents, so if size and weight is an issue, then the Panas are going to be better for you.
It also depends on where you buy from. For some reason, Olympus gear here in Australia is the cheapest anywhere in the world, so the Panasonic stuff has to be significantly better for Oly users to choose Panasonic over Olympus because the price different is almost universally substantial.
I'd consider getting a Panasonic 20mm f1.8 pancake though, simply because there is no alternative. That would be a handy lens to have.
 Maklike Tier's gear list:Maklike Tier's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Regardless of the body use the lens you want BUT …
… WHEN MAKING COMPARISONS, COMPARE LIKE WITH LIKE.
Question
Comparison:
Panasonic 15mm is a considerable amount wider in view than the Olympus 17mm. It makes quite a difference.
The Oly 12-50 is incomparable. The 12-50 is one of a kind -- it is the only lens with those zoom boundaries in the m43 range. Forget comparing it with anything.
In the middle range, compare the Panny and Oly 14-42s -- they have a whole bunch of them.
Did you mention the Oly f1.8 45 and the Panny 1.7 42.5? One is old and the other new. That accounts for any price difference.
The Oly 40-150 and the Panny 45-150 -- for the longest time, these two were comparably priced with the Panny just upwind a little. I paid that price for each of them and considered I was doing very well what with the lovely results I got. Then Oly started to throw out the f4~5.6 40-150 -- I presume to put the emphasis on the f2.8 40-150. Both these Oly and Panny lenses are first quality -- I have used/use them both and am unstinting in my praise for them. Lots of other people on this forum are too.
At $99 it is practically criminal neglect for any m43 owner not to grab the Oly lens. I am not doing so as I now have the Panny 45-150. That's all.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
Dancebert
Dancebert Forum Member • Posts: 87
Ken Christie wrote:
In your 3rd comparison you're not comparing like with like.
Either you neeed to compare 12-50 from both manufacturers, or 14-42 from both. (Oly has 2 versions of the 14-42)
Of course one can make the comparison if one is trying to fill a need. That is 'like with like' for someone who wants a zoom that's about 14-45 and about f3.5-5.6, By your reasoning, one can't compare between P42.5 and O45, or P20 and Sigma 19. I'm not particular about the length of a 'normal' lens, so I'd compare 20s and 25s.
The best camera is the one you're carrying.
My best album (not an album of my best photos): http://www.flickr.com/photos/98341917@N08/sets/72157634470548031/
 Dancebert's gear list:Dancebert's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic 20mm F1.7 II Olympus 12-40mm F2.8 Pro +2 more
