Should the name of this forum be adjusted?
Started Jul 26, 2015 | Discussions
SnappyChappie Regular Member • Posts: 434
Do you think this forum's name should now be:
"Canon Rebel (EOS 1000D-760D) Talk" ?
Or am i just being pedantic?
 SnappyChappie's gear list:SnappyChappie's gear list
Canon PowerShot A620 Canon EF 100mm F2.8L Macro IS USM Canon PowerShot SD780 IS Canon EOS 6D Canon EOS M50 +13 more
msowsun
msowsun Contributing Member • Posts: 740
Re: Should the name of this forum be adjusted?
(EOS 1000D-760D) leaves out many models.
(EOS 1200D-300D) covers all the models but seems backwards to me. I think the Forum should be named (EOS 300D-1200D) as it covers all the models within that range.
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
WilbaW
WilbaW Forum Pro • Posts: 11,643
Yes, it's backwards. But don't forget the 100D!
Check out the unofficial Rebel Talk FAQ.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
msowsun
Yes, I did forget the 100D. Mine says SL1 on it and that's probably why I forgot.
So it is agreed then. The forum should be renamed "Canon Rebel (EOS 100D-1200D)"
Digirame Forum Pro • Posts: 41,857
Agreed...good point!
BarnET Veteran Member • Posts: 3,581
100D-1100D it is then.
This way we miss 1 model but that model has no place and is better off forgotten.
 BarnET's gear list:BarnET's gear list
Panasonic Lumix DMC-GX7 Fujifilm XF 18-55mm F2.8-4 R LM OIS
Another good point!
OP SnappyChappie Regular Member • Posts: 434
No i can't agree as it's not based on mathematical numerical progression but on Canon's naming method of more numerals being the lesser models and the lower of the numbers being earlier or lesser models reading left to right.
So that being [from memory so i may miss some]:
1000D, 1100D, 1200D, 100D, 300D, 400D, 450D, 500D, 550D, 600D, 650D, 700D, 750D, 760D.
Thus to save space - "Canon Rebel (EOS 1000D-760D) Talk"
Or maybe 'Canon Rebel Kiss (EOS 1000D-760D) Talk'
Or 'Canon EOS 1000D-760D (Rebel/Kiss) Talk' <- Yeah, that's me fave!
Even though I don't care much for the Canon T5 (1200D) entry-level DSLR camera, it really should be part of the name (because that's Canon's choice).  Some people like and use it.
How about Canon Rebel (EOS 100D-1200D) Talk?  Really the Canon SL1 (100D) should be part of the name.
kodakrome
kodakrome Senior Member • Posts: 1,026
The forum should simply be called "Canon Rebel". The numbers aren't needed.
WilbaW
See "Canon EOS 7D / 10D - 70D Talk" and "Canon EOS-1D / 5D / 6D Talk".
Olga Johnson Forum Pro • Posts: 24,360
The Rebel name is not used internationally.  That is why the numbers are added to the name.
Olga
Cananeer New Member • Posts: 11
Or just as simple - Canon Rebel (EOS series) Talk
Indeed Olga is correct, hence my last highlighted "fave" forum-talk name includes the EOS numbers for Europe, 'Rebel' for North America and 'Kiss' for Japan
Formal, feisty and cute.
Once again, Rebel is not international and EOS is redundant since all Canon dSLR cameras include the EOS name.
Olga
iancrowe Senior Member • Posts: 1,477
How about "Canon Rebel/xx0D/xx00D/Kiss Forum"?
This has the advantage of covering new models as they arrive hence not requiring a forum name change with each new model.
Ian
Hey look, it's now changed to "Canon Rebel (EOS 300D-760D) Talk".
I was close with my first suggestion
That's great!
means the 1200d no longer has a place.
good riddance.
msowsun
That's great!
good riddance.
What about the 100D?
007peter
007peter Forum Pro • Posts: 12,933
Solution to include Japan + NA + Europe = KISS my REBEL XXXd
You know, the only happy solution is to include the name of every content sales names. That means:
  • KISS my REBEL XXXd forum
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
