70-200 F4 IS lens collar with arcaswiss mount.
Started Jul 23, 2015 | Discussions
Mark den Hartog Veteran Member • Posts: 3,679
I've been looking for a (replacement) lens collar with arcaswiss plate included.
No luck so far. anyone know of such a lens-collar? for nikon they are there which limits searching through google.
thanks,
Mark
OP Mark den Hartog Veteran Member • Posts: 3,679
Re: 70-200 F4 IS lens collar with arcaswiss mount.
I guess it doesn't exist?
Adrian Tung
Adrian Tung Veteran Member • Posts: 4,032
Apparently so... I checked the two usual suspects, Really Right Stuff and Sunwayfoto, and didn't find anything.
Is there any reason why you aren't considering a regular plate to attach directly to the OEM collar?
 Adrian Tung's gear list:Adrian Tung's gear list
Sony RX100 III Olympus Stylus Tough TG-870 Sony RX100 VI Sony ZV-1 Olympus PEN-F +23 more
Less is moreĀ  all small bits end up weighing down the bag. so to move plate on top of a plate ... well seems unnecessary, also a little less stable?
Adrian Tung
Less is more all small bits end up weighing down the bag. so to move plate on top of a plate ... well seems unnecessary, also a little less stable?
It's a little more weight, that's true... but a good plate from Really Right Stuff, Wimberley, etc isn't going to compromise on stability.
ed rader Veteran Member • Posts: 9,068
then why even use a collar?
its not really needed on that lens especially if you have an L bracket on your camera.
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
bigdaddave Senior Member • Posts: 1,163
Re: then why even use a collar?
No, of course it isn't and you can make up a cheap lens ring/arca plate combo for pennies on ebay
Glue it together if you want fewer parts
I will use it on a sony with metabones so getting a collar is a good idea I think.
I know I can do without, but in theory it will be less prone to vibrations... also adding an extender in the mix will make this a wonky setup :-P.
I think I found something on amazon where you can unscrew the plate from the collar.
strange to see that they make it for nikon and not for canon.
I will see how far the nikon version will take me. I still have it... still i'd prefer a dedicated one.
thanks guys.
