Display issue on NX300
Started Jul 23, 2015 | Discussions
bancika
bancika Regular Member • Posts: 421
It's (still) not that big of a deal, since it only happened twice so far, but both instances happened withing the last few weeks, so I'm a tiny bit worried.
When I start the camera, display shows the whole picture but kind of shifted vertically. The top ~20% of the picture is shown at the bottom of the screen, and the rest is shifted up. So everything works, the whole picture is shown, it's just shifted. Restarting solved the issue both times.
Anyone saw anything similar? If it happens again I'll try to take a pic so I can show, but hope I explained it well enough.
 bancika's gear list:bancika's gear list
Samsung NX300 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 12-24mm F4-5.6 ED Samsung NX 45mm F1.8 2D/3D +4 more
Samsung NX300
Skipper494 Forum Pro • Posts: 11,264
Re: Display issue on NX300
Sounds like you need to reboot to defaults and reset everything.
bancika
OP bancika Regular Member • Posts: 421
thanks for the reply, but what does that mean?
LiveM Veteran Member • Posts: 3,836
Go to Reset under Settings. Also go to Device Information to check Firmware Update.
 LiveM's gear list:LiveM's gear list
Samsung NX1
bancika
Thanks. Done. Let's wait and see if it happens again. Firmware was up to date btw.
Cheers
