Do you want a 10.5mm f2 prime?
Started Jul 22, 2015 | Polls
Loga Senior Member • Posts: 1,981
Recently it turned out, that on my trips, the Panasonic 14mm f2.5 + 0.79X wide angle converter combo is my most used lens. It works, it's not bad, but far from good either. A dedicated, high quality prime around 10.5mm with good f value would be very welcome. Please vote, whether you want one as well.
 Loga's gear list:Loga's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX85 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Leica Summilux DG 25mm F1.4 +6 more
POLL
Yes, I want something similar to a ~10.5mm f2 prime.
48.7% 38  votes
No, I want something even wider
23.1% 18  votes
No, I don't need that wide angle prime.
28.2% 22  votes
  Show results
Panasonic Lumix G 14mm F2.5 II ASPH
TheEye
TheEye Veteran Member • Posts: 4,883
Re: Do you want a 10.5mm f2 prime?
For years many of us have clamored for a small, fastish 9 or 10mm lens. Neither Oly nor Panny are listening.
OP Loga Senior Member • Posts: 1,981
Exactly, I followed the discussions. Now I feel the need of having one. Maybe if we keep pushing here, they won't make a new kit zoom or 25mm f1.x again.
However, I'm not quite sure that anybody from Olympus or Panasonic is listening to this forum.
FaFik
FaFik Regular Member • Posts: 147
Panny 14/2.5+DMW-GWC1 is my second most often used lens recently (after 20/1.7). Sharpness in the center of the frame is quite good and even sides are decent, only corners are very soft, but I just try to take it into consideration framing my shots. I thought FoV might be too wide for me, but surprisingly I really like it.
The only gripe I have is the size of this contraption. Compared to lone 14/2.5 it's HUGE. I wish Panasonic made pancake lens this wide.
 FaFik's gear list:FaFik's gear list
Panasonic Lumix DMC-G3 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital 45mm F1.8 +5 more
rurikw
rurikw Veteran Member • Posts: 3,788
No i want an f4 <300g <500€.
 rurikw's gear list:rurikw's gear list
Nikon Coolpix 5000 Sony Cyber-shot DSC-R1 Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill +37 more
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Need 9mm, don't need f2, want a pancake. nt
7
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
Colin K. Work Veteran Member • Posts: 3,699
Definitely wider (7mm) doesn't have to be fast (f4 would be fine) - but sharp edge to edge.
Colin K. Work
www.ckwphoto.com
www.pixstel.com
Astrotripper Veteran Member • Posts: 8,676
I want/need faster
After a rather disappointing Nokton 10.5, which I had great hopes for, I would welcome less extreme, but more competent lens. But f/2 is a bit too slow. Make that f/1.7 with decent quality wide open, and I'm in. I wouldn't mind if it were a bit wider as well.
But I'm not seeing this happening. So I'm warming to the idea of acquiring Samyang 12/2 at some point.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Re: Need 9mm, don't need f2, want a pancake. nt
Hen3ry wrote:
I'm fine with 9mm too, need at least f2.8, don't need a pancake
L.
But the 14/2.5 is TINY! What bothers me more is that when you try to unmount it, in some cases the converter starts to detach as well on its own.
Dave Lively Senior Member • Posts: 1,938
I like the idea of a truly wide prime but a fast version would be so large, heavy and expensive one of the existing ultra-wide zooms would be a better choice for me.
I want a wide prime mostly for use outdoors when 12 is not wide enough so a slower lens would be fine for me. But it would have to offer some combination of lighter, faster, better optical quality or be less expensive than the Olympus 9-18 or Panasonic 7-14 before I would buy it. A focal length of 10.5 is too close to 12mm where we already have the Olympus 12mm.
Once you get below a certain focal length rectilinear lenses get larger and heavier as they get wider, not smaller. A 10.5mm f2 would be larger and heavier than the 12mm. And I doubt a pancake is possible with a lens that wide unless optical quality and speed were sacrificed. Like other posters I would really like a 9mm pancake with decent optical performance even it was slow but I doubt it is possible.
tpani
tpani Regular Member • Posts: 332
There is a Nikon FX lens AF-S 20mm f/1.8. Size is 82 x 84 mm, weight 355 g.
Scaling this down in every dimension by a factor of 2 gives a lens of size 41 x 42 mm, and if all components would be similarly made smaller, the weight would be 44 g (1/8th). Of course, realistically, the lens would be heavier, probably over 100 g, similarly to the 12mm f/2.0 Olympus (size 43 x 56 mm), which is 130 g.
 tpani's gear list:tpani's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G6 Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 +11 more
Comparing the Nikon 50mm f1.8 to the Olympus 25mm f1.8 I am not seeing the 2 to 1 reduction in linear dimensions you are assuming. That only seems to be valid for super telephoto lenses. The Nikon AF-S 50mm f1.8 is 71 x 53 mm and weighs 185 g. The Olympus 25mm f1.8 is 56 x 41 mm and weighs 136g. If the same scale factors present in the 50 -> 25 comparison are applied to the Nikon 20 the theoretical m43 10mm lens would be 65 x 65 mm and weigh 261g.
A 10mm m43 lens would probably be smaller and lighter than that since the SLR lens has to be designed so a flapping mirror does not hit the rear element. But it would still be larger and heavier than the Olympus 12mm. It would probably be more expensive too but that depends on what quality level it was built for. A wide, fast prime is not a typical consumer item so I would expect both the quality and cost to be high.
Gato Amarillo Veteran Member • Posts: 9,353
Would like a 9, 10 or 11 -- but compact, not f2
An f2 would be larger, heavier and probably much more expensive than a slower lens and, for what I do, offer no real benefit.
I want a compact or pancake. I'd rather have a small 2.8 or even 3.5 than pay extra and carry more bulk for speed I don't need.
Gato
"We paint with our brain, not with our hands" -- Michelangelo
Portrait, figure and fantasy photography at Silver Mirage Gallery:
silvermirage.com
FaFik
There is another promising combination: GWC1 on Panaleica 15/1.7. Full stop faster and looks much sharper in corners (maybe even in center, but hard to tell from JPEGs): http://kaimax777.pixnet.net/blog/post/190373655-%E3%80%90%E9%96%8B%E7%AE%B1%E3%80%91panasonic-leica-dg-15mm-f1.7-%2B-dmw-gwc1-%E5%BB%A3%E8%A7%92
tpani
Flange/registration distance with M43 is 20 mm. For the Nikon mount the distance is 46.5 mm. M43 sensor area is 17.3 x 13 mm, while Nikon FX has 36 x 24 mm. The one thing that is not roughly 50 per cent is the mount diameter. The wikipedia article on the Nikon F-mount says that the mount "external diameter" is 46.5 mm. I am not sure how to measure the corresponding for M43. I just checked the 9-18mm mount, which measures between 50mm (outer) and 40mm. Anyway, the M43 mount diamater seems (relatively) much bigger than the Nikon mount (not 50 per cent, but more like 80 per cent). But this is really the only thing that is not about 50 per cent.
The width of the mount, and the need to have many parts of the lens as thick as (and not 50 per cent only) for bigger lenses (so that things do not bend or break) explains why a 10 mm f/4 is not 44 grams, but 100 g, or possibly even more.
The basic procedure is: take any Nikon FX lens design, scale down _everything_ to 50 per cent. You get a M43 lens for a flange distance of 23.25 mm. Make the mount M43, and add 3.25 mm to the lens to make the flange distance effectively 20 mm. Same of course can be done with Canon EF mount lenses. Flange distance 44 mm. Sensor 36 x 24 mm. Same story.
addlightness Veteran Member • Posts: 3,641
I voted 2nd option (something wider) as I'm happy with my 14mmf2.5+wide 0.76x converter(from Fuji).
A $500 7.5mm f4 rectilinear AF would be nice.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
SpinOne Veteran Member • Posts: 4,059
How many of you are willing to spend $1,100 (or more) on a rectilinear 10mm f/2 prime?
How many $1,100 10mm primes do you think they'd have to sell to break even, let alone make a profit?
Franka T.L.
Franka T.L. Veteran Member • Posts: 8,161
simply YES
the need for a school if quality and fast fix focals of the more nominally used coverage is there for any system type ILC , and should be provided
- Franka -
cocoanud
cocoanud Contributing Member • Posts: 706
7.5mm non fish eye prime with screw mount filter thread.
 cocoanud's gear list:cocoanud's gear list
Canon EOS R6 Canon EF 100-400mm F4.5-5.6L IS II Canon EF 70-200 F4 II Canon RF 24-105mm F4L IS USM Samyang AF 85mm F1.4 RF +3 more
