New XF 90mm F/2 on Fuji XPro-1 - OVF not accessible ?
Started Jul 20, 2015 | Discussions
AlexPonsin Regular Member • Posts: 164
Just went to B&H yesterday to try out the new (ish) 16mm and the 90mm, I was disappointed that the OVF did not want to turn on with the 90, I do realize that the bright lines would be quite small, but I can live with that.
At first, I thought it was because I had to update the firmware of my Xpro, but doing some research afterwards, it seems that fuji blocked the bright frames at 60mm (visible with the Zoom Lenses apparently). And there hasn't been any firmware upgrade on the Xpro past 3.4 which was released way before the 90mm.
Does anybody has information about this topic ? Is it reasonable to expect "kaizen" to the point of allowing OVF on the Xpro with a firmware upgrade ? Why would they limit it in such manner, since there's the EVF no matter, how would it hurt the camera to let the OVF on especially since the lens does not block the view that much, I bet it would be quite usable ?
Alex
All the pictures that I post on DPreview, are usually from my Flickr account: http://www.flickr.com/photos/alexandre_ponsin/
 AlexPonsin's gear list:AlexPonsin's gear list
Sony RX100 Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +3 more
Powerdoc Veteran Member • Posts: 3,941
Re: New XF 90mm F/2 on Fuji XPro-1 - OVF not accessible ?
I doubt that Fuji will update the firmware to let the 90 mm to work in the OVF mode. Fuji did not allowed it on purpose.
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm X-T1 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
Vic Chapman Forum Pro • Posts: 10,694
They don't operate at more than 60mm. You may think you could use the OVF at 90mm but you couldn't. Focus would at best be hit and miss and if you were using the lens at f2 then as a user of the 90mm with both XP1 and XT1, I can tell you that at f2 you need to be very very accurate indeed or it will notice. The transition from ultra sharp to ultra smooth oof is swift though smooth so any error in focus will be very evident.
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
DarnGoodPhotos Forum Pro • Posts: 11,881
I can see the lens physically blocking a lot of the OVF so I doubt it would be very useful.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
