35mm f/2 IS USM vs. 24mm f/2.8 STM pancake
Started Jul 17, 2015 | Questions
skopinsky New Member • Posts: 2
Hello!
I'm new to photography, and for now it is mostly just a hobby.
That being said, I'm shooting on a Rebel T6s and currently have the kit lens (planning to use this mostly for travel purposes) and the 50mm f/1.8 STM.
I really love the artistic flexibility that the lower aperture of the 50mm gives me, but I find it is just too zoomed in sometimes. I would like to purchase another prime lens to use to take pictures of my family and friends along with some artistic portrait and engagement photos for some close friends.
I've narrowed it down to the 35mm f/2 IS USM and 24mm f/2.8 STM pancake. Which do you think is better or is there another lens that I am overlooking? Is it worth it to buy both? Price isn't a huge factor in deciding between these two lenses, but I would say I do not want to spend much more than the price of the 35mm in total.
Thanks in advance!
-Sami
Canon EF 24mm f/2.8 Canon EF 35mm F2 IS USM Canon EOS Rebel T6s (EOS 760D / EOS 8000D)
Great Bustard Forum Pro • Posts: 45,641
Re: 35mm f/2 IS USM vs. 24mm f/2.8 STM pancake
skopinsky wrote:
Hello!
Thanks in advance!
-Sami
24mm would complement 50mm better than 35mm.  However, the 35 / 2 IS has an extra stop and IS, although it's larger, heavier, and more expensive (but not so large, heavy, and expensive as a 35 / 1.4).
To be honest, I'd advocate the Sigma 18-35 / 1.8 which performs as well optically as all the primes in its range, as well as being faster than the two primes you asked about.  What are the downsides?  It's larger, heavier, and more expensive than either of the primes, does not have IS, and some report having AF issues.
arty H Senior Member • Posts: 1,546
The 35 F2 IS is a great lens on crop for family photos. It is exceptional for low light, and the IS is useful. The AF is as fast and accurate as I have seen. It is worth thE cost of admission.
Dan_168 Forum Pro • Posts: 11,062
skopinsky wrote:
Hello!
Thanks in advance!
-Sami
I would suggest before you jump into any of those prime lens, take a look at the Sigma 18-35 F1.8 Art series lens. That's of course if you are not planning to go Full Frame any time soon.
I have played with this Sigma on my friend's D7200 body and I have to say this is one GREAT lens, a fast zoom that gives you prime lens quality, I would be shooting one for sure if I have a crop sensor body.
Doug_PS
Doug_PS Contributing Member • Posts: 812
skopinsky wrote:
Hello!
Thanks in advance!
-Sami
The 35 f/2 IS has an equivalent FOV of 56mm on full frame. If this FOV would work for you, and it sounds like it might based on what you've described, then the Canon 35 is hard to beat. It's a terrific lens. I tested it along with the sigma 35 1.4 Art when I purchased my 35mm lens. I ended up going with the Sigma, but it was a tough call...both are excellent lenses.
The 24mm Pancake would give you more of the 35mm FOV on a full frame. I haven't tried the 24 Pancake, but do own the 24 2.8 IS and it works well on my 7DMKII. Which to choose between the 24 Pancake & 35 f/2 IS would largely depend on whether you prefer the 35mm or 50mm FOV (full frame).....a classic debate always!
The 24 Pancake is priced so reasonably that you could go for both if you are intent on going all prime! This would put you around $700 range. Not bad for a small, light weight, quality set of lenses (ie including your 50mm). But, you would still be missing the 15/18 to 24 wider end....could be significant depending on your needs. The Canon zooms that include this range are "slow" with the exception of the 17-55....which is pricey$$.  These are tough calls that I've always struggled with on my crop bodies as well!
Some have mentioned the Sigma 18-35 f/2. Just my experience, but: I've recently tried 2 different copies of this lens and both were very out of focus requiring very large and very different adjustment settings (ie at the various focal lengths and distance ranges.....using the Sigma dock). This combined with the very hit/miss focus accuracy of the lens....I was never able to dial in the focus adjustments (after hours of trying).....unlike the experience with adjusting the focus of my Sigma 35 art with the dock (ie a breeze). Not sure if the 18-35 just does not work well with the 7DMKII? The 18-35 is a great concept.....just didn't work for me. Anyway, if you consider this route, keep in mind that you'll need the Sigma Dock. Price of Sigma lens and dock: $850.
 Doug_PS's gear list:Doug_PS's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EOS M6 Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM +9 more
BAK Forum Pro • Posts: 26,020
repeated question
MODERATORS _ consolidate with her almost identical question, please.
